Mpg and offroad tires.
Discussion in '4 Cylinder' started by Tommy27, Nov 5, 2012.
  1. Nov 5, 2012 at 7:09 PM
    Tommy27
    Tommy27 [OP] Well-Known Member
    Tommy
    Boise,ID
    White 09 AC 4x4 2.7 5spd SR5
    Leer shell, Bed mat, Grill Guard
    I finally got my Tacoma and whant to upgrade from the dunflops. I reall like the look of 235/85R16 tires, and also like Duratrac's. Is this a good combo for keeping my 25mpg on the highway? How do skinny tires effect highway MPG?
  2. Nov 5, 2012 at 7:46 PM
    tubesock
    tubesock Well-Known Member
    I just upgraded my dunlop at20's to a set of 235/85 hankook ATM's. If you can wait a week or so I can give you 1 tank worth of mpg data. So far I have noticed, as have many others, that now my speedometer is reading exactly right, and my odometer is reading about 5% short. I'll factor in that difference when I calculate my mileage.
  3. Nov 5, 2012 at 7:48 PM
    Oowen
    Oowen Well-Known Member
    Owen
    Elko, NV
    '09 Offroad
    Lift Armor Badassery with a shit ton of pin stripes 18% Tint
    I am running the 235's on my rig and i am getting bad mileage. But I have a lead foot
  4. Nov 5, 2012 at 7:50 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    and a v6.
    and jeez OP... you think you like to smoke dope or what?
  5. Nov 5, 2012 at 7:51 PM
    Oowen
    Owen
    Elko, NV
    '09 Offroad
    Yes but 14 mpg:confused:
  6. Nov 5, 2012 at 7:55 PM
    650H1
    NH
    i get about 15... but i have 285's.
    and drive 30 miles one way up the interstate to work. and set cruise to 73 every day.
  7. Nov 5, 2012 at 7:56 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    That size on Tirerack is almost exclusively E load range which is heavy=mpg killer.
    51 pounds in Duratrac
    My 265-75-16 C range Duratracs are 45 pounds each.
  8. Nov 5, 2012 at 7:56 PM
    Jared
    Jared A Bad Ass Member
    Jared
    Porterville, Ca
    2011 Toyota Tacoma DCAB LBED 4WD
    Current Mods: -Viper Alarm System -Covered up seat belt buzzer -WeatherTech Floor Mats -Fog lights turn on with Bright Lights -17 inch Chrome Tacoma rims (off a 2012) -Line-x'd the front skid plate -USB charger that plays music via Mediabridge -Window Tint: Front-20%, Back-5% -Front Toyota License plate logo -2 Extra D Rings in front -Bright Reverse Light Bulbs -6,000K Head light bulb -6,000K Fog light bulb -LED Dome & MAP light bulbs -Trailer brake controller -Escort 9500 Radar Detector (hardwired) -BendMount Mirror Radar mount -C.B. Radio with a built in Mic Plug in by Aux -LED Bed lights with an extra fog light switch -30 inch LED light bar under front grill wired to an extra fog light switch
  9. Nov 5, 2012 at 7:57 PM
    650H1
    NH
    mine wiegh like 65lbs
  10. Nov 5, 2012 at 7:58 PM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    There are a lot more factors that width. You have tread pattern (rolling resistance), load rating (weight), and difference in height will affect your odo reading so you'll have to correct when figuring MPGs. Duratracs are a great tire, but not lightweight/LRR really.
  11. Nov 5, 2012 at 7:59 PM
    BuzzardsGottaEat
    Chaz
    South Dakota
    My wheel (18lbs) plus my tire (40lbs) weigh in at only 58lbs per :D
    Need it with the 22R-E though, lighter weight makes a world of a difference
  12. Nov 5, 2012 at 8:00 PM
    650H1
    NH
    yea that 65lbs is just TIRE. dont even want to think about it with the wheel. they are re-treads so i guess thats how it is. they are load range D.
  13. Nov 5, 2012 at 8:03 PM
    BuzzardsGottaEat
    Chaz
    South Dakota
    Wow, ha if they weigh in at about 25 thats 90# per tire and wider obviously = greater rolling resistance. Sounds like reason enough to Supercharge it to me :D
  14. Nov 5, 2012 at 9:05 PM
    Tommy27
    Tommy
    Boise,ID
    I do like smoking, its better than drinking everyday. I will change it now that I have a Tacoma and can put something actually worth while.
    Anyways, wouldn't a skinnier tire cut through the wind? What is the weight of the stock steelies? How about other Tacoma alloy wheels?
  15. Nov 5, 2012 at 9:08 PM
    BuzzardsGottaEat
    Chaz
    South Dakota
    Did our banter help OP? ha
  16. Nov 5, 2012 at 9:13 PM
    Tommy27
    Tommy
    Boise,ID
    Twas a little excessive, its not like im Willie Nelson.
  17. Nov 5, 2012 at 9:21 PM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    Your 285's weigh 65 lbs each?? I just looked online earlier and a 315/75/16 Goodyear MTR is 63 pounds
  18. Nov 5, 2012 at 9:24 PM
    Dustyroades
    Dustyroades Well-Known Member
    Ontario
    '09 MGM AC 4x4 SR5 2.7L 5spd
    Front Bilstein 5100s at 1.75", rear 1.5" AAL w/ TSB and OME N182s, P265/75R16 Hankook A/Ts
    Just get 265/75R16s in standard load. Essentially the same diameter as 235/85R16 and you won't lose mileage if you stick to a relatively mild all terrain. With Duratracs I'm not sure you can maintain 25mpg.
  19. Nov 5, 2012 at 9:29 PM
    Tommy27
    Tommy
    Boise,ID
    I really want the 235/85 size. I will look at my options though. Any other good weekend warrior tires that may lean more toward the mpg side?
  20. Nov 5, 2012 at 9:32 PM
    BuzzardsGottaEat
    Chaz
    South Dakota
    Cooper Discoverer AT3 come in that size at a lighter weight iirc.
