Mpg and offroad tires.
Discussion in '4 Cylinder' started by Tommy27, Nov 5, 2012.
  1. Nov 5, 2012 at 9:34 PM
    Dustyroades
    Dustyroades Well-Known Member
    Ontario
    '09 MGM AC 4x4 SR5 2.7L 5spd
    Front Bilstein 5100s at 1.75", rear 1.5" AAL w/ TSB and OME N182s, P265/75R16 Hankook A/Ts
    As someone else pointed out, tires in that size are all load range E. They are designed for HD trucks, are very heavy, and will not return good mpgs.
  2. Nov 5, 2012 at 9:38 PM
    Tommy27
    Tommy27 [OP] Well-Known Member
    Tommy
    Boise,ID
    White 09 AC 4x4 2.7 5spd SR5
    Leer shell, Bed mat, Grill Guard
    What about General Grabbers? I really want to keep my 26mpg for sure.
  3. Nov 5, 2012 at 9:48 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    according to FED EX when i got them from treadwright, they were 65 each. and my mpg went from good to suck, so i believe it.
  4. Nov 5, 2012 at 9:55 PM
    Tommy27
    Tommy
    Boise,ID
    Thanks, I was just looking at tires on Tirerack and I know they dont carry Coopers. I just found another tire to research. Anyone run the AT3s?? How are they?
  5. Nov 5, 2012 at 10:04 PM
    Dustyroades
    Ontario
    Dude... check the manufacturers' websites. I have yet to find a 235/85R16 that is not load range E (Coopers are no exception). There is a reason for this: they are made for duallies. You ain't getting 26mpg with E's.
  6. Nov 5, 2012 at 10:10 PM
    Tommy27
    Tommy
    Boise,ID
    What about with 255 85s?
  7. Nov 6, 2012 at 1:13 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Yup! This.
  8. Nov 6, 2012 at 1:38 PM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    Problem with the skinny tires, that size in particular, is you need a heavier sidewall and the 255/85 mostly come in Mud Terrains
  9. Nov 6, 2012 at 11:23 PM
    Tommy27
    Tommy
    Boise,ID
    Well what do guys think is a good compromise between mpg and light to moderate off road use? In 235 or any other size? Thanks so much
  10. Nov 7, 2012 at 12:24 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    I don't think you stand A chance to keep your MPGs with a 4 banger man. Not enough torque. You'll drop down like the rest of us. Especially if you look into M/Ts. I dropped 2-3 MPG city and 1-2 highway with my mud terrains and I have the V6. You're gonna drop even more without the torque to spin bigger tires.
  11. Nov 7, 2012 at 12:29 AM
    brian
    Elizabeth City, NC
    Have you factored in speedo error? That mileage is low as shit!
  12. Nov 7, 2012 at 3:19 AM
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    I went with P265/75R16 Michelin LTX MS2 tires. I lost roughly 1/2mpg from what I can tell from the first 10 tanks.
    I am not sure that the same tire in LT235/85R16 would have been much different since they are slightly narrower but slightly heavier.
    The MS2 is not an aggressive tread pattern, so that helps a lot.
  13. Nov 7, 2012 at 10:29 AM
    Dustyroades
    Ontario
    OP, IMO your best bet is P265/75R16 (standard load). My mileage stayed the same when I swapped to Hankook A/Ts in this size.
  14. Nov 7, 2012 at 10:52 AM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    265/75 16
    BFG KM2
    Ultra gauge says 25 "avg mpg"
  15. Nov 7, 2012 at 9:59 PM
    #35
    Tommy27
    Tommy
    Boise,ID
    Anymore suggestions? Thanks. I want to get down to 5 or less so I can narrow my search down even further. Thoughts on Coopers and General tires? Im not looking for mud tires or huge swamper tires. Im looking for something that does decent off road but retains somewhat my fuel economy.
  16. Nov 7, 2012 at 10:19 PM
    #36
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    6 spd dcsb trd offroad 4x4 Cooper 265 75 r16 stt with ome lift. City about 16 mpg. Highway at best 17.5 mpg.
  17. Nov 7, 2012 at 10:35 PM
    #37
    Tommy27
    Tommy
    Boise,ID
    Im leaning on the Cooper Discover AT3s. They seem to be good on and off road. They are 10 pounds heavier in 235 85r16 than the stock dunflops. They also review very well. Hmmmm
  18. Nov 7, 2012 at 10:36 PM
    #38
    Nixinus
    Nixinus Well-Known Member
    Sub'd
  19. Nov 8, 2012 at 4:59 AM
    #39
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    canton Ga
    06 reg cab sr5
    General lee horn mod, Bilstein 5100's and maxtrac 4 inch lift spindles. omd spring rebuild w/ s10 springs kenwood h/u and cb, warn trans4mer brush guard level 8 tracker wheels and cooper s/t 33's
    Prerunner with with bfg a/t 285/75r16= 25.7 on two lane highway at 55mph and avg 20 in town. I drive pretty slow though
  20. Nov 8, 2012 at 6:43 AM
    #40
    BuzzardsGottaEat
    Chaz
    South Dakota
    Probably your best bet for your application^
    what load rating is that weight in?
