MPG Mods
Discussion in '4 Cylinder' started by kylefrdavis, Apr 20, 2009.
  1. Apr 20, 2013 at 11:34 PM
    #721
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I also have a 1996 4 cyl, std cab, 2wd, with a 5 speed stick.
    And I run Hankook Optimos. They only needed very small weights to balance, they roll really smooth, and I get 25mpg around town and 28 on the highway.
  2. Apr 20, 2013 at 11:38 PM
    #722
    tooter
    Greg
    Los Angeles
    I recently did two mpg mods on my 2012 2.7 5 lug. I installed a LCE header for more low end torque...
    bth_63eecebd-d227-4758-af55-202fc9a4543c_9c017dcc6f4dd09b5146f1af5c8294646a92cc9a.jpg
    ...and I removed the power steering and AC, so now a simple small non serpentine belt only drives the alternator and water pump.
  3. May 7, 2013 at 11:38 PM
    #723
    TCBSU
    TCBSU New Member
    As far as load boosters. My wife and I moved from East Coast ot CA and carried a decent amount in the bed in addition to towing a trailer. Our Tacoma did fine with no mods. We even took some side trips on gravel/dirt roads pulling the trailer with her Corola on it (also loaded up beofre being onlaoded). The only problem the whole way was a broken cargo strap on the trailer. So I would not waste money on anything to help carry more load. BTW I have also done a few local moves with just lots of stuff in the bed and not had a single issue. Good luck with the move.
  4. May 8, 2013 at 12:24 AM
    #724
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Man, you aren't kidding around. I like getting good FE but I dislike sweating all over myself more so I had AC installed.
    Good call on LCE btw. I'm definitely enjoying their model header for my Pickup as well :thumbsup:
  5. May 8, 2013 at 8:50 AM
    #725
    piglett
    piglett Member
    wolfeboro,nh
    01 exstended cab TRD
    i added a set of helper springs to my 95' toyota pickup
    however it was common for me to haul 55 gallon drums filled with break rotors down to the scrap yard (1 hour away)
    i crossed the scales more than once with 2700lbs in the bed
    the stock springs were just not up to the job
    so i installed a set of coils rite between the under side of the frame & the top of the rearend. i may end up doing the same on my 2001 TRD
    but so far it has been alrite.
    good luck
    piglett
  6. May 8, 2013 at 3:15 PM
    #726
    Fish Killer
    Fish Killer Active Member
    kai
    ventura
    base 2003, base 2012
    2003 Tacoma Injen Cold Air Intake. Bosch x4 Spark Plugs. Manual 5 speed 2012. Tacoma Stock, Manual 5 speed. Soon not to be. (Planned Headers, CAI, Muff)
    Get 2 air filters! the extra pays off, when you are cleaning one of them.
  7. Jun 1, 2013 at 7:29 PM
    #727
    halemauka
    halemauka New Member
    Denver
    '08 Tacoma
    none
    Want better gas mileage? Get a Harley!
  8. Jun 2, 2013 at 7:09 AM
    #728
    piglett
    piglett Member
    wolfeboro,nh
    what a joke
    everyone i know that rides a bike has atleast 1 dead friend:eek:
    so i think i'll pass!
  9. Jun 2, 2013 at 7:27 AM
    #729
    tooter
    Greg
    Los Angeles
    I enjoy driving a simple fuel efficient vehicle. :)
    We don't have air conditioning in our home either, and have found that without external compensations your body naturally adapts to changing seasonal temperatures by widening its comfort zone. AC narrows your comfort zone until just a few degrees out of it and you're miserable.
    I always run LCE headers on my Tacomas. Had one on my 1996 for over a decade.
  10. Jun 2, 2013 at 7:35 AM
    #730
    Joshman35
    Joshman35 Well-Known Member
    Josh
    White Mountains, Arizona
    09 Tacoma Custom
    Too many to list
    Want something reliable? Beg the persons you sold your Toyota too, to sell it back because you bought a crap Harley that breaks down every morning, burns or drips way too much oil, and tops out at 80mph
  11. Jun 11, 2013 at 3:15 PM
    #731
    amberger
    amberger New Member
    My new 4 cyl access cab 4x2 should be delivered late this week (Yay!). I was planning on getting an aftermarket bug guard. Has anyone seen any difference in mileage due to the wind resistance changes caused by a bug guard?
  12. Jun 11, 2013 at 4:56 PM
    #732
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Can't imagine it helping. I haven't found the need for a bug guard, you don't need one.
  13. Jun 22, 2013 at 1:04 PM
    #733
    Lil blue rocket
    Lil blue rocket Member
    Montegut LA
    08 PreRunner Offroad SR5
    Cold air intake, 3" lift
    What size engine do you have and what transmission cause I'm turning 33's on my 08 with the 4.0 and I'm only getting 16 driving like a grandma !
  14. Jun 22, 2013 at 3:49 PM
    #734
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    You wouldn't believe how many bugs the windshield picks up with the top two slats of the upper grill blocked off. It boggles the imagination!
    I don't see a bug guard helping mileage at all either. Adding turbulence usually doesn't do good things to airflow.
  15. Jun 27, 2013 at 9:25 AM
    #735
    YotakingO
    YotakingO Well-Known Member
    88 TOYOTA PICKUP 2.4L 4X4
    Stock for now
    I have a 88 Toyotat pickup ( 2.4L) and my MPG is 11mpg. WHiCH is CRAZY! I am trying to up that.. any ideas?
  16. Jun 28, 2013 at 4:12 AM
    #736
    cowboy50
    cowboy50 Well-Known Member
    Dexter,MO
    05 Tundra 4x4
    How long has it been since a tune-up. Fuel filter, plugs, wires, injector cleaner. Maybe try that seafoam trick alot have been talking about. Need to do it before an oil change, since you will need to change it right after. I've had an 87' and an 88' both extra-cabs never could get any better than 19. One was a stick the other was an auto(hated it).Bet it just need's a little luv.
  17. Jun 28, 2013 at 8:36 AM
    #737
    tooter
    Greg
    Los Angeles
  18. Jun 28, 2013 at 6:24 PM
    #738
    tooter
    Greg
    Los Angeles
    Hey, just happened to get this email from LCE today.
    lcengineering.com
    They're having a 10% off sale on everything that's in stock!
    Coupon code: USA
    That would make a 2TR FE 2.7 header only $405 plus shipping. :eek:
  19. Jul 8, 2013 at 11:27 AM
    #739
    janinesfishtales
    janinesfishtales New Member
    Janine
    San Diego, CA
    4x4 pre-runner
    side step rails, Leer camper shell
    Hi. I'm new to this site. My name is Janine. I initially found this forum because I am looking to buy a lite travel trailer for my 2013 Tacoma. I have a 2013, 4x4, Pre-Runner, Double Cab with a Leer camper shell. The color is Pyrite Mica. I love it! This is the 2nd Tacoma I have owned. I recently sold my 2002 to my uncle and it is still running strong. I will always have a Tacoma! I am looking forward to talking to some of you, especially about travel trailers suitable for my rig.
    Janine
  20. Jul 8, 2013 at 12:42 PM
    #740
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Welcome to the forum Janine, :rimshot:
    Lots of good info here on any subject. Mods R Us
    Need a pic of the Tacoma, it sounds nice!!
