Moving from 2nd Gen to 3rd...what to know
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Freeheelbillie, Dec 14, 2019.
  1. Dec 16, 2019 at 4:59 AM
    #101
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    Every 3rd Gen owner on here has stated at some point that the Gen3 will tow as much as the Gen2 albiet at a higher rpm. The specs of the engine says the same thing regarding peak torque. If the numbers for torque that you have just stated were true, then I would have assuredly bought a Gen3 back in '16. You are saying that by using less displacement and a shorter stroke, we've managed to produce more torque at low rpm. I call bull on these number.
    GreyBaldTaco likes this.
  2. Dec 16, 2019 at 5:10 AM
    #102
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    I hope Toyota goes all in on a hybrid taco.
  3. Dec 16, 2019 at 5:15 AM
    #103
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    I don’t doubt that the tranny has a lot to do with it . After all, my tractor can pull 10000 lbs with 40 hp and 60 lbs of torque. But, the rpms per mile are astronomical. Same idea at work here.
  4. Dec 16, 2019 at 7:54 AM
    #104
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    These trucks are selling at record levels so Toyota did something right, CR is a joke.
    Grindstone likes this.
  5. Dec 16, 2019 at 8:08 AM
    #105
    AstoriaTRD
    AstoriaTRD Well-Known Member
    I drive with the ECT (Electronic Controlled Transmission) button on all the time. In my non-professional humble opinion it regulates the shifting to higher in the rpms especially 1st thru 3rd. Personally my taco drives much more to my liking with it on...the gas mileage is very close. I average 20-21.
  6. Dec 16, 2019 at 8:51 AM
    #106
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Yeah it would be interesting to find two equally packaged trucks and run them. The times I quoted were from separate C&D tests. That said, Toyota's official times for the 4.0L vary by as much as 0.6s depending on truck options (7.7 and 7.1).
    Would be very interesting to see them back to back, same tires, same day, etc.
    The ECM logic definitely seems to keep the 2GR at a higher RPM than the 1GR.
    As for the numbers, there's more to the torque produced than just the stroke length. I think everyone agrees that the 3.5L can output more peak torque than the 1GR (280 lbf-ft for the FR version 2GR at 4800rpm, and 266 lbf-ft for the 1GR at 4000rpm).
    Ignoring any potentially erroneous plots, the 1GR makes peak 266 lbf-ft at 4000 rpm, that means that at 4800 rpm it is definitely making less than 280 lbf-ft. So you have two engines at the same RPM, the engine with the shorter stroke is pushing more torque. The illustration here is that there is a lot of variables that determine the output of an engine beyond stroke and displacement. What applies at 4800rpm still applies at 2000rpm.
    There are older 4.0L and larger engines that make less torque than the 1GR. Design, technology, and tuning methods can make big changes between two engines.
    Again, I'm not saying my numbers are right, they're just what Toyota has provided. If we're looking to make direct comparisons, again, strap a 2015 and a 2016 onto the same dyno on the same day and see how they actually compare. The info from Toyota is at least done on an engine dyno to SAE's test guidelines, so can be reasonably compared I would think.
    It's all bench racing in the end though. People will feel what they feel, and there's a lot to how a vehicle "feels" when it's pulling beyond the numbers being put to the ground. Height, seating position, throttle response, shift logic, noise, vibrations, etc., etc. all add so much to how a vehicle feels that small differences in actual torque output can be almost completely overshadowed. It can be quite incredible.
    Jeff
  7. Dec 16, 2019 at 9:31 AM
    #107
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Well said, but those are the numbers comparing two motors in a range trucks don’t normally spend their life working in. Find for the Venza which normally doesn’t make slow runs off road or pulling a trailer, not for a truck. The ideal motor is electric. Anything that comes closer to approximating it’s power out put over a working range, is better for work. That’s the point we 4.0 drivers make.
    It doesn’t go un noticed. CR says the powerful and smooth 4.0 is the best thing about the Tacoma in 2015.
    After that year, it’s all about excuses why it underperforms comparably and there are few accolades compared to others in its class.
