Movement in carrier bearing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MattN03, Jun 5, 2014.
  1. Jun 5, 2014 at 4:54 AM
    MattN03
    MattN03 [OP] Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    I can move the carrier bearing center where the driveshaft goes through it up and down some. How much play is normal?
  2. Jun 5, 2014 at 5:22 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Does it vibrate when you drive or slow down? If so, it should be changed.
  3. Jun 5, 2014 at 9:43 AM
    MattN03
    Bluegrass State
    I haven't noticed any vibration
  4. Jun 5, 2014 at 10:09 AM
    mb911
    mb911 Well-Known Member
    Ben
    Burlington WI
    4X4 double cab
    none
    My truck does the exact same thing I notice a little Vibration I guess more of a lugging when I slow down sometimes. Does that indicate the bearing needs to be changed? then do I have to get it rebalanced.
  5. Jun 5, 2014 at 10:11 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    This, it has a rubber bushing in it and its supposed to move some but if you have vibration then it's probably time to replace it.
    Here's a solid carrier if you want to go that route.
  6. Jun 5, 2014 at 1:14 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    DO NOT, I REPEAT DO NOT, go with a solid carrier on a prerunner... they do not have the rear slip joint like the 4x4's (they use the slip yoke at the front u joint) to account for driveline extension / collapse and having the solid center would HORRIBLY bind up the suspension and break a lot of things.
