MPG Issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpadeGlider, Jan 10, 2020.
  1. Jan 10, 2020 at 12:39 AM
    SpadeGlider
    SpadeGlider [OP] Member
    Jose
    2020 grey 4x4 off road TRD
    Non... YET
    I got a new Tacoma, 2020 off road trd ... had the 2019 sr5 and it gave me good MPG around 18-22MPG when I would use cruise control so I’m accustom to using my cruise control so I’ve been using it for about a week now (the 2020 Tacoma) and I’m getting HORRIBLE MPG I’m getting 12-14MPG... even when I cruise at 65-75MPH has anyone had this issue?
  2. Jan 10, 2020 at 12:44 AM
    WhiteTruckMafia
    WhiteTruckMafia Well-Known Member
    TN
    19 TRD PRO
    First off....... You shouldn’t be using cruise control with a brand new motor. Have you not ever bought a new vehicle before ?
    Tainted likes this.
  3. Jan 10, 2020 at 12:45 AM
    SpadeGlider
    Jose
    Non... YET
    Yeah.. like I said my friend I had a 2019 SR5 right out the box.. What’s the issue with using cruise control? Never thought it would be bad?
    WhiteTruckMafia likes this.
  4. Jan 10, 2020 at 12:47 AM
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    Is it brand new?
    SpadeGlider[OP] likes this.
  5. Jan 10, 2020 at 12:48 AM
    SpadeGlider
    Jose
    Non... YET
    Yeah brand new out the dealer both the 2019 and the 2020
  6. Jan 10, 2020 at 12:49 AM
    socalexpeditions
    Give it 1,000 miles then report back. And don't use cruise control - You should be varying speeds and rpm's for the first 500 (more towards 1000) miles.
  7. Jan 10, 2020 at 12:50 AM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    The issue is that it’s brand new..
  8. Jan 10, 2020 at 12:51 AM
    SpadeGlider
    Jose
    Non... YET
    Can you elaborate on varying speeds? Please
  9. Jan 10, 2020 at 12:52 AM
    WhiteTruckMafia
    TN
    19 TRD PRO
    You shouldn’t keep a constant speed for long periods during the motors break in period. Be fairly easy on it and try to vary your speeds when driving. You want everything to wear in evenly and for your rings to set in good etc etc. I used to put my brand new race bike on a dyno and set the rings / break it in with 30 minutes of my time and never have an issue......... But that’s a whole other level of gear head talk. Just read your owners manual man. Break in according to Toyota is the first 1k miles and it tells you in the owners manual what to do and what not to do.
    :thumbsup:
  10. Jan 10, 2020 at 12:54 AM
    socalexpeditions
    I just re-geared my truck to 4.88 gears.
    The break-in procedure for the gears is to drive 50 miles at a time for the first 500 and then change the diff fluid. Now, you don't have to do this part. However, the first 500-1,000 miles, you should drive on the freeway at various speeds. For instance, if you're doing 10 miles on the freeway, do 5 of those miles at 65mph, and 5 at 70mph.
    It's not mandatory at all, but it just helps break in the engine, driveline, etc. Keep it slow off the line, don't rev it high, etc.
  11. Jan 10, 2020 at 12:57 AM
    SpadeGlider
    Jose
    Non... YET
    Aaaaaa thank you so much I didn’t know that to be honest I really appreciate the help guys!!! Learned a lot! Will follow instructions and I’ll keep you updated :yay:
  12. Jan 10, 2020 at 12:58 AM
    socalexpeditions
    It'll get better over time. Also, most (if not all) fuel stations right now are using winter blend gasoline. Every car I've ever owned gets worse gas mileage in the winter due to the blend vs. the summer. I notice at least 1mpg difference.
  13. Jan 10, 2020 at 1:01 AM
    WhiteTruckMafia
    TN
    19 TRD PRO
    ^^^^^^^^ Exactly that. I’ll also add that you won’t get a great break in by staying on the highway all the time. You need city driving miles mixed in there too. All of the stopping and going puts different forces on your engine that helps all your seals and parts become great friends with each other. Your brakes and everything find ZEN during your first 1k miles. Goofy way of explaining for a laugh , but that’s pretty much what happens when you buy a new vehicle
    MOC221_ and SpadeGlider[OP] like this.
  14. Jan 10, 2020 at 1:01 AM
    SpadeGlider
    Jose
    Non... YET
    Hmmm very interesting good thing to know new knowledge
  15. Jan 10, 2020 at 1:03 AM
    SpadeGlider
    Jose
    Non... YET
    Unfortunately I gotta do highway right now driving to my trade school and back is the only option in the mornings but I will definitely keep that in mind and take different routes when I run my errands
  16. Jan 10, 2020 at 1:04 AM
    WhiteTruckMafia
    TN
    19 TRD PRO
    Just another reason I’m glad I moved back to TN some years ago. Lol 0300 and I’m in shorts and a sweatshirt with a nice mild breeze.
  17. Jan 10, 2020 at 1:15 AM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    ^This^
  18. Jan 10, 2020 at 6:37 AM
    Dano461
    Dano461 Well-Known Member
    2002 Reg Cab PreRunner
    Yup covered in the owners manual.
  19. Jan 10, 2020 at 6:53 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Try turning down the sensitivity of the adaptive cruise, at the default setting, it tends to over react. On the lowest setting, it works great.
  20. Jan 10, 2020 at 7:01 AM
    SpadeGlider
    Jose
    Non... YET
    Thank you!!! I’m gonna spend some more time reading over the owners manual
