MPG Mods
Discussion in '4 Cylinder' started by kylefrdavis, Apr 20, 2009.
  1. Apr 1, 2011 at 6:55 AM
    #301
    HMFD110
    HMFD110 Well-Known Member
    New York
    2011 Reg Cab 4X2
    I'm from NY usually everybody speeds here, while others drive like a$$holes. Plus being a volly firefighter doesn't help either. I think the most miles I ever got on a tank was about 330. :(
  2. Apr 1, 2011 at 1:08 PM
    #302
    rag9836
    rag9836 Well-Known Member
    Robert
    Riverside, CA
    14 Pre Runner SR5 TRD
    Bilstein 6112 & 5160's, SPC UCAs, TRD Pro grill, Cali Raised ditch lights, Pro Runner Cab Roof Rack, Demello Stealth Rock Sliders, SS brakes lines, Power Stop brake kit
    For the AFE air filter, do you need to buy an new air intake, or does it fit into the stock air filter compartment?
    Thanks
  3. Apr 1, 2011 at 2:43 PM
    #303
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    ^^ the aFe is a drop-in replacement for the stock air filter.
  4. Apr 1, 2011 at 8:11 PM
    #304
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Damn, that sucks. I've gotten 530 miles on a tank, and I could have easily gone over 600 miles if I needed to.
  5. Apr 2, 2011 at 7:03 AM
    #305
    deo1929
    deo1929 Well-Known Member
    Dennis
    Central Indiana
    4 cyl. 4X2 access cab
    Convenience package, Toyota VIP alarm, Variable speed wipers, tonneau cover, 2011 factory radio with MP3 CDm Scangauge II
    I also have a Scangauge II in my truck. I've learned how to drive it to maximize my mileage. If I see a light turn red, I lift off the gas and coast into the light. The gauge shows "9999" MPH which means the fuel shutoff mode is active. I probably could attribute 2-3 MPG in city/urban driving to using the gauge. Plus it reads OBD II codes and other stuff.
  6. Apr 2, 2011 at 7:08 AM
    #306
    JEA86
    JEA86 Well-Known Member
    Jeremy
    WV
    2016 TRD Off-Road
    ^^ yeah my driving styles have changed as well.
    whenever i see a redlight i always coast to it. plus in WV we have alot of hills i basically coast down my hill into the city every morning for work but i use gas going back up the hill in the evenings, but i have been pulling out 25 MPG
    the best thing i ever did was stop driving my truck like a Civic si (that i had before) and revving it up so high to be easy on the gas and just leting it coast where it can has attributed to alot of my gas savings :)
  7. Apr 2, 2011 at 9:17 AM
    #307
    rezu84
    rezu84 New Member
    dave
    oconomowoc
    05tacomaoffroad
    i just changed my plugs on my 05 double cab,denso on rs and ngk on left side.
  8. Apr 3, 2011 at 7:03 AM
    #308
    stephan305
    stephan305 Active Member
    stephan
    miami,fl
    1999 prerunner
    2 1/2 skyjacker lift k/n cold air filter
    its all how you drive,just watch the tach.try to keep under 2200 rpms.not heavy on the gas.
  9. Apr 3, 2011 at 7:11 AM
    #309
    HMFD110
    New York
    2011 Reg Cab 4X2
  10. Apr 3, 2011 at 7:12 AM
    #310
    JEA86
    Jeremy
    WV
    2016 TRD Off-Road
    ^^ remove resonator in the fender
  11. Apr 3, 2011 at 4:29 PM
    #311
    TheMrGExperience
    TheMrGExperience Because Tacos are too mainstream...and Im poor.
    Garrett
    Slidell, LA
    01 GMC Sierra z85 4x4 4.8L RCLB
    Debadged, 4x6 to 6x9 rear speaker conversion
    does this actually give you better mileage or does it just make your intake louder?
  12. Apr 3, 2011 at 6:11 PM
    #312
    DPR921
    DPR921 Well-Known Member
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    24 mpg stock here! Pretty pumped on that.
  13. Apr 4, 2011 at 4:55 AM
    #313
    o5iiawah
    o5iiawah Well-Known Member
    Tim
    Philly 'burbs, PA
    '11 4x2 access cab 2.7l
    i have 5k miles and my average has gone to 23.2 to 24 in over the last 4 tanks, with an average fillup of 25.7. Being cooler in Fl has certainly helped as I havent had to run the Air con.
  14. Apr 4, 2011 at 6:18 AM
    #314
    JEA86
    Jeremy
    WV
    2016 TRD Off-Road
    it didnt make anything louder and i feel it helped, now if it did or not i dont know
  15. Apr 4, 2011 at 3:28 PM
    #315
    TheMrGExperience
    Garrett
    Slidell, LA
    thats surprising because i thought the main purpose of the resonator was to muffle the sound of the intake
  16. Apr 4, 2011 at 4:14 PM
    #316
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    When I took out the resonator it came a lil bit louder.
  17. Apr 4, 2011 at 6:49 PM
    #317
    TheMrGExperience
    Garrett
    Slidell, LA
    when i took the secondary air filter i noticed a bit more pick up. Any noticeable increase in gas mileage or pick up after taking out the resonator?
  18. Apr 4, 2011 at 8:21 PM
    #318
    JEA86
    Jeremy
    WV
    2016 TRD Off-Road
    it is but i noticed really no change in sound, just saying, not really saying its going to be the same on all trucks but for mine it did not up the sound level
  19. Apr 4, 2011 at 8:25 PM
    #319
    JEA86
    Jeremy
    WV
    2016 TRD Off-Road
    i know it wasnt directed toward me
    but i noticed a bit more what seamed to be lag in the lowr RPM's but it for sure breathes better and you dont have to gear down as much going up inclines, as for MPG with everything i have done i went from getting 19-20 to getting 24-25 True story and i think most of that is being ALOT easier on the pedal on the right
  20. Apr 6, 2011 at 8:36 AM
    #320
    TonyP19
    TonyP19 Member
    I read a recent tech article that claimed the air filter does little or nothing to improve gas mileage. It will, however, improve performance, which apparently doesn't go hand-in-hand with MPG. The example used was a dirty air filter - it made no difference when replaced. Using this knowledge, installing a high-flow air cleaner may improve performance, but not gas mileage.
    Like others have stated, proper tire inflation helps some, as does synthetic oil. I think the biggest gain in MPG is the proper use of your right foot. I find this Scangauge interesting and useful piece of equipment to help improve your driving habits, which would result in increased MPG.
