mp3 files on USB stick question
Discussion in 'Audio & Video' started by geronimo1958, Jul 20, 2021.
  1. Jul 20, 2021 at 11:38 AM
    geronimo1958
    geronimo1958 [OP] Member
    I have a new 2021 Tacoma TRD 4x4. I am considering loading a bunch of mp3 files on to a USB stick since my phone does not have much space for music.
    Does the system have to read all of the files (to created an index) each time I start my truck? I tested with just a couple of albums but do not want to use this method if having 100GB of music is going to cause a very slow scanning of my music each time I started the truck or unplug and reinsert the USB stick.
  2. Jul 20, 2021 at 12:37 PM
    pinktaco808
    pinktaco808 Hot Steppa
    Leave it . Fast. Shitty thing is once you start the truck it read it as one file. You can't see each file or album Individually. It stupid.
  3. Jul 25, 2021 at 9:31 PM
    Rhogur
    Rhogur Member
    Sierra Vista, Arizona
    2019 Tacoma TRD Sport DCSB 4x4 MGM
    Premium and Tech packages. Tow package. TRD Performance exhaust and air filter. Front TRD skidplate. TRD steps and tonneau. Bed mat and bed extender. Debadged and decals removed. AVS Hood protector and in-channel low profile vent visors. Custom Accessories 39245P steering wheel cover. Tinted 360°. Toyota bed light and remote lock. Leveled 2"/1" on Cooper Rugged Trek 265/65-18" (Formerly Toyo Open Country ATII 265/65x18") tires mounted on Vision 416 Se7en 18x9 6x5.5" +12mm Gunmetal/Black wheels. 1.25” hubcentric blue anodized Spidertrax wheel spacers. Rigid Ignite auxiliary back-up lights rear bumper flush-mounted with 3-way switch (On-Off-Reverse) and second switch on Meso Customs' Stealth PRO Shift knob (ECT selector relocated to shifter knob). Sensoro RX7500M radar detector hard-wired through A-pillar into under-dash cigarette lighter plug. 48" 3-color tail-light strip with sequential turn signals hard-wired into back of 7-pin towing plug. LED interior lights, reverse lights, license plate lights. TRD Pro grill with 4 smoked white Raptor lights. 32” 180w LED combo beam hidden grill light bar. Switch-Pros SP-9100 mounted on headliner; junction box on SDHQ mount; 8 gang terminal block and 6 gang grounding block. 8 RGB Rock Lights (4 corners, under 4 doors). KD Max Tune. Throttle body spacer. Anderson Engineering intake manifold spacer. Blue 10,000# Receiver tow loop. PTYYDS seat covers. Seat Jackers (Removed). PRUVEEO 360 Degree View 4 Channel Dash Cam Front and Rear Inside Left Right, Dash Camera for Cars, Built-in GPS WiFi Night Vision. Trail Grid Pro Anytime Rear Camera and Front Camera kit.
    I have a 256Gb SanDisk thumbdrive with hundreds of albums loaded. It works as well as my old iPod. You've got to get rid of all of the extraneous files and make sure the folders match artists. If you're not very organized with your data, it can be time-consuming to prepare the thumbdrive. I've heard that the stereo will only read the first so many files, but have had success using ALL of the music I loaded on the thumbdrive.
    1Crusader likes this.
  4. Jul 25, 2021 at 9:58 PM
    1Crusader
    1Crusader Well-Known Member
    2020 SR5
    I have a 32gb USB stick of music, and the system reads the data very quickly on startup, takes maybe 5 seconds tops.
    At first it didn't display the song name, but all I had to do was click on browse, then songs. After I did that the first time, it has displayed the artist, album and song that's playing every time.
    I made a separate folder for each artist, and within that folder I sorted the songs by album.
    Also, I eliminated extraneous files like Rhogur mentioned.
    Rhogur likes this.
