MPG Mods
Discussion in '4 Cylinder' started by kylefrdavis, Apr 20, 2009.
  1. Oct 7, 2012 at 7:40 PM
    #621
    Creepwood
    Creepwood Well-Known Member
    Lake Tahoe
    08 TRD 4X4 QCLB
    5100's w/885's up front, 5100's w/AAL out back
    Sounds like you've got a much bigger problem than tire size man.
  2. Oct 14, 2012 at 7:33 PM
    #622
    murderd out taco
    murderd out taco Member
    john
    new england
    murderd out
    Rims, tires, fender flares, heated seats
    Has anyone out there tried the gf performance chip in a 2011 taco 4x4 double cab?
  3. Oct 15, 2012 at 4:12 AM
    #623
    Charles Scott
    Charles Scott Member
    Vermont
    2007 Tacoma
    There really are no milage secrets out there and no mods anyone can simply bolt on to a vehicle and gain much in the way of milage, and still be legal. Back in the early 70's, we went to a national speed limit of 55 mph, because the cost of gas had skyrocketed due to Saudi Arabia and others in the cartel shutting down some of their refineries in protest to US policies.
    55 mph was chosen because at that speed most vehicles will maximize their gas milage. There is a milage "bucket" if viewed on a graph in which vehicles get their best milage. It starts out low on the graph and then moves up as you go faster and sort of levels out above 50 or so and keeps on going up slightly after that to about 58 mph. This is in top gear, or overdrive and on a level road with no headwinds. It is often simulated in test cells with the engine on a test stand.
    Anyway, about the slowest speed you should go, again, in top gear, is 42 or 43 mph. Below that, the engine is not running at it's most efficient and there are pumping and friction losses. Above 58 mph, air drag becomes a negative factor and continues to negatively affect mileage from then on. This will vary per type of vehicle, but even the big 18 wheelers get their best mileage at 58 mph.
    So it's actually very simple, the slower you run your engine in top gear, the less gas you will use. Heavy footed driving will use up gas at a much higher rate than driving as if there were and egg under the accelerator pedal.
    Brakes that drag a bit will also reduce mileage. Racks on the truck reduce mileage. Anything that causes drag, including driving with the windows down, will cost mileage.
    Corky Scott
  4. Oct 22, 2012 at 12:05 PM
    #624
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    Truck Nuts!!!
  5. Oct 23, 2012 at 7:14 AM
    #625
    Charles Scott
    Vermont
    2007 Tacoma
    My information is that lugging an engine, any modern engine, does not damage it in any way. This is an old belief that some ascribe to early hyper fragile small bore racing engines that had to be kept revved up so as to make adaquate power and not damage the crankshaft bearings.
    But todays engines have plenty of oil pressure to protect the engine at any speed, including lugging it. In addition, todays oils have come a long way and are superior in almost every way to those of 40 years ago.
  6. Oct 23, 2012 at 10:02 AM
    #626
    exploringcarolina
    exploringcarolina Well-Known Member
    Bill
    North Carolina
    Installed a ScanGaugeE late last week with recommendations from others on this forum. Found I was getting lower MPG by not shifting to 5th sooner, previously shifted around 50MPH. Tried shifting to 5th at 45MPH going "easy" on the gas pedal on mostly level roads yesterday. Two 35 mile local trips mixed with interstate driving up to 65MPH and not loaded, got an average between 30 to 31MPG during each trip.
    Purchased the ScanGaugeE to help find better MPG towing the TT Camper, but found my non towing driving habits needed improvement, too.
  7. Oct 23, 2012 at 6:14 PM
    #627
    Corndawg
    Corndawg Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
    for sure, driving no faster than 55-60 mph everywhere i go, no cruise control has helped my mileage. light foot. i have 33s with a 2.5 inch lift
  8. Oct 24, 2012 at 6:21 PM
    #628
    old dad
    old dad Well-Known Member
    mark
    sc
    tacoma pickup
    n/a
    My 2010 just ran 26mpg, mixed speeds up to 70 mph,,,it's still stock.
  9. Nov 6, 2012 at 7:10 PM
    #629
    Sandy sangha
    Sandy sangha Member
    Sandy
    Vancouver
    08 Tacoma trd 4x4
    wouldnt it be better if you change the cold air intake or just the filter
  10. Nov 7, 2012 at 7:29 PM
    #630
    paid4c4
    paid4c4 Well-Known Member
    Northern KY
    2015 4X4 TDR Sport, Auto Extended Cab
    Charles, I'm not disputing your information on engine lugging but I would like some more comments or data. I guess I've always been taught lugging an engine is always a bad thing and that it's time to change gears. I totally agree with you about the improved abilities of today's oil to provide better engine protection.
    Bill
  11. Nov 12, 2012 at 10:20 PM
    #631
    MrTacoma
    MrTacoma Well-Known Member
    Tacoma Base v6
    None
    Does Acetone ? work? if so how much do you put in and how often
  12. Nov 13, 2012 at 5:38 AM
    #632
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    No
  13. Nov 14, 2012 at 6:52 AM
    #633
    Trabs
    Trabs New Member
    Dillon
    Alberta , Canada
    Inbetween Rides.
    Still Lookin...
    Driving Habits make a huge differnce. Keep your tires filled and fluids topped. Dont use tune ups in a can. Toyota and other Companies engineer vehicles to perform the way they do, Dont expect a 250$ intake system to out perform or enchance your tacoma in great amounts.
    Lighten your truck , remove uneeded weight ( not the spare ).
