MPG Mods
Discussion in '4 Cylinder' started by kylefrdavis, Apr 20, 2009.
  1. Oct 14, 2010 at 5:18 PM
    #181
    whtlizzard
    whtlizzard New Member
    ANTHONY
    PASADENA CA. + DURANGO CO.
    08 DOUBLE CAB 4X4 LONG BED BASE MODEL
    VOLANT INTAKE WITH RAM AIR ..FREEFLOW MUFFLER WITH OVER SIZE PIPES looking at adding a lift kit
    its a 2.7 thats normal
    mines a 4.0 4x4 I got 23 MPG last week driving 70-80 mph
    next week im putting on a volant ram air intake and a freeflow muffler and oversize exhaust pipe
    I did that to my t-100 and got 3-4 more miles per gallon
  2. Oct 14, 2010 at 5:19 PM
    #182
    whtlizzard
    ANTHONY
    putting a bed cover tonnou or roll-up cover will help also
  3. Oct 17, 2010 at 8:00 AM
    #183
    DBZ
    DBZ Hunter-Gatherer
    South Georgia
    2010 DC PreRunner TRD Off Road
    Fog lights anytime, DIY shorty antenna, carpet lined storage bins, debadged, tailgate hoseclamp, DIY washable cabin filter, AFe Pro-Dry air filter, Protecta bed mat
    I have a question about oil and fuel mileage. I see many members say they use 5w-30 or even 10w-30 syn and dino oil, but the 2010 V6 manual recommends 5w-20 or 0w-20 (for better MPGs and cold weather starting). Is there a reason for running the higher viscosities and is there any correlation to improved or decreased MPGs?
    I've been running 5w-20 Mobil 1 syn in my 2010 DC V6 AT. I'm getting 20 MPG on a 40 mile round trip commute to work; very little city driving. I'd like to get the 0w-20 Mobil 1 syn, but you can't buy it in the 5 qt jugs (well that's what I read on TW and I have never seen it in the store) and it's ~$6.50 a qt. Has anyone seen the Mobil 1 syn or syn in 0w-20?
    A side note, I don't tow or haul loads often so I don't "need" the high viscosities oils.
  4. Oct 17, 2010 at 12:01 PM
    #184
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    The ratings on a multi-weight oil are telling you what single weight oils they can be used to replace. The low number being the lower weight, and hence lower temperature that the oil can handle with the right viscosity. The high number being the higher weight and hence the higher temperature the oil can handle. So a 0w-20 and a 0w-30 oil will have the same viscosity up to the temperatures that the 0w-20 can handle. After that the 0w-20 will start breaking down and lose to much of it's viscosity to protect your engine properly.
    So, basically, you can run a 5w-30 with the same gas mileage benefits as a 5w-20. The 5w-30 will just protect your engine at higher temps that the 20 won't be able to handle. This means you should be able to buy the 5qt bottle of mobile 1 0w-30 at wally world, and get any gas mileage benefits to be had. The idea is to meet or exceed the oil weight range specified by the manufacturer.
  5. Oct 17, 2010 at 6:33 PM
    #185
    DBZ
    DBZ Hunter-Gatherer
    South Georgia
    Thanks for the reply! Makes perfect sense.
  6. Oct 18, 2010 at 5:52 AM
    #186
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Leadgolem,
    Show me proof that a 30wt protects better than a 20 wt. On a major oil forum, no one has been able to prove this, when a 20 wt oil is specified by the manufacturer. The main reason is that 20 wt oils use a higher quality base stock, that shears less than most 30 weights. The "W" in the grade rating stands for winter. This is the rating for the flow charateristics at cold startup. The upper number is for the viscosity at 212F. And more viscosity is not always a good thing. In the next few years you will begin to see 0w-10 oils, as engine tolerances get even tighter. For cold start a better thing to know is the pour point. Unless you live north of the USA border, you wont know the difference between 5w and 0w. Most decent brand names 5w have pour points of -35F or better.
    DBZ,
    Don't fear the thin. It really is helping you save fuel. My 4 cyl Taco gets about 1 to 1.5 MPG more using 5w-20 vs 5w-30.
  7. Oct 18, 2010 at 6:09 AM
    #187
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    I try to keep moving and reduce how many times I come to a complete stop.
  8. Oct 18, 2010 at 10:47 AM
    #188
    Leadgolem
    Greg
    Littleton, CO
    You are correct in that more viscosity is not necessarily a good thing. However, you do need a certain minimum viscosity to keep your engine parts coated during normal operation.
