Moving to the Salt belt...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Morbid_168, Jun 10, 2020.
  1. Jun 11, 2020 at 1:25 PM
    Morbid_168
    Morbid_168 [OP] Member
    nicholas
    2008 DCSB sport
    It is a 4x4, has lived mostly in the southeast, SC, NC, TN, and CO when I lived out there. I'm in Tennessee/Kentucky now. I have experience driving in the snow in 4wd, as well as rear driven and front driven cars. And my commute to and from work will not be far.
    I've read into fluid film and crown a lot. That stuff does seem to work. Like I said, I'm hoping I won't be there for very long, maybe two winters.
    Maybe I'm freaking out over nothing, but I'd rather be prepared than have a Swiss cheese taco. I'm moving in july/August time frame if COVID allows, so I'll have time to prepare.
    Thank you all for the advice
    GQ7227, 3JOH22A and doublethebass like this.
  2. Jun 11, 2020 at 4:05 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    My Taco has been in VT all it’s 12yrs and 190k. The salt, salt brine is harsh.
    I had a long ass post but! I tried and failed new frame 2yrs ago. It’s like new again!
    If you can avoid exposing it to salt do it.
    Subaru’s are great in the winter and can be found for decent money. Timing belt needs to be done by 100k.
    doublethebass likes this.
  3. Jun 11, 2020 at 4:24 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    If you don't want the winter salt and chemicals to eat at your truck, have it rustproofed (or use Fluid Film if you want to do it yourself) and have it done yearly to keep maximum protection against rust
    That's the only way to protect it, other than not driving it though the salt
    If the existing rust is surface rust only, don't need to remove it before a rustproofing treatment. If you have loose flaking rust, it is best to remove it with a wire brush before applying the rustproofing grease
  4. Jun 13, 2020 at 12:49 PM
    88Taco
    88Taco Well-Known Member
    Michigan
    Black 08 DCSB TRD Off-road.
    Rear diff breather mod. Block heater
    Icon shocks are much more resistant to corrosion than others. HOWEVER, the salt and bullshit still does a number on them. The springs rusted the first year and the adjustment nut was corroded so tight when I went to longer springs it took a bench vise and an air hammer to break it loose. Cannot recommend that process ever again. Storing it for the next couple years is your best bet but letting vehicles sit can cause issues as well.
  5. Jun 13, 2020 at 2:03 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Buy a beater and park your Tacoma during the salted road time.
