MPG improvements?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Devo4x4, Nov 28, 2022.
  1. Nov 28, 2022 at 11:03 AM
    Devo4x4
    Devo4x4 [OP] Member
    Parker
    2006 Tacoma SR5 V6
    3” ToyTech Lift 33” BFgoodrich A/Ts MBRP exhaust Upgraded front brakes Prinsu Roof Rack TRD style Grill Spyder Headlights Cali Raised Pod lights Etc etc
    Hey all. I’ve got an 06 Tacoma, 3” toytec lift on 33s (aired up to 35 btw). Engine is stock, I do have an MBRP exhaust tho. My MPGs are around 12.5-13.5 tank avg (highway/city mixed). Gonna say this before, I don’t drive aggressively, I keep RPMs under 2k as much as possible, use cruise on hwy. I’ve seen people on here claim 17+ mpgs in lifted 2nd gens, what sort of mods/maintenance/etc should I do to get there? thanks.
    MarX and My4thTacoma like this.
  2. Nov 28, 2022 at 11:05 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Keep current on maintenance items, don't use cruise control and keep it under 70 mph.
    /one and done.
  3. Nov 28, 2022 at 11:32 AM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    tbh your best bet to regain some mileage will be changing to a smaller/lighter tire and removing the lift. You could try getting the MAF cleaned/air filter removed which might lead to slightly better mileage, or you could regear, but 12.5-13.5 is about right. I'm on a 3" King lift, with 33" E rated tires, as well as a decent amount of armor and other stuff. But the biggest MPG drop I saw was when i installed the lift and changed the tires...all the other extra weight only made a 1MPG difference or so.
    MarX likes this.
  4. Nov 28, 2022 at 11:47 AM
    SpruceWillis
    SpruceWillis Active Member
    2014 Tacoma spruce mica
    I'm going to try hard to not make this sound like an advertisement, but I highly suggest looking into a Sprint booster throttle controller for several reasons.
    I have been working in automotive electronics design my whole life and have dyno tuned, flash tuned ecus, built ecu dataloggers from scratch, did design work for the big 3, etc. the Sprint booster is one of the best automotive plug and play products I've seen in my life. However, doing some research online, they are very polarized and mixed reviews, after getting mine, I couldn't figure out at first why some people hated them and some loved them.
    A friend of mine sells them in his store and talked me into it, which is the only reason I considered it. Being very familiar with (more old school) ECU tuning, when i first saw the sprint booster, I thought BS, that's not going to work or do anything. However i am more familiar with cable throttle body and not drive by wire at the time. now newer cars are all drive by wire, the throttle bodies are electronically controlled. You can get a complete stand alone ECU, tuned, custom turbo charge your engine, change everything, if you still have that OEM throttle body and pedal, it will always be the same. The performance of the Throttle body never changes. The ECU has no idea that it is even there, it only gets TPS signal coming back.
    So if you were to slam your gas pedal down all the way, there's an accelerometer circuit inside the pedal assembly that senses that rate of change, deadens it out, and opens the throttle very slowly and controlled. The majority of this functionality, IMO, is for saftey, and some for longevity. Imagine our truck engines, lets say 200hp/200 lb ft, thats comparable to a lot of muscle cars decades earlier. Those type of cars not every grandma can get in and hit the gas 1/4 throttle, without slipping all over the place or crashing. Its a lot of power, but by today's standards its average. With the drive by wire, anyone can drive these vehicles, especially a truck with a light end.
    Now one thing you are interested in is MPG, and most people do not get a throttle controller for MPG. I learned that MPG can actually be increased with this. Take the 2nd gen Tacoma for example, hit your throttle 0 to 75%, i mean slap it back and fourth. it almost does nothing. imagine being on the highway, curising 65 mph, you want to overtake a slower vehicle in front of you, you merge over one, and accelrate to pass. With the stock throttle setup, that 0-75% is doing nothing, you try to go to 50% and it doesnt give it enough to pass, so what happens is you end up going to that 75% or whatever (im using arbitraty numbers but you get the point). once you get past that 75%, now its too much, the engine revs, the transmission kicks down, and you just used way more gas to do this simple task of passing someone on the highway. Now with the Sprint Booster, depending on how aggresive of a setting you are using, you can push the pedal not even 1/10th, and instead of kicking down and revving out, it just gives a little. vrrrrrrrrrrr, and you are accelerating enough to pass the car, without downshifting or anything like that.
    When im towing a trailer, all of the things i described are now exacerbated greatly, that's when you can really feel the thing working in your MPG benefit. Now me personally i drive very heavy, and this thing is not going to save me MPG because on a daily because I have it in 1:1 race mode all the time. When I'm careful on long road trips it does help. but your driving style will be the most influencing factor. Another customer at the shop mentioned his MPG increasing greatly, and he was the type of guy that drove carefully and tried to conserve gas.
    I recommend trying one, because they have a no bs 30 day trial period, it installs in 5 minutes. if you don't like it, send it back.
    Now for an example where it doesn't work. A friend of mine got an F-150 ecoboost. those thigns make tons of torque, twin turbo, all that. He wants to start tuning it up, so i recommend for him to buy one. He installs it and says it does nothing, i go drive his car to confirm, hes right, its very minimal difference. I called the vendor that sold it, he recommended putting it in manual transmission mode instead of Automatic to give it more sensitivity. We tried a bunch of stuff and it didnt work. Driving his truck though, i realized that compared to our trucks, his gas pedal actually works after 15-20%, its already a very sensitive pedal and very torqy engine. So that explained to me why some people do not like this thing and some do. He was able to return it no hassle, however he ended up getting one for his nissan Z instead where it made more of a difference.
