Moved to Washington, snow advice?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pax11B, Sep 17, 2017.
  1. Sep 17, 2017 at 9:38 AM
    FRE1809
    FRE1809 Well-Known Member
    Long Island,N.Y. ; USN ( Ret.)
    I second the notion about getting a set of winter tires Blizzacks are the way to go.
    KTJO 4x4 likes this.
  2. Sep 17, 2017 at 11:23 AM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Nobody is advocating filling the bed up with 1000lbs of sand, a couple hundred pounds will help keep the back end stable without significantly increasing stopping distance. Edit: not to mention easy traction aid if you or someone else gets stuck.
    Lots of good advice here OP, your wildpeaks I believe are 3 peak mountain snowflake rated which is an industry standard for winter traction. I plan on putting these tires on my truck sometime in the next couple months. As far as studs, they need to be studdable from the factory IIRC, don't think you can add them to any tire.
  3. Sep 17, 2017 at 12:29 PM
    myamada1230
    myamada1230 Well-Known Member
    Greenacres, WA
    2021 TRD Offroad DCLB
    Welcome to the area, I live in the Spokane Valley also. What part of the Valley are you in? The best advice I can give you is to take your time and give yourself plenty of room. Road conditions can change from icy to wet to icy again in the blink of an eye. Good tires in the winter are a must. In a perfect world, I'd run dedicated snow and ice tires, but I run KO2s and have had pretty good luck in winter conditions with them. I drove across White Pass in December and had zero issues. IMG_5780.jpg I also carry a recovery strap with me and thankfully have not needed to use it yet.
  4. Sep 17, 2017 at 12:42 PM
    weefek
    weefek Well-Known Member
    J
    2017 OR ACLB
    Something you probably wont hear too often but here goes: Don't go too SLOW either. There's nothing more dangerous than someone going 15/20 km/h when the conditions call for 40 or 50 especially on a highway
    Paul6506 likes this.
  5. Sep 17, 2017 at 2:02 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Lol my wife has a prius but it's a beast around town with blizzaks. Again, common sense wins in the fight against ice. Doesn't matter how many wheels you have, 4 x 0 will always take you in a ditch.
    Sand bags in the bed will keep you from having to switch to 4x4 more often. As others have stated, first snow go to an empty parking lot and have a little test in the different modes.
    GotToyota likes this.
  6. Sep 17, 2017 at 2:05 PM
    Tacowin1013
    Agreed, sand bags aren't the best for weight distribution but they are the most convenient... Can load and unload 60 lbs in under a minute.
    ndoldman59 likes this.
  7. Sep 17, 2017 at 2:54 PM
    Pax11B
    Pax11B [OP] Well-Known Member
    2017 Quicksand Tacoma TRD OR AC
    https://www.tacomaworld.com/threads/pax11b-quicksand-build.491885/
    Thanks for all the advice. I'm currently in an apartment complex so having an extra set of winter tires is a little hard. But the Wildpeaks are rated for snow so we will see how it goes. Luckily everything is right around me so I won't have to drive very far.
    I always carry straps and once winter hits I'll mount up my max Trax just in case
  8. Sep 17, 2017 at 3:49 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Take your truck to your nearest Les Schwab and get a good set of chains and ask about sipping your tires for better traction on wet or icy roads. By the way, excellent choice of Taco!!
  9. Sep 17, 2017 at 7:01 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    There's no substitute for experience in snow. Take the 'advice' here with a grain of salt. Wash your truck, fluid film if you want. Get snow tires if you want, again no substitute for experience.
    upTOPOverland_Drew likes this.
  10. Sep 17, 2017 at 7:46 PM
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    Just a couple things not mentioned don't pull out in front of someone just because you have a 4x4, slushy ruts can pull you in directions you don't want to go, if the snow is somewhat powdery you can become snow blind from the "draw" back draft , keep windows clear. most other comments are good, even the best of drivers have problems. I had my first winter accident 2yrs ago and totaled my 04 in 41 years of winter driving.
    Coot83 likes this.
  11. Sep 20, 2017 at 4:20 PM
    Pax11B
    Good advice, I'm going to do that tomorrow. Correct me if I'm wromg..but I believe I read in my owners manual not to use chains on these trucks?
  12. Sep 20, 2017 at 5:06 PM
    Captqc
    Tigard, OR
    Nope ! Check pages 274 & 275 for information on chains.
