MPG Mods
Discussion in '4 Cylinder' started by kylefrdavis, Apr 20, 2009.
  1. Feb 20, 2011 at 5:56 AM
    #261
    gray liquid
    gray liquid Member
    NC, for now
    '08 2.7, 4x4, access cab
    rmvd 2ndary air filter, memphis audio speakers,lce header, mobil1 full syn engoil(factory filter), afe pro dry s drop in,
    anybody using any other type of spark plugs like performance ones . any recomendations.
  2. Feb 21, 2011 at 1:44 PM
    #262
    greg muncy
    greg muncy New Member
    greg
    Pottsville Pa.
    2011 4cyliner 4x4 Tacoma
    Just got 2011 access cab, 4 cylinder auto., I got it for gas mileage, not thrilled with taking it easy and getting just under 16 mpg with a mix (town & highway). Anyone else have this?
  3. Feb 21, 2011 at 1:51 PM
    #263
    tacopromatt
    tacopromatt Matt's Pro Taco (SOLD)
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
    Changing my plugs and doing front/rear diff oil + transfer case oil upped my mileage by at least 3mpg. Went from 13mpg to 16+ overnight (city driving). I'm hoping for 18+ on this next road trip.
    I am lifted 3", 4wd, with 33's.
  4. Feb 22, 2011 at 6:26 AM
    #264
    deo1929
    deo1929 Well-Known Member
    Dennis
    Central Indiana
    4 cyl. 4X2 access cab
    Convenience package, Toyota VIP alarm, Variable speed wipers, tonneau cover, 2011 factory radio with MP3 CDm Scangauge II
    I have tried a variety of plugs including the Bosch Platinum +4. The best plug I've found is the Iridium plug that comes from the factory. I lost MPG on the other plugs but got the best MPG on the Iridium plugs.
    BTW...If you haven't done with Thieu has done (i.e. change the drive line fluids to full synthetic) do it. I got the same gain in MPG as he did when I changed the fluids out. I used Amsoil, but Mobil 1 will work just as good.
  5. Feb 22, 2011 at 6:30 AM
    #265
    deo1929
    Dennis
    Central Indiana
    Check your tire pressures. I run mine at 35 PSI and have no problems with tire wear and it helps MPG too.
  6. Feb 22, 2011 at 12:17 PM
    #266
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I also have an '08 2.7. Curious, what was the mileage when you change the plugs. How did they look ? They say 100,000. You didn't do 100,000 in 2 years did ya ? I've got about 35K on mine. I don't think I want to wait til 100,000. The 6 cyl are pegged at 30,000. What's up with that ? They don't use Iridium plugs tho. Thanks Curious George
  7. Feb 22, 2011 at 12:20 PM
    #267
    tacopromatt
    Austin, TX
    I just did mine as 45k (I'm 6 cyl.). The service rep himself told me not to worry about it until 60k and I read every 30k eveywhere online.
    For $15 bucks and 45mins of my time, the added mpg was totally worth it.
  8. Feb 23, 2011 at 8:09 AM
    #268
    deo1929
    Dennis
    Central Indiana
    I had a 1st Gen Tacoma and I tried different plugs in the 2.4L engine. the MPG dropped about 1 MPG and I got the engine check light coming on after 4K miles. I had it checked and it was a misfire code. I changed plugs to the factory Iridium and the problem went away and the mileage came back up. On my '08, I have only 32K on it. I also tried the "halo" plug in my Honda CR-V with the same results as the truck. So I'm sticking to the factory plug and will check them around 50K and again at 75K. I guess if it works, don't fix it, eh?
  9. Mar 25, 2011 at 9:18 PM
    #269
    TheMrGExperience
    TheMrGExperience Because Tacos are too mainstream...and Im poor.
    Garrett
    Slidell, LA
    01 GMC Sierra z85 4x4 4.8L RCLB
    Debadged, 4x6 to 6x9 rear speaker conversion
    you probably have not broken the engine in yet. I get about 22-24 mpg with my 4 banger access cab. :)
  10. Mar 27, 2011 at 8:40 AM
    #270
    ADVBedouin
    ADVBedouin Well-Known Member
    Central CA Coast
    '10 Preunner Acc Cab 2.7L 5spd
    2" CCM front spacers, secondary airfilter gone, OEM 16" alloys, Trailer hitch gone, Seat belt buzzer gone, Ignition key buzzer gone, shortened fact. antenna.
    My '10 4cyl, 5spd Prerunner access cab w/ 16k miles gets 22 in the city & that was when I was running 40 psi in the Dunlops. I'm running 48-50 psi rear/front & we'll see if that changes it all.
    Just don't run the thermostat on panel/Def as I think it utilizes the A/C which will hurt mileage.
  11. Mar 27, 2011 at 9:05 AM
    #271
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    For those if you Running the dunlop grandtreks on your 2011 4x4 what are your tire pressures? The door jam says 30psi for front and rear. What are you guys running for best fuel economy? I hate the tires So i dont care about wear just care about not hydroplaining and dying with those horrible tires in the rain.
  12. Mar 28, 2011 at 11:23 AM
    #272
    JEA86
    JEA86 Well-Known Member
    Jeremy
    WV
    2016 TRD Off-Road
    ^^ i run 37 on all 4 corners on mine
  13. Mar 28, 2011 at 12:11 PM
    #273
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    jea86 thank for the info I will try 37 see how it handles in the rain and hope i dont die
  14. Mar 28, 2011 at 12:43 PM
    #274
    JEA86
    Jeremy
    WV
    2016 TRD Off-Road
    i have used it in snow and ice so i dont think you will die :) but like i said this is how my truck responds may not work for yours so just be careful as you are going above what factory calls for i am just telling you what i use
  15. Mar 28, 2011 at 12:44 PM
    #275
    JEA86
    Jeremy
    WV
    2016 TRD Off-Road
    just pulled 24.9 MPG on my 2010 4x4 :) woo hoo!
  16. Mar 28, 2011 at 12:54 PM
    #276
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Exactly the same for me -- 2006 4-cylinder 2wd automatic access cab SR5, 58k miles. 2 weeks ago changed the motor oil/filter, tranny fluid and differential oil. Now it's smooth like buttah and clocked 24.2mpg on the last fill-up, mixed hwy/city. Stock tires at 34/32 psi F/R.
  17. Mar 28, 2011 at 5:25 PM
    #277
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    jea86 whats the make and model of your truck
  18. Mar 30, 2011 at 9:50 AM
    #278
    JEA86
    Jeremy
    WV
    2016 TRD Off-Road
    2010 reg cab 4 cyl bas model.
    switched all the fluids to synthetic blend (wal-mart supertech)
    switched motor oil to 5w-30 Wal-mart synthetic
    AFE high flow filter Stock airbox
    removed intake resonator
    inflated all 4 tires to 37psi
    TRD suspension
    TRD off-road Wheels
    TRD skid-plate
    color matched bumper with fogs (has nothing to do with gas just threw it in there :)
  19. Mar 30, 2011 at 1:23 PM
    #279
    TheMrGExperience
    Garrett
    Slidell, LA
  20. Mar 30, 2011 at 3:00 PM
    #280
    george3
    New Jersey
    This is a excellent lead in to a question I've been wondering about. Who makes wal-mart supertech ? What are the standards ? Is it on a par with Mobil 1 - which seems to be the most used synthetic on TW and sold at Walmart ? How could I check this ? Anyone ? Thanks.