    You really should do your own research if you think I'm wrong. Dig into some of the base data instead of relying on the conclusions of others. I think you will be surprised by what you find. :)
  9. Oct 18, 2010 at 11:12 AM
    #189
    91r100gs
    Dan
    Kansas City area
    No sir, it is up to you to show the proof, since you made the claim.
    You said it yourself. You need a certain minimal viscosity, and the automakers, the government with its fuel mileage standards, and the oil producers have now for over ten years have produced a light viscosity, high quality oil that protects their products to the levels the automakers demand.
  10. Oct 18, 2010 at 11:49 AM
    #190
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    All I know is I've been using full synthetic Mobil 1 0w-20 and she likes it. Definitely runs smoother, and gained a bit on the MPG's.
  11. Oct 18, 2010 at 7:25 PM
    #191
    Leadgolem
    Greg
    Littleton, CO
    Original commend deleted by me, it was unnecessary.
    EDIT: This discussion did make me curious. I went back and looked and I did misremember some things. I was incorrect in stating that a 0w-20 and a 0w-30 oil would have the same viscosity when hot.
    http://en.wikipedia.org/wiki/Motor_oil
    This means that a 20 top number oil would be thinner then a 30 top number oil when hot.
    There is something odd here though. My manual specifies a 5w-30 oil for improved gas mileage. If a 5w-30 and a 10w-30 oil have the same viscosity at operating temperature then using a 5w-30 oil should not have any effect at all on gas mileage. Except, of course, for the small amount of time it takes the engine to heat up.
    I think I'm going to have to find a copy of SAE J300. I'm thinking the disparity is due to the difference in where the actual engine temperature is, as opposed to what the SAE considers "hot". The viscosity change slope due to temperature being different for a 5w-30 vs a 10w-30.
  12. Oct 19, 2010 at 4:00 PM
    #192
    91r100gs
    Dan
    Kansas City area
    If I had your truck I would run a 30 wt in it also. It is what the maufacturer recommends. I always ran 5-30 in my 1991 Toyota PU. IIRC the manual suggested 10w-30 also, but I was beginning to get oil savy around that time, and understood the benefits of a lighter weight during cold startup, and realized that 90-95% of engine wear occurs during the first 20 seconds of a cold start.
    If you go hang out at www.bobistheoilguy.com for a while, you can learn about common misconceptions about modern rapidly improving oils. 20wt vs 30wt are some of the best discussion threads there.
    BTW: I am caffiene free: but really do miss it.:D
  13. Oct 19, 2010 at 10:50 PM
    #193
    Leadgolem
    Greg
    Littleton, CO
    Hmm, I think I'll go do that. It should be an interesting read.
    EDIT: Actually, I'm running a 0w-30. :)
  14. Nov 7, 2010 at 7:17 AM
    #194
    br1
    br1 New Member
    Texas
    06 Tacoma
    I just bought my first Tacoma, how will putting a shell on the back affect the gas milage?
  15. Nov 7, 2010 at 7:50 AM
    #195
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Probably not much different, at least in my experience. The difference in air resistance is offset by the weight, I'm guessing my shell is at least 200lbs if not a little more. You most likely won't see much difference if any.
  16. Nov 15, 2010 at 3:44 PM
    #196
    ImthePrez
    ImthePrez Well-Known Member
    TN
    06 Prerunner TRD
    I switched to Mobil 1 full synthetic 5 w30 few months ago and I can see a difference in the mpg.
  17. Dec 1, 2010 at 7:07 AM
    #197
    jrabbit
    jrabbit New Member
    john
    acworth ga.
    08 tacoma prerunner quad
    helper springs on rear
    i put some helper springs on my 08 tacoma prerunner and they help from the back end from sagging with a loaded trailer behind it
  18. Dec 1, 2010 at 7:09 AM
    #198
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    x2 I usally go 5 mph under the speed limit. You can also use www.fuelly.com to monitor your mpg.
    AxisCab likes this.
  19. Dec 3, 2010 at 8:38 AM
    #199
    FTL911
    FTL911 Well-Known Member
    Paul
    SoCal
    06 PreDblCabTRDSport
    I concur...It really boils down to $$$ vs sense
  20. Dec 4, 2010 at 4:12 PM
    #200
    sanbullet
    sanbullet Member
    good idea but when the motor is running your are always using some gas
