Mpg loss with BFGoodrich All Terrains
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sg11, Mar 17, 2016.
  1. Mar 17, 2016 at 3:49 PM
    sg11
    sg11 [OP] Member
    The BFG AT is quite a bit heavier than the stock tires and was just wondering for those of you who have upgraded to BFG AT tires, how much of a mpg loss if any have you noticed? And whether you have the 4 or 6cyl...
  2. Mar 17, 2016 at 3:58 PM
    amxguy1970
    amxguy1970 Well-Known Member
    Tyler
    Texas
    All that info is out there (many of times), it is dependent on the person, the size are you going to, what model you have, which transmission, are you a 4 or 6 cylinder, what area are you living and driving in, what load range tires, are you going to level? If you are a non OR are you removing the valence? Figure 1-2 give or take. Load range E 2 as well as a rougher ride. So many variables and so much info already out there and answered...
    Tyler
  3. Mar 17, 2016 at 4:04 PM
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Well, the search tool can be a bit of a pain to find what you need.
    Anyhow, I have 265/75/16 BFG KO2's Load Range E and I haven't noticed a difference in my MPG. I'm heavy footed as it is so.
    I also have a 4cyl.
    TurboGT likes this.
  4. Mar 17, 2016 at 4:06 PM
    BrettsMac08
    BrettsMac08 Well-Known Member
    Kansas
    2016 DCSB TRD Sport | 2002 Camaro SS
    KDMax Tuned | MagnaFlow Exhaust | OEM Audio Plus Reference 450Q | TRD Pro Wheels | AT Tires | LED Interior Lighting
    I'd expect to lose about 3.141592654 MPG with the E2 BFG's on a TRD sport with valence removed and 17" TRD Pro wheels with a 3.5L V6 auto trans set to S5 while going up a 20 degree grade in 56.4ºf weather while it's foggy with a 10 MPH tailwind and your lights on.
    Really though, I'm sure someone around here has a simple answer and will respond accordingly. I'm considering going to some AT tires on FN FX Pro wheels on my Sport and was kind of wondering the same thing.
    I put a 3"/1" level kit with the stock 17" TRD Rock Warrior wheels and 275/70/17 BFG AT KO's on my Tundra and it wasn't any different at all from what I could tell. Averaged about 14 either way, haha.
    TurboGT likes this.
  5. Mar 17, 2016 at 4:07 PM
    Hankstone
    Hankstone Well-Known Member
    2016 Tacoma Sport DCLB
    I've got 3rd gen V6 with 265/70/17 KO2 C's. I'm in the SF Bay area so not flat, I'm finding I can get within a mile or so of stock MPG but I've got to work the throttle a bit more than with stock (I mean to get the best MPG I can get). Seems easier to make the MPG go down though.
  6. Mar 17, 2016 at 4:10 PM
    mij
    mij Day work
    Traction is the reason I went with the K02's .
    Next more traction more aggressive tire like Super Swampers.
    mpg . ride . noise mean little Traction =#1
  7. Mar 17, 2016 at 8:50 PM
    redbull9944
    redbull9944 Well-Known Member
    Southwestern PA
    ‘24 LC250 First Edition, ‘25 TRDOR 6MT, 2016 DCSBTRDOR Inferno 6MT, 2004 Double Cab 4WD Project
    Prinsu Rack, 275/70R17 Cooper ST MAXXs, TRD PRO 4Runner Wheels, 5100s
    V6 Manual Transmission. I lost about 1-1.5 MPG. Tires are BFG AT/KO2 275/70R17
  8. Mar 17, 2016 at 10:18 PM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    Dat Pi reference. ;)
    big_jarv likes this.
  9. Mar 18, 2016 at 5:32 AM
    manofsteele2003
    manofsteele2003 Well-Known Member
    2016 Blazing Blue TRD Sport Double Cab
    17" TRD wheels w/265/70/17 BFG KO2s, Weathertech mud flaps, Gecko LED bed lights, more to come.
    I don't think I lost any at all. I got 265/70/17's C load, TRD Sport 4x4. They're set at a higher psi than stock (45psi) so that might be making up some difference, they also ride so much better than the stock tires.
  10. Mar 18, 2016 at 1:06 PM
    208samm
    208samm Well-Known Member
    Sam
    2016 MGM DCLB TRD OR
    Most people putting KO2s on their Tacoma seem to go from 265/70-16 to 265/75-16 (or similar for 17s). So the odometer will show 96.7 miles for every 100 miles driven. So if you were getting 20mpg with stock tires, 19.3 mpg would be exactly the same economy. It seems to be common to see people say they lost 1-2 mpgs, some of that is due to wheel size differences affecting the odometer, some of it due to weight/tire construction/etc. just a thought.
    tacoman45 likes this.
  11. Mar 18, 2016 at 1:36 PM
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    Somehow I don't think those that lift their trucks and put those heavy off road tires on them really care about fuel economy. Nor should they......
    smitty99 likes this.
  12. Mar 18, 2016 at 1:41 PM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    I love Pi... especially cherry Pi
  13. Mar 18, 2016 at 1:42 PM
    208samm
    Sam
    Agreed. I didn't lift mine, but did put the 265/70-17 KO2s load range C on it, and I think the odometer not calibrated to the new size is the biggest contributor to the *slight* change in MPGs.
  14. Mar 18, 2016 at 1:49 PM
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    OK, so I just filled up my truck so maybe I can answer this basic and simple question, all variable's aside. I have a 2013DCSB SR5, just installed a 2.5" lift, with BFG A/T Load E, 285/70/17. When the truck was stock, I had 245/75/16 I was getting 16 city, 19 hwy, I am now getting 14.5 city, HWY??TBD...Good thing this isn't my daily driver...hope this answers your question...
  15. Mar 18, 2016 at 2:55 PM
    manofsteele2003
    Did you check the speedo prior to install? I guarantee that it was off by about 2 mphs and putting a half size bigger didn't even it out. I had 285's on my FJ and the speedo was dead on my GPS, 2 mphs off to start with. Run an extra GPS and see what it says compared to the speedo.
  16. Mar 18, 2016 at 3:36 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    My GPS seems to read about 1 mph faster than the speedometers. Wondering if going up to a 265/75/16 would put it just about right on.
  17. Mar 18, 2016 at 4:46 PM
    manofsteele2003
    Yep, it'll say you're going a mile or two faster than you are so a size larger should put you about dead on. It think every car I've owned has been that way, I guess it's just a margin of error on the safe side.
  18. Mar 18, 2016 at 4:56 PM
    SLO TRD
    SLO TRD Living the SLO life.
    Gene
    San Luis Obispo, Ca.
    2016 Magnetic Grey TRD Sport DCLB
    Snugtop, 5100's, weather tech mats floors, truck bed, Tinted front windows.
    I have 265/70/17 BFG TA's and my MPG sucked before and after I put new tires on! No difference it just sucks...
    Roddy13 likes this.