    In the hylander, it’s a very well regarded motor. IMO, it’s misplaced for the sake of 2 mpg.
    There are two solutions in making this 3.5 a viable truck motor with better low end torque; adding a turbo or adding ( an) electric motor(s). One compromises it’s reliability, the other enhances it. Let’s hope Toyota chooses one. Otherwise, it remains a less competitive truck motor.
  8. Dec 16, 2019 at 9:44 AM
    #108
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Toyota sells well for one primary reason. Everyone who actually uses a truck to work, values reliability and durability. That’s reflected in every review CR makes. They are spot on in their reviews. Just because they don’t print what one wants them to, doesn’t make them false. Aamof, pissing off at least a small segment of the population is more often a sign of honesty in their reviews.
  9. Dec 16, 2019 at 9:51 AM
    #109
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    Get a 2015 TRD Sport 4x4 with low miles
    uwhusky12 and Dagosa like this.
  10. Dec 16, 2019 at 9:52 AM
    #110
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Yah, it’s like the fastest car/truck Toyota is making after the Supra....which is a bmw derivative. Toyota makes hybrids well.
  11. Dec 16, 2019 at 9:54 AM
    #111
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    uwhusky12[QUOTED] and Dagosa like this.
  12. Dec 16, 2019 at 9:55 AM
    #112
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    There are a boatload of safety enhancements do you'll be mush better protected if you're ever in an accident. That is reason enough to get a 3rd gen. They are still solid trucks that perform like you would expect. I've definitely put mine through it's paces and it's never let me down. The interior is obviously much nicer. My only suggestion would be to get an MGM sport do a hood swap with me.
    Junkhead likes this.
  13. Dec 16, 2019 at 9:58 AM
    #113
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    I think the only way we're going to settle the real torque question is hook up both trucks, put them in 4H and see which one moves forward. Maybe this seems a bit childish but aren't we all just big boys with big toys anyway? :duel:
  14. Dec 16, 2019 at 9:59 AM
    #114
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Can’t argue with that. The safety enhancements are preventative in nature. This is where Toyota leads the industry in making so much standard. You’re absolutely right. There is a great reason to buy new Tacos ( and other Toyota’s ), safety features.
  15. Dec 16, 2019 at 10:00 AM
    #115
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    It’s been settled in every review and head to head test. The 3.5 is a pussy, compared to the 4.0. My toy is bigger....;) and better and it gets worse mileage to prove it.
    Steadfast[QUOTED] likes this.
  16. Dec 16, 2019 at 10:01 AM
    #116
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    If I'm not mistaken (and I might be) there are more airbags in the third gens than the second gens as well.
  17. Dec 16, 2019 at 10:02 AM
    #117
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Could very well be. If I had to bet, I’m betting on that. At least, They have to be better engineered too. but, Toyota has always improved safety every year regardless of model change. So, I’d buy a 2020 over a 2017 for that reason too. Much more is standard.
  18. Dec 16, 2019 at 10:28 AM
    #118
    SirPuck
    SirPuck Well-Known Member
    2016 Tacoma TRD Offroad
    I purchased a '16. I have always heard never purchase the first year of a newly redesigned vehicle but I have been very happy. No issues with anything. Maybe the newer generation reached a more sensitive bunch that tend to whine alot, who knows. I am glad I didn't start reading online posts prior to purchased my '16 or I might not have purchased it.
  19. Dec 16, 2019 at 11:03 AM
    #119
    shakerhood
    Southern Ohio
    Go to TFL on YouTube and look at the towing tests, the 3.5 Tacoma sucks the doors off the 4.0 while achieving better MPG. It also beats the Frontier by over 40 seconds and is only about 3 seconds behind the Ranger which was supposed to be the quickest of the class.
    WSchafer likes this.
  20. Dec 16, 2019 at 11:09 AM
    #120
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    No! No! No! No! No!
    Waah! It's a minivan motor! Waah!
    I must defend the honor of the amazing 4.0 truck engine at all costs! It's a real TWUCK motor dammit!
    Waah! Waah!
