MPG display difference?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Josh-L, Dec 22, 2020.
  1. Dec 22, 2020 at 12:12 PM
    Josh-L
    Josh-L [OP] Well-Known Member
    2021 Silver SR DCSB V6 4x4
    I keep the “latest” mpg on my radio screen and then there’s the one on the center gauge cluster if you push the down arrow. That one says 23.6 but the latest one says 20.4. What’s the difference?
  2. Dec 22, 2020 at 12:14 PM
    Tacospike
    Two Trucks
    My calculator says 3.2 is the difference
  3. Dec 22, 2020 at 12:18 PM
    Josh-L
    Boom Roasted! lol
    I mean why are they different
  4. Dec 22, 2020 at 12:19 PM
    Tacospike
    Two Trucks
    I'm not sure? I usually go off the center gauge cluster though
    Junkhead likes this.
  5. Dec 22, 2020 at 12:22 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    The dashboard average is a tank average, and resets after every fill up.
    hiPSI, Junkhead, shakerhood and 3 others like this.
  6. Dec 22, 2020 at 12:24 PM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    The one on the touch screen (Unless you reset it) gives your overall MPG since Day One ... The one on the center of the dash ('A' screen, I think it's called?) resets itself every time you fill up the tank and gives you MPG for THAT particular fill up.
    Junkhead and Josh-L[OP] like this.
  7. Dec 22, 2020 at 12:26 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    A better question is, how do you know if either number is accurate? :stirthepot: The truck doesn't have a flowmeter in the fuel system, so it's going off injector timing (which injects picoliters per combustion cycle, a few thousand times per minute). A high degree of error can accumulate that way.
  8. Dec 22, 2020 at 12:27 PM
    Josh-L
    Now why you gotta go and complicate things
  9. Dec 22, 2020 at 12:28 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Next anxiety item for you: why are the digital and dial speedometer readings slightly different? :devil:
    Chako, Junkhead and shakerhood like this.
  10. Dec 22, 2020 at 12:31 PM
    Josh-L
    And now I’m calling my therapist...
  11. Dec 22, 2020 at 12:34 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    I came up with the same answer. Math can be tricky.
    4drtaco03, Yota_TRD4x4, hiPSI and 3 others like this.
  12. Dec 22, 2020 at 12:36 PM
    Tacospike
    Two Trucks
  13. Dec 22, 2020 at 12:37 PM
    BMH
    Bruce
    Keep in mind though ... The MPG on the dash screen, is not entirely accurate as to actual MPG.
    I say this because .. Where I live and cold, cold COLD ... I'll start the truck up and let it idle for 15-20 minutes with the heater going, because I wanna get into a nice warm cab. So, your rig is using fuel .. Without any actual miles being put on it.
    So, keep that in mind if you look at the screen and say 'WTF?? Why is my MPG so crappy??' ;)
    MadKatt and Junkhead like this.
  14. Dec 22, 2020 at 12:41 PM
    BMH
    Bruce
    LOL!
    I was pretty good at math once... Then they threw this thing called 'Algebra' at me in the 9th grade. I decided I had enough of that shit...
    Kev250R likes this.
  15. Dec 22, 2020 at 12:44 PM
    Mr.Hustler
    Mr.Hustler Well-Known Member
    2018 Magnetic Grey Metallic TRD Off Road 4x4 [AT]
    It's a secret
    It's possible one is showing numbers for Trip Average, and the other Tank Average.
  16. Dec 22, 2020 at 12:54 PM
    BMH
    Bruce
    LOL!!! No shit right? LOL!
    I used to just Fill The Tank To the Top for about 3 times in a row ... Record the mileage between fill ups ... And let a $5.00 Casio figure out (Basically) what my average MPG was ...
  17. Dec 22, 2020 at 12:55 PM
    Punkface
    Punkface Well-Known Member
    Colorado
    2020 Tacoma TRD Off-Road DCSB 4x4
    You're getting over 20 mpg?
    Emeryk13 likes this.
  18. Dec 22, 2020 at 1:05 PM
    dcat151
    dcat151 Active Member
    2020 Tacoma Off Road MT
    On my truck, I find that the tank average reading is about 0.75 higher than what I'm actually getting. It's not too far off, but isn't perfect.
  19. Dec 22, 2020 at 1:12 PM
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    The one on the radio screen keeps a running total until you hit update. The one behind the steering wheel resets automatically when it detects more gas has been put in. So if you don't manually hit update on the radio one, before pulling away from the pump, they will be different.
    Josh-L[OP], shakerhood and BMH like this.
  20. Dec 22, 2020 at 1:35 PM
    BMH
    Bruce
    And there ya go.:thumbsup:
