Moving USB to console or glove box?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12SuperWhiteDC, Oct 2, 2012.
  1. Oct 2, 2012 at 9:23 AM
    12SuperWhiteDC
    12SuperWhiteDC [OP] Well-Known Member
    West Alabama
    12 DC SR5
    I'm thinking of pulling the USB connector back into the dash, and connecting a USB extender to run it to the console or the glove box. Before I rip the dash apart (and since alldatadiy doesn't have the '12s yet) has anyone laid eyes on the backside of that connector? If so, any advice on the idea of relocating the port?
    Why move it, you ask? I use the USB input to play music from a small flash drive. I'd like to remove it from sight by putting it in the console or glove box without having to yank the flash drive every time I park it.
    Thanks!
  2. Oct 2, 2012 at 9:30 AM
    Onetime27
    Onetime27 Well-Known Member
    Joe
    Columbia Gorge, OR
    ‘20 OR DC
    275/70/16 AT3Ws
    Sub'd I'm curious as I like a clean look with damn near nothing showing.
    Good Luck!
  3. Oct 2, 2012 at 9:42 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Is it down below the Ac controls where the aux input is? If so, it's easy to pop it out. On the backside there is a plug.
  4. Oct 2, 2012 at 10:00 AM
    12SuperWhiteDC
    West Alabama
    12 DC SR5
    Yes, it is on the same switch blank as the aux. Thanks!
    I was looking at this thread yesterday and got the idea to move the port. My wife's Accord has the AUX port in the center console.
  5. Oct 2, 2012 at 10:02 AM
    JLink
    Josh
    Ocean, NJ
    I have an aftermarket head unit, but mine is in the glove box. Wouldn't want it out in the open
  6. Oct 2, 2012 at 7:15 PM
    abcdleines
    abcdleines Well-Known Member
    Brett
    Portland, Oregon
    2012 Prerunner SR5
    Super White, Two tone black and grey leather, AVS hood protector, AVS in channel window visors. Leer 180 cap. New TRD exhaust, TRD 17" wheels.
    I took mine out and ran an extension from the back of the panel to the arm rest. Then I purchased a blank filler at the dealer to fill the hole in the dash. Much cleaner look than having my iPod wire just laying there. And my iPod is now out of sight.
  7. Oct 2, 2012 at 7:19 PM
    DLat27
    DLat27 Well-Known Member
    Danny
    South Jersey
    2012 TRD Sport DC LB Pyrite Mica
    Black tail lights mod FX-R stage III retrofit w/ orbit shrouds and XB Angel Eyes Morimoto Mini elite H11 kit for fogs Horn relocate mod Toyota Man's Sleeper Lids
    Show some pics if you end up doing this. Sounds like a cheap easy mod lots of people would like. Sub'd.
  8. Oct 2, 2012 at 7:28 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Is a $20 USB flash drive really worth all this trouble?
  9. Oct 2, 2012 at 8:22 PM
    JLink
    Josh
    Ocean, NJ
    last time i checked, ipods could be used through a usb port... and the cord alone costs $20....
    but i do realize you are referring to the op where he said he uses a small flash drive
  10. Oct 2, 2012 at 9:31 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I think I saw some pics awhile back, the back side of the connector mades no sense IIRC. Lots of wires for no reason. If it come down to it, just leave the connector hooked up, plug in your extension, secure it with a zip tie behind the dash and still run it to your glove box. Out of sight, out of mind.
  11. Oct 3, 2012 at 5:01 AM
    12SuperWhiteDC
    West Alabama
    12 DC SR5
    The flash drive certainly isn't worth the trouble to protect, but the window that someone goes through to get at it is. Out of sight, out of mind....
  12. Oct 3, 2012 at 6:18 AM
    shemp
    shemp Well-Known Member
    I wouldn't bother. A thief who goes to the trouble to break in isn't going to worry about a $5 flash drive, they'll crowbar the HU right out of the dashboard and leave the flash drive.
    I promise.
  13. Oct 3, 2012 at 7:03 AM
    12SuperWhiteDC
    West Alabama
    12 DC SR5
    stock head unit, so the list of suspects would be pretty short.
    Oh, and I have a band clamp holding the head unit to the tailgate. :rofl:
  14. Oct 3, 2012 at 8:54 AM
    shemp
    Those 2012 HU's look pretty fancy, and that's all the thief will be looking at.
  15. Oct 3, 2012 at 9:03 AM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    If I had a '12 I would find out which wires are for the USB and extend those to he glove box and add an additional USB port there. This way the factory aux/USB is still in place, but the USB portion can be accessed from a second plug in your center console. :) just my .02
  16. Oct 3, 2012 at 9:20 AM
    shemp
    Are those HU's capable of managing multiple USB devices on a hub?
  17. Oct 3, 2012 at 9:29 AM
    ProForce
    Anthony
    Alaska
    Probably not. I wouldn't use a hub, nothing would be plugged into the OEM USB port. It would be tapped onto the wires behind the plug. Like splitting the signal. It would work fine unless you plug in something to both ports at the same time though. Just have to b mindful of that. Even adding a hub won't work I don't think.
  18. Oct 3, 2012 at 10:53 AM
    shemp
    In that case, I'd be inclined to route an extension wire to the glove box and just plug it in as needed rather than hard wiring. BAD things can happen if somebody accidentally plugs in two devices to the same wire.
  19. Oct 3, 2012 at 11:49 AM
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    What happens? error message? I had both the Aux port and the USB plug hooked to 2 different phones once and when I turned on my IHeart Radio app and hit the Aux button on my radio, I got an error message. I unpluged the USB and it started working fine.
    On the same lines along with this thread. What I want to do is similar to the other guy. I want to leave the factory plug in place and tap into both USB and Aux port wires behind the dash and route them to the back side of the center console / arm rest where I want to add another factory USB / Aux plug. Along with that I also want to do the 400 watt anytime mod and while I do that I want to add the plug ins on the back side of the console too.
  20. Oct 3, 2012 at 12:07 PM
    shemp
    Definitely depends on the device, if its just pulling charging current, you'll probably be fine. If you plug in, for example, two flash memory devices, you could corrupt data, or even smoke one (or both) of them.
    If you just want to tap in for device charging, splice ONLY the power lines, not the data lines. Then there won't be any conflict.
