MPG MOD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xgalvanxgx, Mar 24, 2012.
  1. Mar 24, 2012 at 9:38 AM
    xgalvanxgx
    xgalvanxgx [OP] seymour butts
    Gerardo
    OC (Lake Forest) California
    TRD Off-Road BlackSandPearl 07 PreRunner
    DTF Race Kit with 2.5 x 10 Kings, DMZ SUA rear with 16" triple bypass Kings, King bumpstops front and rear, 17" KMC beadlocks and 35's, front and rear DTF bumpers, front Fiberwerx glass and Mcneil trophy bedsides, K&N 77 Series Intake, Magnaflow, USA SPEC iPod Adapter, Rockford Fosgate 10" sub with custom box and amp. Andres' devil horn emblem, 50" D4 curved LED bar, HID converted hella 4000s.
    quick question. so i just installed some 285's on my taco with a 3" spacer lift. :D looks beautiful! i was just wondering if i install those air filters (afe) how much MPG's would i really be saving? before i believe i was 19 city and 21 highway.
  2. Mar 24, 2012 at 9:40 AM
    Tythias
    Tythias Active Member
  3. Mar 24, 2012 at 9:44 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    I think you'll get a little more high end power, but as far as mpg, you won't be able to notice...
  4. Mar 24, 2012 at 9:47 AM
    xgalvanxgx
    Gerardo
    does anyone know the average mpg's with 285's?
  5. Mar 24, 2012 at 10:37 AM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    fuelly.com
  6. Mar 24, 2012 at 10:37 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    You tell us, you have them.
  7. Mar 24, 2012 at 11:08 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Other threads asking this. The aftermarket air intakes don't give you better gas mileage.
  8. Mar 24, 2012 at 11:14 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Your stock air intake is already a cold air intake because of its location in the side fender. You may feel a little bit of hp increase using the butt dyno by adding an aftermarket filter but if you get an oiled filter such as the K&N then the MPG's will plummet, or at least mine did. You truly won't get much gain from a filter replacement because of the way modern fuel injection works. You can have a filter clogged to the point where it will literally pop and come apart the computer and fuel injectors will adjust to the amount of air coming in to allow for the best power and fuel economy depending on how you drive it. The best MPG mod is to keep your foot out of it and rpm's around or under 2k revs.
  9. Mar 24, 2012 at 11:51 AM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    My truck with stock tires was 18-19 mpg with 285 BFG's it was about 15-16 mpg, now with 35" tires it's about 13 mpg.
    But remember that you need to take into account tire brand, wheel type, actual diameter, etc.... it is NEVER comparing "Apples to Apples" No one's truck will be exactly like yours!!
    Also you will need to re-calibrate you stock speed ratio to match your tires size or the number means "Jack Crap!"
    Example:
    My 35" tires actually is getting 15-16 mpg after all the calculations. So from stock I dropped 2 mpg. Real world milage.
    Each rotation of the 35" tires cover more distance then the smaller stock tires. Also the engines rpm to actual speed is lower, so at highway speed at the same rpm I cover more distance then a stock truck.
    But stop and go driving there is a higher load due to the larger size tire.
    If that's not confusing enough?
    Smaller tires with heavier wheels vs larger tires with light alloy wheels. The difference maybe a wash! It depends on many different factors!
    My best advice if you're gonna loose sleep over mpg??
    Leave it stock or buy a kia!
    No sense having a pimp'd out ride and it causes you stress in the wallet!
  10. Mar 24, 2012 at 12:03 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Toku dropping knowledge, as usual. ;)
    Track at least your next 3 tanks and you'll have a good idea. Only way you'll know what your ride with you behind the wheel will get.
  11. Mar 24, 2012 at 12:23 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The AFE will most likely hurt MPG.
    Not because of anything it does, but because you'll like the sound and end up mashing the "go pedal" more.
    90% of fuel economy is in your right leg.
  12. Mar 24, 2012 at 3:49 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    click my fuely... interesting idea about the K&N making mpg worse..
  13. Mar 24, 2012 at 4:07 PM
    xgalvanxgx
    Gerardo
    Thanks guys! Hopefully my baby doesnt drive me too hard or back to stock wheels and tires it is. :) :/
  14. Mar 26, 2012 at 8:58 PM
    toku58
    HAWAII
    4x4 Beast!
    Hey Eric! Long time no talk! How's things in your neck of the woods! I hardly come around the Tacoma forums these days. Busy with life!:D
    Hope all is well!
  15. Mar 27, 2012 at 3:43 AM
    4x4Taco2012
    4x4Taco2012 Well-Known Member
    Philadelphia, PA
    2013 DCSB TRD Sport 4x4
    Tacoma Bed Mat, TRD Front Skid Plate, Pop'N'Lock Tailgate Lock, Weathertech Digifit Floor Mats, BAK Roll-X Tonneau Cover, Toyota Wheel Locks, Sliding Rear Window Lock, Center Console and Glove Box Motion Detection LEDs, BFG Rugged Terrains, PrimusIQ Brake Controller, Toyota Cargo Net, Entune w/Nav.
    He nailed it!
  16. Mar 27, 2012 at 9:17 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Try and get rid of all the unnessary wieght that you might carry around. I carry a bunch of stuff the I think I might need sometime and it kills my gas mileage. Also as stated above try and keep the revs below 2k.
  17. Mar 27, 2012 at 12:45 PM
    late apex
    late apex New Member
    This is true, apparently the stock air box is maximized for fuel economy on these later taco's. I have had an AFE Pro Dry for 4ish months.
  18. Mar 27, 2012 at 10:59 PM
    toku58
    HAWAII
    4x4 Beast!
    You can get the same results by removing the secondary filter in the stock air box.
  19. Mar 27, 2012 at 11:21 PM
    Schwinn
    Schwinn Well-Known Member
    Jamie
    Georgina, ON
    2012 TRD Sport with Trail Teams package
    I've replaced the air filter in my last few cars with a K&N with varying results, but always figuring worse case scenario I'd at least save in not replacing air filters.
    My first ranger had a weak six, and I had to keep down shifting on every small hill on the highway. The filter eliminated that, so I did get a couple of ponies. No noticeable difference in mileage. It fit my next Ranger with the bigger 6, so I never drove it without. No idea on the effect.
    The Tribute, Civic si and Mazda5 we had after that, I think there may have been a very slight performance improvement, but it could have just as easily been a placebo/wishful thinking effect. My wife's Kia Sedona is getting about 2 1/2 more mpg with it, which is nice given the amount of travelling we do in "the Behemoth".
    My V6 Mustang got a cold air. The original air box drew from inside the wheel well, so it was essentially a CAI. However, there was an almost 180 degree bend in the tube, and the inlet was about an inch and a half. After I installed the after market CAI, I did get more power, but my mileage went up by 7mpg! (based on on average increase in distance traveled on a tank of 100+ kms).
    Looking through the site, there doesn't seem to be a consensous on the effects of performance filters or CAI. But my personal experience has been, "Depends". But I agree with toku58, I was aware of my mileage when I bought it. But I didn't expect to be able to increase the mileage. If I do, bonus. If I don't, then I guess I'll just have to slow down so the ladies can check out my awesome...
  20. Mar 28, 2012 at 1:34 AM
    !TacoTaco!
    !TacoTaco! TACO LOVER!
    Felix
    PSL, FL
    09 Prerunner TRD SR5 Sport
    Removed coal filter, Also installed AFE air filter. Roof rack with custom diamond plate air diverter.
    Control your right foot, I did and I removed secondary filter and added AFE filter and I got 21 MPG.
    I also do mostly city driving. Everything else is stock on my truck.