  14. Nov 14, 2012 at 8:16 AM
    #634
    goufcustom
    goufcustom 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    Bought a 1990 Miata, it gets 32mpg on the highway, and looks better than a Prius.
  15. Nov 15, 2012 at 3:54 AM
    #635
    Charles Scott
    Vermont
    2007 Tacoma
    I was taught that too. Way back in the late 60's when racing autos interested me I used to read a lot of car magazines. I happened to be reading Car and Driver, an article about a modified Camaro written by Brock Yates. He was driving the car around with the car's owner/builder. The engine was highly modified with special carburation, a full race cam and high compression pistons. Yates was describing how he was driving around while talking with the owner and realised that he was lugging the engine and apologised. The owner, who had been building engines for a long time, responded that the idea that lugging the engine, even such a high performance engine, would damage the bearings was a myth. The oil pump supplied adaquate pressure to float the crankshaft at even the lowest rpms he said.
    This was back in the late 60's, as I mentioned, and oils have been improved greatly since then. When I was an auto mechanic, I never heard of an engine being damaged by lugging, under any circumstances. We even had a Mazda come in that had broken the chain that drove the oil pump. The owner noticed that oil light was on while driving down in Boston. He drove it all the way back to Vermont at normal highway speeds because he thought it was just a malfunctioning light. When we discovered that the oil light was on because the oil pump chain had broken, we tore the engine down to check the bearings. No damage, and we REALLY looked them over. We conjectured that the engine was lubricating itself by the crankshaft arms splashing in the oil, but I'm really not sure. The oil showed a bit high on the dipstick so that might have been possible, but it's remarkable never the less.
    Charles Scott
  16. Nov 21, 2012 at 3:23 PM
    #636
    k17d27m29
    k17d27m29 New Member
    Alabama
    Stock 10 model crew cab
    I want to put a programmer in an also a new air filter an possibly exhaust Iam new to this toyota because i drive a 2500 hd duramaxx. Any help or suggestions will be appreciated.
  17. Nov 21, 2012 at 5:15 PM
    #637
    worthywads
    Assuming you are try to improve MPG then the exhaust and intake are not recommended.
    The programmers I am aware of are only good for wide open throttle. Not helpful for better mpg either.
  18. Nov 21, 2012 at 6:54 PM
    #638
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    Yeah, I think that many of us probably hoped that there were loads of bolt-on gadgets that would boost our fuel economy, but there aren't many.
    synthetic oil
    Scanguage/Ultraguage
    Tonneau cover
    smaller tires/rims
    The guages might be the most important: gives you feedback while educating yourself to drive smarter. Driving 'blind' and following the tips the others have given will get you pretty far, but the guages help you to dial in on your specific vehicle configuration.
  19. Nov 26, 2012 at 1:19 PM
    #639
    euro911s
    euro911s 'Plays with Toys'
    Mark
    So Bay, So Cal
    96 Tacoma 4x4, V6, Ex Cab
    I used to have a a TRD supercharger on the Tacoma, converted back to NA when I bought the Tundra. The SC was tons of FUN!!!
    My first Toyota was an '89 X-cab, 4x4, 2.4L EFI. I installed 30x9.50-15 tires and a Competition 'Sprint' camper shell (125 lbs). It only got around 15~16 mpg in the city, but mid to high 20's on the highway. It didn't have enough power to pull a trailer, so I sold it in '96 and bought a new Tacoma 4x4 X-cab, 3.4L with 31x10.50-15 tires (also installed a Competition 'Sprint' shell).
    The Tacoma only got 14~15 in the city. I installed a Magnuson (TRD) supercharger when they came out and it reduced the fuel economy about 1 mpg. Gas was fairly reasonably priced then so I didn't mind ... the increase in HP and torque was worth it. It made pulling a trailer a pleasure. The only problem was the TRD was not intended for installation on 3.4L engines until '97 (EGR and different ECU) and I had to reset the ECU every 5k miles.
    In 2002, I bought a new Tundra LTD Access Cab, 4x4, 4.7L V8, LSD for towing purposes and planned to sell the Tacoma. I removed the supercharger from the Tacoma shortly after. The mpg went back up to 14~15 city, 17 highway.
    Well, against my wife's wishes, I kept the Tacoma and recently joined this forum to gain technical insight on maintaining it (except for oil changes and brake jobs, we always had it serviced at the local dealer where I purchased it). Time to change the timing belt, water pump (and possibly head gaskets), and I want to do the repairs myself.
    I installed an Afe dry filter element on the Tacoma a month ago and have noticed an increase of about 1 mpg in both city and highway. I also noticed a little more pep going up freeway on-ramps.
    I recently changed the tires on the Tundra - went from the original 265/65x16 to 245/70x16 (.78" narrower and a 'smidge' taller). I immediately realized a 2mpg increase in mileage both city and highway . I just purchased an aFe dry filter for it and will check to see if it helps any. I'll report back my findings after a few tank fulls.
    I may go with one size narrower tires on the Tacoma (unless I sell it prior to needing new tires).
  20. Nov 27, 2012 at 6:54 AM
    #640
    cowboy50
    cowboy50 Well-Known Member
    Dexter,MO
    05 Tundra 4x4
    Just ordered an AFE filter for my 01 even if I don't gain much performance improvements, it will pay for itself in four oil changes at 15.00 bucks a pop for OEM at Wally World. One thing I just rolled 200,000 on my first 2.7, is there anything that needs to be checked after that many miles? Lifters or anything? No probs just wondering otherwise we'll just keep bumping along.
