MPG Mods
Discussion in '4 Cylinder' started by kylefrdavis, Apr 20, 2009.
  1. Aug 26, 2013 at 6:04 PM
    #781
    bbatka
    bbatka Member
    brad
    chicago
    96 taco 4x4
    Amsoil in both differentials and transfer case..... 1.3mpg gain. Amsoil signature oil and I'm getting 2 mpg over stock.
    Just to clarify, the 4x4 will see greater gains by going synthetic because of the extra differential & t-case. I'm not saying you 5 lug guys wont' see gains, just that the 6 lug people will see more of a gain by going synthetic with the additional differential and transfercase because the 4x4 is pushing that many more gears.
    I called Amsoil, and they say their ATF fluid will not void factory warranty..... I will call Toyota tomorrow to confirm. I will call all the way to corporate if I gotta.... will post as soon as I know.
    I got my reply from Amsoil.....
    [FONT=&quot]Brad,[/FONT]
    [FONT=&quot] [/FONT]
    [FONT=&quot]Multivehicle ATF meets the Toyota T-III and T-IV specifications. ATL meets the Toyota WS specification. The use of the product does not void Toyota manufacture warranty. It is recognized as meeting the specifications, and printed on the fluid label. However, it is not recognized on and “approved” list. AMSOIL does not pay companies to be listed. [/FONT]
    [FONT=&quot]Thanks[/FONT]
    [FONT=&quot]Ashley Barone[/FONT]
    [FONT=&quot]AMS[/FONT][FONT=&quot]OIL[/FONT][FONT=&quot] Technical Services Representative[/FONT]
    [FONT=&quot]abarone@amsoil.com [/FONT]
    [FONT=&quot]AMSOIL INC- AMSOIL Building[/FONT]
    [FONT=&quot]Superior, WI 54880[/FONT]
    [FONT=&quot]TEL [/FONT][FONT=&quot]715.392.7101 [/FONT][FONT=&quot]EXT[/FONT][FONT=&quot] [/FONT][FONT=&quot]6098[/FONT][FONT=&quot] -FAX [/FONT][FONT=&quot]715.392.3097[/FONT]
    [FONT=&quot]www.AMSOIL.com[/FONT]
    the web page for drain intervals is:
    http://www.amsoil.com/lit/g1490.pdf?gear-lube
    The drain interval for ATF is the same, so I would be most interested in focusing on the manual trans& differential& transfer case for the longer life and reduced friction to realize noticeable MPG gains.
  2. Sep 28, 2013 at 1:24 PM
    #782
    Patrol42
    Patrol42 New Member
    That's for a V6 right? If so that is a pretty nice bump!
  3. Oct 9, 2013 at 11:03 AM
    #783
    jimmyd
    jimmyd New Member
    2013 prerunner sr5
    Hi! I just joined, had my 2013 Tacoma about 2 months now. I am installing fog lights, and the wiring is giving me some problems mainly no instructions or skematics. Any one know what to do with this mess of wires?
  4. Oct 9, 2013 at 3:02 PM
    #784
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Hey Jimmy, :wave:
    Welcome to Tacoworld.
    You could try starting a separate thread in the 2nd gen forum. Be sure to post some pictures of your problem, and put your lighting question as the title.
    There are a lot of very knowledgeable people here and someone will have an answer. I don't know shit about car wiring, but others do. :thumbsup:
    Greg
  5. Oct 15, 2013 at 9:13 AM
    #785
    AeroKen
    AeroKen Well-Known Member
    Kendrick
    Littlefun, CO
    2wd Tacoma, 2.7L 5spd
    None so far
    I noticed that most people seem to agree that larger tire-diameters hurt fuel mileage, but I'm wondering how many of those folks are still going by the stock odometer to track fuel. It's true that it most likely hurts your fuel mileage for city driving, but there's a good chance that at least the taller street tires improve highway MPG, but you'll never know unless your odometer or method of miles-tracking is accurate. Otherwise, it's sure to hurt your MPG, since it looks like you're going shorter distances than you actually are.
    Just food for thought. Sorry if it's a dead horse.
  6. Oct 15, 2013 at 1:53 PM
    #786
    tooter
    Greg
    Los Angeles
    Larger diameter tires do effectively raise the final gear ratio so that the engine is turning slower at any given speed. This would favor better freeway gas mileage. But what works against better gas mileage is the heavier rotating wheel and tire weights. There's an old rule that one pound of rotating weight equals ten pounds of static weight. With different wheel diameters you also throw off your odometer reading, so that you would need to use a percentage correction factor when computing gas mileage, to adjust for the slower turning wheels.
  7. Oct 15, 2013 at 2:48 PM
    #787
    AeroKen
    Kendrick
    Littlefun, CO
    None so far
    That's the thing. I wouldn't be surprised if half the people reporting worse MPG after the bigger wheels/tires are put on, are actually getting BETTER MPG.
