mpg help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MROBERTS, Mar 23, 2011.
  1. Mar 23, 2011 at 7:58 PM
    MROBERTS
    MROBERTS [OP] Active Member
    Stevenson AL
    06 PreRunner SR5
    10000k hids, horn relcation, and more
    what is the best mods to help me squeeze out some better mpgs?
  2. Mar 23, 2011 at 8:02 PM
    Kingfrog
    Kingfrog Well-Known Member
    08 TRD Rugged Trail Edition
    Undercover,Pop n Lock, Hardwired GPS, Garage door opener , Scanguage II, wireless back up camera, X994 Basslink, ...Prefer stock and non invasive functional mods
    ^^^^^^ Brilliant....
    There's a TSB for that.....
  3. Mar 23, 2011 at 8:03 PM
    MROBERTS
    Stevenson AL
    06 PreRunner SR5
    not possible i have to get where i need to get when i need to get there
  4. Mar 23, 2011 at 8:03 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Just keep your air filter changed and your oil changed...thats about it...maybe get a AFE Drop in filter
  5. Mar 23, 2011 at 8:05 PM
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    i like to go fast... but i've found that quickly accelerating off stoplights and such really makes absolutely no differenc in time to get places... so just don't accelerate qucikly, you'll get where you're going at the same time.... let the taco cruise...
  6. Mar 23, 2011 at 8:07 PM
    MROBERTS
    Stevenson AL
    06 PreRunner SR5
    i have a k&n drop in already and stock exhaust gas is almost $4 in alabama and its killing me i put $60 in my truck yesterday drove home back to school back home and used over 1/4 of a tank
  7. Mar 23, 2011 at 8:10 PM
    MROBERTS
    Stevenson AL
    06 PreRunner SR5
    college is to expensive to have two cars and there is NO WAY i am selling my taco
  8. Mar 23, 2011 at 8:12 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    well about all of your options have been listed lol
    1. Change oil on the regular
    2. Change air filter on the regular
    3. Exhaust
    4. CAI
    The last two will give minimal, if any results ;)
  9. Mar 23, 2011 at 8:13 PM
    Kingfrog
  10. Mar 23, 2011 at 8:13 PM
    MROBERTS
    Stevenson AL
    06 PreRunner SR5
    i really dont drive fast usually five or so over the limit......could my wheels and tire hurt my mpgs ......could a bed cover help?
  11. Mar 23, 2011 at 8:14 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    the bigger and more aggressive the tire...the worse your MPG will be
  12. Mar 23, 2011 at 8:15 PM
    MROBERTS
    Stevenson AL
    06 PreRunner SR5
    they are not aggressive just heavy
  13. Mar 23, 2011 at 8:18 PM
    MROBERTS
    Stevenson AL
    06 PreRunner SR5
    i dont really pay attention to it......could a tonneau cover help
  14. Mar 23, 2011 at 8:24 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    IF you are close to needing new tires, shop for a highway tread or all season tread. look at a lighter tire too. You'll do ok in dry dirt and gravel, but you wont really want to try offroading.youll gain 1 mpg perhaps over an AT tire.Also not worth the money unless you do a lot of pavement miles.
    Other things , keep the psi up , coast to red lights the best you can ...WITHIN reason , lighten up a bit on the throttle , keep weight out , at next fluid change go synthetic. Lastly a tonneau cover can help or a cheap mod can be had with 1/4" plywood and the ol plastidip to cover it , bolt to the cleats or such.
  15. Mar 23, 2011 at 8:31 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    For best MPG you need lots of stickers, stick on vents, and truck balls. Add all this up and it will give you 5-8 mpg better. Also are you in RDA mode. This makes the engine get much better mpg. When you get in turn the key to "on", roll down all windows, turn on radio to CD. Make sure you have a CD with Rebecca Black---Friday on it. Then crank it to 50 power and watch as everyone stares at your super economical car. As long as you drive like this you will get excellent mpg.
