MPG loss after TRD air intake install..?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 360joules, Apr 6, 2019.
  1. Apr 6, 2019 at 11:42 AM
    360joules
    360joules [OP] FWC Stalker
    Troy
    Portland Oregon
    SOLD
    Hi Folks,
    So, I made two upgrades at once and afterwards noted a fairly significant drop in MPG. I installed the trd intake and also installed OVTune and now most in-town trips get as low as 8 mpg.
    I flashed OVTune back to the factory stock flash and still get low MPG. Also, most users noticed an increase in MPG with OVTune. I'm thinking it has something to do with the intake.
    What might I have screwed up when installing the intake? Any sensors or anything that I might have damaged during install? The filter itself looks nice and clean.
    Where should I start looking? Thanks.
    Added: Another change I made was that I switched from 87 octane gas to 91-92.
  2. Apr 6, 2019 at 11:47 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Wow, 8 mpgs that really sucks. Hard to belive intake will do that. I read the ov tune review thread and all members said they got improvement in mpgs.
    Any warning lights on? How does it drive? If you didnt connect sensors right you would def have warning lights on. Very curious to know whats the issue. Good luck and hopefully you fix it soon.
    inwood customs likes this.
  3. Apr 6, 2019 at 11:49 AM
    360joules
    Troy
    Portland Oregon
    SOLD
    I guess one more change I made during that time was going to 92 octane gas from 87...for the tune.
  4. Apr 6, 2019 at 11:54 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    *points at your foot*
  5. Apr 6, 2019 at 11:54 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    How many miles since the change? It took a solid ~400 miles or so before the tune really settled in and i started noticing a improvement in MPG. When you flash the ECU, most if not all the fuel and timing trims are reset, which will in turn need to be relearned. Give it some time if you havent already.
    FWIW I got about 1 mpg increase with the tune over stock (87base tune) and average ~19 mpg. All stock, except for 250lbs of armor and 265/75r16 10 ply tires that are very heavy.
  6. Apr 6, 2019 at 11:59 AM
    xaircav
    xaircav Well-Known Member
    Bill
    Wheat Ridge, CO
    '10 TRD Access Cab 6 speed manual
    TRD intake, skid plate, cat back exhaust and short throw shifter. Bilstein 5100 leveling front and 5100 shocks rear. 32” Falken WP AT4W tires on Gen 3 wheels.
    The TRD CAI I put on my gen 2 netted me a slight mileage increase. This is very strange. Try disconnecting the battery negative for about 30 minutes. MAF clean? Throttle body clean?
  7. Apr 6, 2019 at 12:01 PM
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    I have the TRD intake and mileage was the same as stock. Maybe a hair better if anything. Have had it for about 15,000 miles
    Nexusix likes this.
  8. Apr 6, 2019 at 12:04 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    :burnrubber:
    inwood customs and 360joules[OP] like this.
  9. Apr 6, 2019 at 12:07 PM
    360joules
    Troy
    Portland Oregon
    SOLD
    So we are all in agreement that something is "wrong" about this.
    I don't have any warning lights on. I do periodically feel a misfire or two, but Mat is addressing that issue with his OVTune updates. I'm tempted to replace the MAF sensor just to rule that out, but not sure if there are other things that can get screwed up with this install.
    I seem to recall reading somewhere something about these air boxes blocking an injector something something but don't know where or what that was.
  10. Apr 6, 2019 at 12:10 PM
    pinochle
    NNJ
    You can try cleaning the MAF sensor first. Make sure it's cold before you start and use MAF cleaner.
  11. Apr 6, 2019 at 12:18 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    The second gen tacoma black and red plastic topped "trd" intakes typically run lean... So that makes sense
  12. Apr 6, 2019 at 12:19 PM
    RuggedOffroadBC
    RuggedOffroadBC Adventurer and Vlogger, Land Cruiser Owner
    Tristan
    Okanagan Valley, British Columbia, Canada
    2011 Tacoma TRD Off-Road 4.0L 6spM
    https://www.youtube.com/channel/UC4GnTr_PRdbgMD5TEL-dofg
    ^ seconded. MAF clean may be in order, but generally as a rule if the MAF is faulty you'll get a CEL coming on. That being said, due to there being a new intake in question, still would be the first place I'd check.
  13. Apr 6, 2019 at 12:37 PM
    Hijynx
    Hijynx Well-Known Member
    Pacific Northwet
    2019 Offroad DCLB
    I just installed my TRD CAI last saturday and flashed 1.05 87 base on thursday. my mileage stayed about the same. if you are getting 8 MPG I think you would smell the catalytic convertors (rotten egg smell) from an overly rich mixture. make sure you didn't over tighten the clamps on the plumbing to the intake - they just need to be snug enough to hold the hoses on. if the maf sensor was not plugged in you would have warning lights at a minimum. the only other thing that is disconnected to install the CAI is the EGR hose - that's easy enough to check. other than that reflash to a different tune and disconnect the battery or refill the tank to reset mileage. how many miles driven since the changes?
  14. Apr 6, 2019 at 1:04 PM
    CTtoNoVa
    Pop N Lock
    Did you take the plastic off the filter? :)
  15. Apr 6, 2019 at 1:05 PM
    CTtoNoVa
    Pop N Lock
    I like it.
  16. Apr 6, 2019 at 1:10 PM
    SpeySquatch
    2016 TRD OR DCSB
    Are you waiting a full 300-400 miles after a flash before you start watching mpgs? This is crucial
  17. Apr 6, 2019 at 2:25 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
  18. Apr 7, 2019 at 2:23 PM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    I can't even imagine 8 mpg in a Tacoma. My worst mpg so far was 17.1 mpg and that was due to driving into 25 mph headwinds coming out of the Columbia Gorge combined with making a half dozen trips to the hospital in The Dalles which I swear sits on the highest hill in that area.
    One should not go by what you see on your dash readout. The one and only way to tell if your mpgs are actually worse is to have tracked all your mpgs per tank prior to making the changes and then continue doing so afterwards. Total miles driven divided by gallons to fill the tank. The only way to see trends.
    Boghog1 likes this.
  19. Apr 7, 2019 at 6:32 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    87 octane has more btu per gallon than 91. Likely it’s the tune and required fuel.
  20. Apr 7, 2019 at 9:01 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