    It all depends on driving conditions. I think someone who puts on mostly highway miles will likely see a net gain. The added weight is less of a factor at higher speeds, going downhill, extra weight even helps.
    Anywho, someone else's MPG doesn't really factor in to my own, but there just seemed to be a lot of universal agreement that it will suffer no matter what.
  8. Oct 15, 2013 at 6:50 PM
    #788
    tooter
    Greg
    Los Angeles
    Yes. That's entirely possible, because the odometer would register less than the actual traveled miles. I'm not sure how many people actually go through the time and trouble to change their speedometer gears when they put on big heavy large diameter off road tires.
    That's also possible, but only at a constant speed. As once a flywheel is rotating that energy needed to spin it remains stored within it as the inertial resistance to changing speed.
    The problem is stop and go driving. As it takes more energy to get those four heavy flywheels spinning. When the brakes convert that energy into heat to slow down or to stop... that energy is lost and the next acceleration also takes more energy.
  9. Oct 15, 2013 at 7:00 PM
    #789
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    My MPG went up after going from heavy stock wheels and 245/75-15 tires up to lightweight wheels (18ish lbs) and 265/76-16 tires (about 40 lbs) simply because of the taller final gear ratio (especially on the highway while under 70) but also because I shed unsprung weight at the wheels/tires in the process. Works great when you only have about 125 horses working for you.
    I do correct for the odo difference of 11.9% and have checked that percent/new speed with gps and speed trap things. It's right on the money.
    I enjoy having oversized tires AND netting about 20% above EPA in the winter :D
  10. Oct 15, 2013 at 7:02 PM
    #790
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    This is old, from July 25th at the most recent fill up. But my record for the Summer was last week. I got 24.25 MPG and didn't even go under the speed limit to achieve it.
  11. Oct 24, 2013 at 10:54 AM
    #791
    talisker
    talisker Well-Known Member
    Scott
    Vermont
    06 TRD Off Road SR-5 W/1 Ton wood pellets
    Firestone Ride Rite airbags
    I've got the 4.0 and 6speed transmission. What is the deal with 6th being geared so low? 72mph is 2500rpm. This motor has way more power than what is necessary to maintain cruising speed at much lower rpm. I wish 6th was around 1900rpm. I have to think if it was, I'd get a lot better gas mileage over the highway.
  12. Oct 27, 2013 at 5:41 AM
    #792
    piglett
    piglett Member
    wolfeboro,nh
    01 exstended cab TRD
    slow down some so the rpm is lower. what rpm are you at when you run 65mph?
  13. Oct 27, 2013 at 11:05 AM
    #793
    tooter
    Greg
    Los Angeles
    Any off road truck will always have lower gears.
    My 5 speed 2 wheel drive came with 3.31 street gears, so 60 mph is 2,000 and 75 mph is 2,500 rpm. But that's with the smaller 4 cylinder 2.7.
    I would think that your 4.0 would be powerful enough to push higher gearing and am surprised that the 6 speed doesn't have a wider range of ratios.
  14. Oct 27, 2013 at 7:03 PM
    #794
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    T
    Yea when I put on my bigger tires my mpg's didnt change much either. Did the same thing as you went from steel to aluminum wheels and calculated for the % change in tire circumference into my mpg calculations and still got pretty much stock mpg's. Gotta stay off the interstate and the go pedal to do that though. I had people call me a liar because they couldn't get close to my mileage, but I could make a 5 lug manual get 10 miles per gallon if i drove it like an asshole.
  15. Oct 27, 2013 at 7:30 PM
    #795
    Nathan
    Nathan Well-Known Member
    Nathan
    Frederick County, MD
    2010 5 lug single cab
    Whats the best tires for the 5 lugs in regards to mpg?
  16. Oct 27, 2013 at 7:37 PM
    #796
    BuzzardsGottaEat
    Some Toyotas
    Round tires
  17. Oct 27, 2013 at 8:17 PM
    #797
    Nathan
    Nathan
    I hear those recommended a lot, but the smallest size is 235/75/15. Will they make up for the extra size/weight?
  18. Oct 27, 2013 at 8:24 PM
    #798
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    What size are your tires? 255/75?
  19. Oct 27, 2013 at 8:30 PM
    #799
    Nathan
    Nathan
    I have one of the small trucks, 215/70/15
  20. Oct 27, 2013 at 8:35 PM
    #800
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Yeah I just looked up the stock size. It had slipped my mind.
    Honestly, from what I've read of people going up to a 235 they have lost 1-2 mpg, however most if not all had gone to a more aggressive tire than this one so I don't know. The lower overall effective gear ratio may help you on the highway (it did for me) but I would guess you would still lose one or so around town if others reports are accurate. Only way to easily counter it is lightweight wheels like SCS F-5s for the 5 lug and the MS2s are pretty lightweight as well.