    I know there are several brands of this, i am more attracted to the sprint booster one as they have the original patent on it, but dont seem to be enforcing it in the US as they are a Greek company.
    As for other MPG factors, i can only suggest the obvious, but there is not going to be anything that is a major game changer.
    Tire pressure (actually tune it if you really want to dial in your MPG).
    take off cap, or heavy tool box or extra weight.
    air filter, general Maintenace, scan engine for MIL's.
    check for brakes dragging
    tire balance
    alignment
    A friend of mine lifted his truck, but left stock wheels on for a couple weeks until his wheels came in. he said there was no difference in MPG with the lift, his previous theory was that the aerodynamics would affect it a lot at the higher ride height. once he put the heavy 33's and wheels though, that's where the loss started. with that said I don't think air dams or anything would help much with something that already sits too high off the ground compared to a car.
    cloudbnd likes this.
  5. Nov 28, 2022 at 11:50 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    lift and tires are not doing you any good what so ever. You will never get good MPGs with that especially if they are LT e rated
    MarX, Raylo, b_r_o and 1 other person like this.
  6. Nov 28, 2022 at 11:57 AM
    saint277
    saint277 Vigilo Confido
    Best way to improve mpgs is to go back to stock. Going up in tire size effectively reduces the gearing advantage of the engine and trans meaning it needs to work harder to go the same distance. Another option is to get new gears in the diffs to try to get back to a stock ratio.
    MarX and Raylo like this.
  7. Nov 28, 2022 at 11:59 AM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Take secondary highways and get a second set of P rated 245's on alloy rims.
    How heavy are your wheels (rims and tires)? Unsprung weight is a mileage and acceleration killer.
    Past 55mph, air resistance/drag becomes multiplied. You'll get near 40% more fuel consumption at 75 vs. 55mph.
    MarX likes this.
  8. Nov 28, 2022 at 12:04 PM
    nd4spdbh
    SoCal
    If you truly have "been working in automotive electronics design my whole life" you should understand the simple analog circuit of the throttle pedal on our trucks and how it connects to the ecu, is literally two analog rotational hall effect sensors, 1 for main and the other as a reference. Being a plug and play inline product to that simple analog circuit you would understand that the spirit booster does nothing more than simulate one pushing down on the throttle pedal more (sport modes) or less (eco modes) than they actually are. It DOES NOTHING and CAN NOT DO ANYTHING to change the mapping of the throttle pedal to the throttle blade in the engine bay.
    It, does not and can not reduce the "lag" between the throttle pedal and throttle blade, and in fact there is less than the blink of an eye delay from pushing on the throttle pedal to the throttle blade opening (even fully to the floor and wide open at the throttle blade). THE ONLY TIME the ecu EVER deviates from the requested throttle blade angle as set out in the ECU's map is if traction control needs to step in due to wheel slip, or in the case of gear based limited throttle blade angles (which only applies to stock toyota TRD supercharge tunes).
  9. Nov 28, 2022 at 2:30 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Buy a Honda accord, you're driving a truck . . .
    DARBADARBZ and Steves104x4 like this.
  10. Nov 28, 2022 at 2:33 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I get 16-17 mpg mixed driving with my 07 4X4 DC. On the road 18-19 mpg and on good days 20. No lift, but I do have a mildly aggressive 265/75/16" tire which is just under 32".
    Wider tires hurt mpg worse than skinny tires in the same height. Tires with aggressive mud tread will cost you 2-3 mpg compared to a less aggressive AT tire even in the same size and load rating. The lift is causing more wind resistance. I'd say with all of that you're about where you should be.
    MarX likes this.
  11. Nov 28, 2022 at 2:38 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Regearing would help get your to closer to stock ratios for some MPG improvement, but the best you could do is get rid of the taller + heavier 33s, lower it back to stock, and if your truck had/has an air dam up under the chin, make sure to use it/keep it.
    MarX likes this.
  12. Nov 28, 2022 at 2:57 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  13. Nov 28, 2022 at 3:49 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Lol that’s me. Truck for fun and going out.
    2015 accord for commutes to work and stores. Average of 30-31 on the accord
    MarX likes this.
  14. Nov 28, 2022 at 5:39 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    That's about where I've been ever since the LTs went on
    MarX likes this.
  15. Nov 28, 2022 at 6:21 PM
    pahaf
    paul
    NorCal
    I also noticed that every truck is different. Some get better mpg. Some get worse.
    Im lifted 1.5-2” on 265-70-17 and get 15-16mpg. Meanwhile other people get 17mpg with the same set up. Im on top of all maintenance and have perfect alignment and perfect tire psi.
    then there are people who run 33” tires. Some get 13mpg. Some get 16mpg.
    MarX likes this.
  16. Nov 28, 2022 at 6:27 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C’d DCLB TRD SPORT
    Try 35’s with a steel bumper. :anonymous:
    I’ve only put 5000km since March of this year lol!
    MarX likes this.
  17. Nov 28, 2022 at 6:47 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Carry less weight, decrease rolling resistance, max 70mph on the interstate. Simple as that; how you get there is your decision.
  18. Nov 28, 2022 at 7:02 PM
    Taco y mas
    Taco y mas Well-Known Member
    SoCal
    Tacoma TRD Sport
    None
    Extend front air dam down to within five inches of the ground.
    YF_Ryan likes this.
  19. Nov 28, 2022 at 7:06 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    Remove the lift, go back to stock tires.
    Or get a Prius.
    With all those mods, can you really expect more mpg’s?
  20. Nov 28, 2022 at 7:08 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Cruise control is perfectly fine to use, provided you're on relatively flat ground or very gradual slopes.
    wi_taco, mray and JGO like this.
