Mpg loss from heavier stock sized tire trd or
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jrain904, Dec 20, 2018.
  1. Dec 20, 2018 at 3:27 PM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    About 2 mpg loss, cut I have 265/75/16, one size up from stock. Also my pressure is about 30 psi due to the chalk test results.
  2. Dec 20, 2018 at 3:42 PM
    jrain904
    jrain904 [OP] Well-Known Member
    Thanks bud. How is the old 505? I grew up there.
  3. Dec 20, 2018 at 3:52 PM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    Just to throw this out there. A good upgrade is a lighter wheel. You can get brands like FN for around $700 and you will get that money back in the long run from gas savings. My FN countersteer type x weigh in at 19 lbs a peice (Stock alloys are around 29lbs) running E load range 285s on my 2nd gen I still get 16-18 mpg. On stock wheels and tires i only averaged 17-19mpg. And obviously the wheel can last you a lifetime. Good luck with your decision.
    :cheers:
    509 buckeye and jrain904[OP] like this.
