MPG and Tire Pressure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bucc5207, Oct 11, 2014.
  1. Oct 11, 2014 at 4:19 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    In it's Shell !!!!!!
  2. Oct 11, 2014 at 4:20 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    *hare
    ... And your post failed miserably. :D
  3. Oct 11, 2014 at 4:30 PM
    RND2
    RND2 Well-Known Member
    In my head swimming around
    12 DCSB
    RCD 4"
    You payed attention so that makes you the smart one.
  4. Oct 11, 2014 at 4:32 PM
    File IFR
    Central MA
    *paid
    I'm turning into a grammar cop like OZ. :D
  5. Oct 11, 2014 at 7:22 PM
    millsra13
    millsra13 Member
    San Diego, CA
    2021 TRDOR 4x4 6MT
    File IFR
    You are correct in that the ECU will compensate for thinner air by leaning out the fuel mixture to maintain a constant Stoichiometric balance, but what you are not accounting for is that you will be way down on power therefore you will need more fuel AND air to maintain the same speed as you would at sea level. If you run performance charts on ANY airplane you will see that FTC (fuel to climb) increases dramatically the higher your takeoff elevation is. That applies to turbine and Otto cycle engines.
  6. Oct 11, 2014 at 8:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I run 32 psi in my tires at all times if possible.
    I get worse gas mileage in the mountain.
    But I attribute it to the many incline I climb more than to the
    air density.
    But most likely it's due to using 4th gear. Over Drive shifts too much
    so I drop it to 4 and roll on.
  7. Oct 11, 2014 at 9:08 PM
    Yota64
    Yota64 Professional Threadjacker
    I'm in SE texas and run 47/45. Get pretty awesome mpg. The best thing to do is run a chalk test.
  8. Oct 12, 2014 at 8:18 AM
    Bucc5207
    Bucc5207 [OP] Well-Known Member
    Yrisarri, NM
    2014 V6 SR5 4x4
    Yep, uphill you mash the gas to get going, and as soon as you back off the OD kicks in and you slow down. Mash the gas again and drop out of OD. Repeat. Or, you disable the OD which also has disadvantages.
    Downhill is like freefall and you have to use your brakes too much.
    Why I always buy manual transmissions.
  9. Oct 12, 2014 at 9:23 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    You've summoned the OZ... He'll find you. Sneaky Canadians.
  10. Oct 12, 2014 at 9:56 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    My experience has been the opposite - better mpg in the mountains, but probably a combination of factors - driving slower up hill, less a/c use, manual transmission, phase of the moon - who knows. But, on road trips, with a properly calibrated scangauge, I get about 15% better mpg (from 20 to 23) with my current truck, and similar increase with my previous truck.
  11. Oct 12, 2014 at 7:50 PM
    TnShooter
    Deogee
    STOCK
    I don't slow down in the mountains. I've seen them enough. I live in the foothill of the Smokey Mountains.
    I maintain the speed limit and get to where I'm going.
    Most of my travel is in 4th gear. I'd say at least 85% of it.
  12. Oct 13, 2014 at 2:23 AM
    File IFR
    Central MA
    "Way down on power"? What do you mean.... considerable, extreme, dramatic?
    A little? sure, but "way down"? Do you have any numbers to back it up instead of adjectives?
    Not applicable here, sorry.
  13. Oct 13, 2014 at 5:26 AM
    Spindifferent
    Spindifferent Well-Known Member
    Central Texas
    2013 PreRunner 4.0 v6
  14. Oct 13, 2014 at 5:29 AM
    Ma Deuce
    Ma Deuce Well-Known Member
    Joe
    Colorado
    Let me throw some numbers at you. 03! 24! 13!
    Seriously though, it's a few percent for every thousand feet of elevation. My Tacoma is probably about 35-45 HP lower here in CO than it would be at sea level. Not a huge deal. My mustang though is rocking about 150 hp lower here :mad:
    As far as gas mileage is concerned, it's mostly a wash. If I had to pick one, I would say that the higher elevation gives you slightly better gas mileage.
  15. Oct 13, 2014 at 6:01 AM
    #35
    millsra13
    millsra13 Member
    San Diego, CA
    2021 TRDOR 4x4 6MT
    Do I have numbers to back it up? Sure, I'll do a simple google search -
    http://www.examiner.com/article/elevation-and-the-combustion-engine
    A general rule of thumb is 3% power loss per 1,000 feet
    If you are going from New Orleans to let's say Colorado, that's roughly 6,000 feet. That is a 18% power loss or 42.48 horsepower loss for the 4.0L Taco. I'd say that is way down...or "considerable, extreme, and dramatic".
    One thing I will add is that because the air is less dense at altitude you also have less drag. As long as you don't work the engine any harder to compensate for lack of power you CAN increase your fuel mileage due to less air resistance.
    What do you mean not applicable here?
  16. Oct 13, 2014 at 2:13 PM
    #36
    File IFR
    Central MA
    There is no need to add that..... I've known that for a very long time. ;)
  17. Oct 13, 2014 at 4:49 PM
    #37
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    Air current direction can make a big difference also.
