Mpg increase and not caring about pay back
Discussion in 'Performance and Tuning' started by PFD279, Apr 2, 2013.
  1. Apr 2, 2013 at 2:18 PM
    PFD279
    PFD279 [OP] Member
    Portland, Me
    Lets say I wanted to increase my mpg at any cost and making the money back wasnt a concern. No matter how small the increment, what DEFINITELY, w/o a doubt, proven, improves milage?
  2. Apr 2, 2013 at 2:21 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    D4D swap :cool:
    Costs about $20k through dieseltoyz so it will never pay itself off.
    More realistic, just keep your driving habits in check and enjoy better MPG's as a result.
  3. Apr 2, 2013 at 2:21 PM
    169.254.255.201 Well-Known Member
    Interwebs
    Not sure quite why you would want to do this..
    Tonneau cover, I have heard a electric fan helps.. and if you really reallly want to spend money, i have heard a supercharger.
    And tires. Just get some of those no tread tires. :)
  4. Apr 2, 2013 at 2:28 PM
    theredofshaw
    theredofshaw Well-Known Member
    Reno, NV
    2016 Honda Civic (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    buy a prius.
    you are driving a 3-4K brick...
  5. Apr 2, 2013 at 5:26 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    05 prerunner trd off road DC
    Red hot glass pack muffler dumped preaxle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front and modified zuk mod coil spring lift for about 2" in rear paired with 5100 also. C channel front bumper. Maxxis bighorn 255/85/16
    Two-speed rear end like some 3.23 and 4.88 lowsfor city high for hwy. Easier on Ur motor in city and higher gears obviously on hwy if it will still turn the wheels.
  6. Apr 2, 2013 at 7:04 PM
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    a mast and a sail...
  7. Apr 2, 2013 at 8:05 PM
    MaxQ
    MaxQ Active Member
    Southern California
    '13 PreRunner SR5 4x2 with exaust tip.
    Don't forget to tack between lanes. LOL
  8. Apr 2, 2013 at 8:22 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    1 Low roll friction tires,perhaps narrower even, with some light rims... you get to research the lightest.
    2 synthetic diff, trans(if manual), motor oil, and xfer case
    3 delete side mirrors, get some slick aero camera mod. (write this one up for us please).
    4 gear swap ... down to 3,08, but that might get you banned here hehe.
    5 the header guys often say they get more mpg.
    6 the rest is mostly free, try adding tire psi ... to a point, shift below 2000 rpm if reasonable (manual), try to coast to lights .... if reasonable,
    Tires and the synthetics are reasonable at some point. I think I got .5 -1 mpg on synthetics, but its real hard to truly measure accurately due to variables.
  9. Apr 2, 2013 at 8:29 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    WeatherTechs, Console Vault, OEM Bed Mat, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, Exterior Cargo Net, OEM Toyota Cargo Divider, Cobra CDR 840 Dash Cam, Sliding Rear Window Security Bar, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Full Debadge except TRD OEM Red Tailgate Badge, Undercover SE Tonneau
    Make sure you have a good, clean air filter.
    Don't carry around any unnecessary weight.
    Over-inflate your tires by about 1 psi or maybe 2 psi max.
    Really good synthetic motor oil.
  10. Apr 2, 2013 at 9:34 PM
    Interwebs
    If you really want to save on gas (for your truck) hire a tow truck to tow you around.:D:D
    Sorry. Had to. ;)
  11. Apr 2, 2013 at 9:42 PM
    scocar
    scocar Purity of essence
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks groaning under boxes of mods to be
  12. Apr 2, 2013 at 9:47 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Lower truck as low as possible.
  13. Apr 3, 2013 at 5:50 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    First thing you need to tell us is what kind of driving are you opimizing for? Changes that may help on the highway, may detract in city, and vice-versa.
  14. Apr 3, 2013 at 5:55 AM
    Large
    Large Red
    Ehhh, my tanks without the S/c were consistently 15-17 mpg.. my first tank with boost was 12 and my driving habits didn't change. If I get around to it I will chime back in here with some updated MPGs.
  15. Apr 3, 2013 at 6:56 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    Increase your tire pressure.
  16. Apr 3, 2013 at 8:02 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Harbor Freight 110v welder garage fab parts.
    Regulate your right foot....
  17. Apr 3, 2013 at 8:09 AM
    jshsltr
    jshsltr Well-Known Member
    Josh
    St Louis
    Cut hole in floor boards. Wear thick shoes.;)
  18. Apr 3, 2013 at 8:11 AM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    '14 Ford F150_Ecoboost
    Take a poo before driving.
