Moving wire for bypass mod on avic
Discussion in 'Audio & Video' started by Dallas8888, Jul 1, 2010.
  1. Jul 1, 2010 at 6:25 PM
    Dallas8888
    Dallas8888 [OP] Member
    Toronto
    2007 SR5
    4x4 Illuminated Switch, BakFlip G2, Weathertech Floor Liners
    Just thought I'd post what I discovered while trying to move the yellow wire for the bypass mod. I read many were struggling to remove the wire from the harness...me included. Simply lift the retainer(holds wires in place and runs perpendicular to the wires) on the harness. Now have the female end of the harness facing you...you'll notice a tiny hole above the slot where the yellow wire is. Insert a needle into this hole and the wire will slide out like a dream. Don't know if someone already posted it but I certainly couldnt find any easy method when searching before I started. Sorry for no pics.
  2. Jul 2, 2010 at 6:40 AM
    kramer2k
    kramer2k Well-Known Member
    Jacksonville, FL
    08 DC PreRunner TRD OR
    I think the power wires are similar for the last few generations of AVIC HUs.
    I did the bypass mod on my AVIC Z-110BT a few months ago following the AVIC forums post.
    I found the most success and easiest method was to use an eyeglasses screwdriver to pry up the little plastic retainer on the white connector. Then use a staple or something as small to press against the yellow cable pin while lifting the white connector to get the yellow cable out.
    Then re-insert in the space next for the successful mod. You'll know it seats correctly when you hear the click. Viola!
  3. Mar 14, 2012 at 10:16 AM
    XPOTRON
    XPOTRON The Game Has Changed
    Stefen
    Tucson, AZ
    2016 TRD Pro Tundra
    IG: st3f3ns #OB1235 R.I.P. Rinzler
    old thread i know but i just broke the damn yellow wire.......any suggestions where to get another one or am i screwed???
  4. Mar 14, 2012 at 10:48 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
