Mpg drop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCtaco13, Apr 29, 2018.
  1. Apr 29, 2018 at 5:05 PM
    NCtaco13
    NCtaco13 [OP] Well-Known Member
    North Carolina
    2013 Gray DCSB 4x4 V6
    Over the last two tanks of gas I've run through, my mpg has been about 16.5 for both of them when before I was constantly getting 19.5 to 20.5 mph. I feel like that is a significant drop and I haven't done anything out of the ordinary. I last checked my mpg a few months ago when I was running different octane gas through it to see what I got.
    I don't drive insanely fast (reckless driving ticket slowed me down but even when I did my mpg was higher) I drive on mostly flat land and use cruise control when I can. I usually stick to highway driving so very little stop and go city traffic. I don't tow or use 4x4 often (mainly driving to and from work and driving around in rural areas). No lift kit or aftermarket bumpers or anything, just a stock truck
    I've done all regular maintenance, tire rotation, oil changes, spark plugs, recent transmission flush, greasing drive shafts, differential, air filters, and t-case oils. I don't put any additives in any oils or gas I use. The only thing I have is an oil catch can but I've had that since last September and hasn't affected mpg that I saw after putting it in.
    Just wondering if there's any common issue with these trucks that would cause that or if there's something certain I should look into. I'll keep an eye on my mpg to see if anything changes
  2. Apr 29, 2018 at 5:34 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Is the cel on?
  3. Apr 29, 2018 at 5:37 PM
    NCtaco13
    North Carolina
    Nope no cel or any lights flashing
  4. Apr 29, 2018 at 5:37 PM
    MMoreno16
    MMoreno16 Cupcake Forest Ranger
    Los Angeles
    2018 TRD OR DCSB
    :facepalm:
    Comatose likes this.
  5. Apr 29, 2018 at 8:43 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Checked tire pressure during the last 2 tanks?
  6. Apr 30, 2018 at 12:12 AM
    NCtaco13
    North Carolina
    Checked it yesterday 3 were at 30 and one was at 32, I keep them at 30 based on the door sticker
    I let the one down to 30
  7. Apr 30, 2018 at 1:47 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Just throwing this out there, don't know if it has anything to do with what you're seeing, but 70 mph on the highway seems to be the tipping point for these trucks. Go over that, and the mileage takes a nose dive.
    Hobbs, Justbrian, Toy4me and 2 others like this.
  8. Apr 30, 2018 at 2:44 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Speeding. Pay attention to the road, not your phone.
    It's the American way. Go 85 mph. Complain about gas mileage.
    Who's noticed the massive about front end bumper humper collisions? 90% of wrecked cars I see, have smashed front ends, lolz. Auto body shops are making a killing.
  9. Apr 30, 2018 at 3:05 AM
    NCtaco13
    North Carolina
    Well damn most of my drive to work the speed limit is 70 so if course I'm going a few miles over that I just didn't think it would impact the mpg that much though but if that's what it is I guess I'll just have to deal with it
  10. Apr 30, 2018 at 4:16 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    70 is the breaking point for mine also 65 avg 18, 70+ right at 15.5-16.
    Yukon and Alexely999 like this.
  11. Apr 30, 2018 at 4:30 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Drive no faster than 70 and put a little more air in the tires. With P series tires on my Tacoma I ran about 35 PSI. Last set I bought are E rated LT series and I keep them at about 40 PSI.
    Driving into a headwind will hurt you to. I did a cross country road trip 2 years ago and averaged right at 20 mpg over about 5000 miles. Some tanks were in the 22-23 mpg range. Some in the upper teens. But on the way home I hit a steady headwind from Denver to Kansas City. I still kept the same speed, ~ 70mph, but my fuel mileage on that stretch was in the 16's.
    BlkDakDave and MattCowsmasher like this.
  12. Apr 30, 2018 at 4:59 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Consistent highway driving under 70 mph gets me 21+ mpg. I do a lot of 60mph-65mph. Go over 70 and it drops as stated above.
    MattCowsmasher likes this.
  13. Apr 30, 2018 at 5:28 AM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    Not saying this is your problem... my wife's car started getting bad gas mileage.
    I found the vacuum hose for the brake booster was loose. The hose would easily slide off even with the clamp on. I replaced the clamp and the gas mileage was back up.
  14. Apr 30, 2018 at 5:33 AM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    Keep the rpm under 2k. Are you lifted? If so, how much?
  15. Apr 30, 2018 at 6:53 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Lift wheels and check for brake drag
    bad alignment can affect MPG
    MAF sensor can do weird things when dirty
    MadDaddy likes this.
  16. Apr 30, 2018 at 7:03 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Also could be a 02 sensor on its way out just a thought.
  17. Apr 30, 2018 at 7:09 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    If I go above 65 I’m already assuming I’ll have lower mpgs. I got 18.5-ish on an all freeway trip recently!!! Lol
  18. Apr 30, 2018 at 9:08 AM
    hunter991
    hunter991 Member
    c
    tahoe
    Check your brakes. I had a caliper stuck, couldn't tell until it wore out the pad on my car. Mileage jumped back up once i did the brakes and fixed the issue. Saw a 3 mpg decrease. I just thought it was the colder weather.
  19. Apr 30, 2018 at 9:48 AM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    I agree 100% with the over 70mph mileage tipping point, but since the op's problem happened so quickly I'm inclined to believe that something mechanical went wrong.
  20. Apr 30, 2018 at 4:31 PM
    NCtaco13
    North Carolina
    Thanks for all the suggestions everyone I'll look into them and see what I find. How can I tell if a caliper is stuck? I just rotated my tires 2days ago and when I checked the brakes on both sides the pads were pressed against the rotors on both sides. Drum brakes looked fine, I cracked the drum open and cleaned it out nothing looked abnormal back there
