Moving from 2nd Gen to 3rd...what to know
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Freeheelbillie, Dec 14, 2019.
  1. Jan 9, 2020 at 10:29 AM
    #241
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Right. I wonder if these same people hop in a tractor and cry because it doesn't redline high enough.
    It's a different engine. The driving style needs to be adjusted. Want power? Put it in a gear that has the rpms over 3500
    shakerhood[QUOTED] likes this.
  2. Jan 9, 2020 at 11:39 AM
    #242
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Exactly.....so in my experience, you control the shifting more in the auto. Toyota certainly gives you the option. At least in The posts I read, many just throw the trans in D and expect the computer to do something it wasn’t set up to do, go fast with good acceleratiin . It’s programmed for economy.
  3. Jan 9, 2020 at 11:43 AM
    #243
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Exactly. But, many of these guys had the 4.0. You can drive all day under 2000 rpm and still Get lively performance under 3000.
    Really, it’s like driving a four cylinder till it gets up there.
  4. Jan 9, 2020 at 1:16 PM
    #244
    m603holden
    Marteeen
    New England
    I had two second gens before this. One AT and one MT. Wheeled both. People get butt hurt and fixed on a number. Rpm is irrelevant. Put it where your truck is making the ft-lbs. If you have the same bandwidth that puts out better torque just at a different range, it's up to the driver to adapt to the truck.
    WSchafer and shakerhood like this.
  5. Jan 9, 2020 at 3:42 PM
    #245
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Sorry, for me it depends on use and on what you’re using it for and rpm is totally relevant. It’s why I chose a kubota over a John Deere and a 2015 taco over a 2016. One reason I expressly chose a 2015 over the next gen 2016 was because I towed with a 2004 4 runner with exactly the same motor. Technically they tow the same weight. The 4.0 is just a better motor for trucks and does it much easier and with less fuss. There is little debate. Plus of course...I was cheap and got the 2015 OR for the same price as a 2016 sr5.
  6. Jan 9, 2020 at 3:47 PM
    #246
    2ndGenOffRoad
    2ndGenOffRoad Well-Known Member
    Los Angeles, CA
    '14 SBDC OffRoad 4x4 '84 4Runner 22RE
    Schmell Fab Sliders ATH Fab Rear Bumper Icon Stage 3 Suspension Front Runner Outfitters Roof Rack Softopper Bed Cover 285/70/17 KM3's on T4R Pro Wheels
    DON'T DO IT!!!
    Freeheelbillie[OP] likes this.
  7. Jan 9, 2020 at 4:09 PM
    #247
    m603holden
    Marteeen
    New England
    No, no it does not. 225ft-lbs at 2700rpms vs 225-ft-lbs at 3400rpms is still 225 ft-lbs. First gear is really the only place you see a difference until you're put in the power band. The difference is great for arm chair bragging rights, but not really a factor in the real world.
    And arguing which tows better between the 3rd gen and 2nd is like arguing if spaghetti is easier to eat with a knife or a straw.
    The right tool is a fork. Or for towing, a full size. The difference is just not enough between the two and for the rest of the world who drives and tows with bigger trucks, we always laugh at this topic.
    WSchafer likes this.
  8. Jan 9, 2020 at 5:00 PM
    #248
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    That’s not quite right.
    If vehicle speed were the same in both cases, 225 ft-lbs at 3400rpm would be a good bit more torque at the wheels than 225 ft-lbs at 2700rpm.
    You only need 179 ft-lbs at 3400rpm to have the same torque at the wheels as 225 ft-lbs at 2700rpm if the truck was traveling at the same speed down the road.
    That’s why power matters, not just torque, and that’s why power and gearing can mean a smaller engine that can rev higher can be faster than a larger engine if it is allowed to operate in its optimal powerband with the right gearing.
    Like you said, having low end grunt is nice from a stop to avoid needing high rpms, but that’s really why electric motors are ideal for it.
    Jeff
    CrippledHo likes this.
  9. Jan 9, 2020 at 5:28 PM
    #249
    Freeheelbillie
    Freeheelbillie [OP] Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    Gonna stick, with my 07...I love the spirited debate though!
  10. Jan 9, 2020 at 6:49 PM
    #250
    cleats50
    cleats50 Well-Known Member
    chris
    Tacoma 2007 TRD
    air intake push bar running boards
    No an automatic that felt sluggish and herky jerky.
  11. Jan 9, 2020 at 6:52 PM
    #251
    cleats50
    chris
    Tacoma 2007 TRD
    I have an 07 and had an 18 as a rental while I got my frame replaced. I seriously liked the ride in my 07 better.
  12. Jan 9, 2020 at 7:07 PM
    #252
    xola3que
    xola3que Well-Known Member
    Long Valley, NJ
    2019 Tacoma Sport
    Do you like the gas mileage better too?
  13. Jan 10, 2020 at 6:23 AM
    #253
    Undertow
    Undertow Well-Known Member
    CT
    2020 Cement DC OR 6MT
    Stock
    The problem is I don't like wringing out the engine to get power - it makes it less day to day friendly.
  14. Jan 10, 2020 at 6:43 AM
    #254
    Bowhuntercoop
    Bowhuntercoop Well-Known Member
    2025 gx550 overtrail. 2025 limited off-road tundra.
    Couldn’t pay me to go back to a 2nd gen. My 3rd gen tows better, looks better, and the mileage is way better. There is seriously nothing about a second gen that would ever want me to go back. The 4.0 was great but this 3.5 is just as good if not better. Push the pedal, the truck scoots quite well.
    vicali, xola3que, shakerhood and 2 others like this.
  15. Jan 10, 2020 at 8:34 AM
    #255
    xola3que
    Long Valley, NJ
    2019 Tacoma Sport
    the 3.5L is a better allarounder than the 4.0L, IMO. You need it, crank it up. You don't, let it simmers down and saves you money.
    Ideally, a hybrid is great but given that it is a pickup truck and for its intended purposes, hybrid is complex and expensive. You wade it in the puddle once, you have a lifetime of headaches. Pickup trucks are built for abuses and modifications, not to make it jump off the line to impress anyone.
    Trust me, If Toyota put a hybrid into the Tacoma, you will see how quickly the resale value gets bombed. And 4-5 years from now when all these skateboard electric trucks hypes die down, you will see what a bad idea it really is.
  16. Jan 10, 2020 at 8:43 AM
    #256
    m603holden
    Marteeen
    New England
    Zero issue here.
    Again, another case of the driver not adjusting to the truck. 99% of the issues out there.
    165k on an 06' access cab. 130k on a 11' double cab and now 59k on a 17'.
    Love hearing the rental stories though.
    WSchafer and Bowhuntercoop like this.
  17. Jan 10, 2020 at 11:10 AM
    #257
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    For these engines 3500 isn't that high. Hell to go up over the mountain to Tahoe I usually have it around there and in "S"uper mode to keep it from upshifting so I can maintain speed and accelerate quicker if need be.
  18. Jan 11, 2020 at 4:02 PM
    #258
    Undertow
    CT
    Stock
    A truck should really have some low end torque.
  19. Jan 11, 2020 at 4:08 PM
    #259
    CrippledHo
    Eric
    2016 DCSB Diet Coke
    True, and it would be nice if it had more, but as it sits it's not a bad. If I'm nitpicking then I agree with you, but day to day it more than enough get up and go.
  20. Jan 11, 2020 at 6:00 PM
    #260
    m603holden
    Marteeen
    New England
    You're right.
    Boy do all the Tacomas suck compared to trucks that need low end torque.
    Sincerely,
    The dude with the 3500hd work truck, 60gal fuel cell, rack body, and 1600lb welder who also operates heavy machinery on the side of mountains installing 30k gallon fuel systems.
    Yes. Familiar with torque. As someone who's owned both and has thousands of actual trail miles vs "I had a rental for a week", the power is fine.
    harrycw3 and WSchafer like this.