  13. Sep 20, 2017 at 5:15 PM
    modifiedtaco
    modifiedtaco Well-Known Member
    Alex
    2016 Magnetic Gray Tacoma Limited
    Tuff Country 3 inch spacer kit with aal Tuff Counrty 1/4" spacer on LF (for taco lean) Bilstein 5160 rear shocks Bilstein 5100 adj front struts (removed tuff country front spacers) set to 0 lift OME 886 coil springs Front sway bar relocation bracket N-Fab Rock Rails 17x9 -12 Fuel Beast wheels Toyo AT2 285/70/17 tires Led light conversion on all interior lights Morimoto 35w HID kit 5500k OE all weather floor mats OE Tonneau cover OE Door Sill Protectors Bed Mat De badged all factory emblems matte black vinyl tailgate letter and Tacoma emblem on door silver vinyl insert on glove box and door sill protectors OME Carrier Bearing Drop Insain Fab cab mount chop plates Weathtech Rain guards
    Just a couple things no one has mentioned yet.. If you go to local Les schwab you can pick up a set of chains just incase.. If they are not used you can return them for a full refund in April.. Also If your braking or turning and start to slide don't keep you foot on the brake, many times if you let of a bit you can regain control..
  14. Sep 20, 2017 at 5:59 PM
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    Good advice on this thread. Having lived in New England and now Portland and Seattle, I can tell you that the icy conditions is way harder to drive here than anywhere else. In Boston, I drove a BMW rear rear drive with Blizzaks in all conditions and no problem. In Portland, I had a 4x2 Taco and barely made it home 12 miles from downtown Portland due to the icy conditions. The problem is the hills and shady areas than the snow itself. Oh and the city's willingness (finally) to use salt and borrow Seattle's equipment is helpful.
    Now, Eastern WA is different than Seattle and Portland, but the main thing to watch out for is the other drivers! Give yourself lots of room and watch out!!
    Captqc likes this.
  15. Sep 20, 2017 at 6:20 PM
    #35
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Not sure how the washington winter is, but I'm in canada so for our winters here.
    Coat underbody
    have winter tires (we get icy winters)
    plug in at night (just takes strain off the start in the morning and has the truck heat up faster)
    Use 4x4 when needed.
    UNDERSTAND 4x4 does not mean you can stop any better. so leave plenty of space. Tires are the only thing that will help you stop next to hitting something.
    I have the Nokian hakkapelitia R2s, absolutely loved them last winter.
    Hosing off might not do much, understand salt activates with moisture so unless you are removing all of it you could actually be doing more harm than good. touchless drive through car washes are good. not the cheapest but I go every week or two.
    I haven't tried it in the truck yet so not sure how it will work but when driving my jetta I always use engine braking a lot more than the actual brakes. You could likely do the same with the taco in heavy snow. Its not for when the conditions are ok just for when really shitty conditions. less brakes, more engine braking really helps.
  16. Sep 20, 2017 at 6:36 PM
    #36
    AWDDude
    AWDDude Well-Known Member
    2017 Tacoma TRD Off Road DCSB, QuickSand
    Congrats on the move! I moved up from Houston Texas 2.5 years ago. I live about an hour and half south of you in Pullman, WA.
    myamada1230 likes this.
  17. Sep 20, 2017 at 7:00 PM
    #37
    Pax11B
    Someone told me they don't even use salt any more, they use some sort of chemical but it still gets corroded. At least where I'm at.
  18. Sep 20, 2017 at 7:02 PM
    #38
    Pax11B
    And you have a Quicksand! Haha. I'd still like to get to know people up here. My buddies are deploying this month..figures..I've been here not even a month and they end up leaving haha
  19. Sep 20, 2017 at 7:30 PM
    #39
    Pax11B
    In regards to siping, aren't my wildpeak at3w pretty well siped? Hate to cut them even more
  20. Sep 20, 2017 at 7:39 PM
    #40
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    There are two Schools of thought as far I know in Washington in the snow: 1. Drive as fast as you can to beat every snowflake before it hits the ground. 2. Drive as slow as possible so every snowflake has hit the ground. As far I know their are only these are the only way to drive in snow in Washington, or Wershington as the locals call it.
    bobsuruncle and rlx02 like this.
