Moving from 2nd Gen to 3rd...what to know
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Freeheelbillie, Dec 14, 2019.
  1. Dec 16, 2019 at 1:22 PM
    #161
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    I have owned a 22R in a Celica. It was underpowered. I do still have an appreciation for their reliability, but they were not impressive to drive, at all.
    Jeff
  2. Dec 16, 2019 at 1:29 PM
    #162
    Bushed
    Bushed Well-Known Member
    Kenora, ON
    08 DCSB TRD OR - Sold
    Cambridge Metals and Plastics Bed Bar
    I’m stuck trying to decide between 3 machines right now. I have 3 acres with about 600 feet or road access and driveway with one section being rather steep down to the house. The machine would be used for snow removal in the winter, and maintaining the gravel drive the other 3 seasons. I also have a few projects where I could use a backhoe, but once they’re done, so would be my need for a hoe. So the choices are a BX23S for around $24K plus probably a snow pusher box, and grader scraper. A used B2601 with 20 hours, that I could probably get with the pusher and grader for the price of the new BX. Lastly, an L2501 TLB off a friend of a friend in the spring. Low hours, but the lack of mid PTO makes me hesitate, in case I’d ever like to go the front mount blower route, I’d like to have that option available to me. Back issues make a 3 point mount blower undesirable. What thoughts, advice, recommendations do you three Kubota aficionados have to pass along?
    Steadfast[QUOTED] likes this.
  3. Dec 16, 2019 at 1:37 PM
    #163
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Did you load the tires or add wheel weights ?
  4. Dec 16, 2019 at 1:48 PM
    #164
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    A couple of hints.always get 4 wd !! It’s much safer braking and overall use. If you’re working off road, you’ll need the ground clearance; if you can possibly afford it, get an L series. Second, I use a rear blower and also have back issues. But, I always drop the blower skids on angled 6 by6 by 4 foot pieces of lumber, never in bare ground. I can then use a crow bar to easily align the the machine with the hitch points. I prefer not using front mounted blowers. You lose the use if the bucket and the weight of the blower on the back makes for much safer use. With that weight and chains, I sometimes don’t even use 4 wd
    You’re right....Back hoes are great, but unless you’re a contractor, you run out of use for them in no time and they’re the most expensive add on. I never saw one pay for itself. I would just rent a back hoe for stumoage and ditching and temp use. You get a really big one and fly through jobs and it’s much cheaper over time. .
    Best of luck.
    Steadfast and Bushed[QUOTED] like this.
  5. Dec 16, 2019 at 1:54 PM
    #165
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Not the turf tires, but my ag rears will be. Either going to use rv coolant or washer fluid. I don't like the price of rim guard personally.
  6. Dec 16, 2019 at 1:57 PM
    #166
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Excellent choices. My calcium in inner tubes have been in place for 13 years...never a problem.
  7. Dec 16, 2019 at 2:01 PM
    #167
    Lt. Dangle
    Ohio
    Yeah calcium certainly has a better specific gravity compared to my 2 choices, but I just wanted to avoid the corrosive nature of calcium in case of a leak. Rim guard is very close to calcium in regards to the specific gravity, but I'm too cheap for that.
    Steadfast likes this.
  8. Dec 16, 2019 at 2:08 PM
    #168
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    They loaded mine with beet juice when I bought mine.
    Dagosa likes this.
  9. Dec 16, 2019 at 2:12 PM
    #169
    Lt. Dangle
    Ohio
    Yeah that's rim guard.
  10. Dec 16, 2019 at 2:13 PM
    #170
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    I don't think we need the turbo in the Tacoma. Just my opinion
  11. Dec 16, 2019 at 2:22 PM
    #171
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    I had an '84 Celica GT with the 22RE engine. great little daily driver. Just enough power to have some fun but not enough to get into trouble. I also had several Toyota pick-ups with the 22RE engine. To talk bad about the 22R engine is blasphemy in my books. :duel:
  12. Dec 16, 2019 at 2:30 PM
    #172
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    As long as the calcium is in tubes, there should be no problem. Either way, I would use tubes no matter what other choices you make. The liquid ballast is the best way to go instead of wheel weights.
    The other thing about tires too is, store your tractor out of sunlight. I keep mine under a car port and the only tire that I’ve had to repair, is the left front that gets sunlight...;)
  13. Dec 16, 2019 at 2:32 PM
    #173
    ryan760
    ryan760 Well-Known Member
    Still blows my mind that they used the 22REs in those old Dolphin motorhomes.
    Junkhead likes this.
  14. Dec 16, 2019 at 2:41 PM
    #174
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    But but but it’s not a twuck motor!
    WSchafer likes this.
  15. Dec 16, 2019 at 2:53 PM
    #175
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    I don’t think we “need” it either. But, 300 ft lbs of torque like the Ford Ranger has, ...would be sweet.
  16. Dec 16, 2019 at 2:54 PM
    #176
    WSchafer
    WSchafer Well-Known Member
    Will
    2020 Midnight Black Metallic 4Runner TRD OR
    22RE PUSSY MOTOR CONFIRMED
  17. Dec 16, 2019 at 2:54 PM
    #177
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    It’s for people in no rush who can stop any time to take wiz while cruising in the breakdown lanes at 50 mph.
  18. Dec 16, 2019 at 2:57 PM
    #178
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    That’s cause the early Toyota’s weren’t really trucks compared to f150 s. Now, they’re as long as the standard full size. They got a lot bigger.
  19. Dec 16, 2019 at 3:05 PM
    #179
    Bushed
    Kenora, ON
    I can probably buy the L2501 in the low to mid twenties (Canadian bucks). We haven't talked price, but the guy wants to sell it in the spring, as he's beginning to downsize. Says he'll give me a good deal on it. The friends and family deal. I could always get the backhoe work out of the way, then sell it to buy more useful implements. Hadn't really considered what you mentioned about a rear blower. Don't know that I'd go that route anyways. A snow blade or pusher would probably work better for my application. My biggest concern it the weight of the machine for work out in my yard, which is a clay base. Very hard when dry, but there's still wheel depressions from when the previous owners moved out seven years ago. Guess I'd just stay off the grass when the ground is wet.
  20. Dec 16, 2019 at 3:17 PM
    #180
    WSchafer
    Will
    They’re still shorter, narrower, and lighter in comparable configurations. But this is all a non point, because the 3.5 in the Tacoma is also much closer to the engines in many half tons then the 22RE was.
