MPG Mods
Discussion in '4 Cylinder' started by kylefrdavis, Apr 20, 2009.
  1. Mar 12, 2015 at 1:21 PM
    #1061
    bigmac34
    bigmac34 New Member
    Phil
    Indiana
    06PreRunnerTRD
    I have been Tacoma, 4cylinder owner for about 30 years. Recently I bought
    a 17' Casita travel trailer. It was a load for the 07 Tacoma. So I traded in
    the 07 for a 06 PreRunner, 6 cylinder, with TRD. I get a much better ride
    with the PreRunner, and the 6 cylinders take the hills with ease. I changed
    the oil today for the first time. It is much easier changing the oil filter. I
    took a small water bottle (empty), tied a cord around it to hold the bottle
    on to the drain pipe so as to catch the oil while replacing the filter. It worked so well and I hope other readers will try this.
  2. Mar 12, 2015 at 1:37 PM
    #1062
    Yota64
    Yota64 Professional Threadjacker
    Welcome to TW! I use a plastic hose and guide it down to the used oil pan.
  3. Mar 18, 2015 at 6:02 PM
    #1063
    Mikeyjd
    Mikeyjd MPG Enthusiast
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    Grill Block, Front Belly Pan, 3 inch lift shims in front, AAL rear suspension lift, Ultragauge Instrumentation, Flush Topper, Full Synthetic Fluids
    Now that we've made through winter and I no longer must rely on the v6 4x4 for it's capabilties, I splurged ($1,000) and got a flat bed 4 banger manual trans 1st gen Tacoma with 170,067.4 miles on the odometer. It's rough around the edges to say the least, but it rides nice. I got it home and dropped the oil and topped up all the fluids. It's a peppy little thing that I think I'll enjoy using this summer.
    Initial 10 mile roundtrip course with Pulse & Glide driving without Engine Off Coasting yielded 37.7mpg uncalibrated on the Ultra Guage. This was after airing the tires to 44psi and removing the passenger wiper. This truck has much taller gearing than the V6, so I found myself wanting to shift early. It doesn't have a tac either which I'll have to add to the front screen on the UG. The UG also powers down when I key off, so I will need to wire in a kill switch in order to EOC.
    I'm excited as this truck is already showing promise and has alot of aero possibilities on the table. First mods to do are:
    Grill Block
    Kill Switch
    Replace brand new rear winter tires with used summer ones
  4. Mar 18, 2015 at 7:04 PM
    #1064
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
  5. Mar 19, 2015 at 4:00 AM
    #1065
    zakattak
    zakattak Well-Known Member
    Zak
    California, MD
    2015 TRD Sport DCLB
    ok so in home testing results...one MPG Mod at a time to see the difference!
    I took the stock air filter out and replaced it with a Specter cold air intake right off the side of the intake box...
    I confirmed 4 tanks of gas at normal driving stock to 15.4mpg
    the very next tank of gas with the cold air intake is 16.7mpg
    and 16.6 after that and working on the third tank now.
    this is just my own personal test, the ONLY thing I have changed is the intake.
  6. Mar 19, 2015 at 5:25 AM
    #1066
    Mikeyjd
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    That is an unreliable way of testing a modification like this. Good ABA Testing is required to accurately quantify any mods you do.
    Fuel consumption is remarkably sensitive to all kinds of variables:
    ambient temperature
    wind
    humidity
    barometric pressure
    vehicle temperature (not just engine, but the entire drivetrain including transmission, joints, bearings, tires)
    fuel grade/quality
    payload
    elevation/road grade
    road surface conditions / type
    speed
    other traffic
    driving style / driver psychology
    Here is a graph posted by a respected forum member on ecomodder showing the relationship between temperature change and fuel economy.
  7. Mar 19, 2015 at 5:30 AM
    #1067
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    http://www.tacomaworld.com/forum/performance-tuning/349020-free-mpg-mod-maybe.html i tried the same thing basically this winter with decent results but i just used the stock filter location. i noticed that i could get about 40* increase over ambient temps once the truck warmed up, and i could maintain it as long as i didnt drive over 55mph or so. in one page i got really mathy and slightly assumptious and decided i was saving roughly 1 gal per 650 miles or so at my average driving rpms.
  8. Mar 20, 2015 at 1:41 AM
    #1068
    Mongo1958
    Mongo1958 Well-Known Member
    Van
    Newnan, GA
    2015 Bright White Access Cab w/convenience pkg.
    Carbon filter removal. Intermittent Wiper Stalk. Cruise Control. Fog Lights.
    The Link you provided to find AFE filters does not have any AFE filters that fit my truck. :confused:
  9. May 4, 2015 at 8:06 PM
    #1069
    Nor7
    Nor7 Well-Known Member
    Eric
    Texas
    2011 Tundra, Texas Edition
    Wanted to share this: Helped my MPG a little bit.
    Thanks for reading. I just created this tutorial video regarding how to treat your engine with Seafoam. I know there are haters that don't believe in it and swear by other products but I love the stuff. It can be used on any engine (gas or diesel), and I've noticed an improvement in performance.
    Enjoy
    https://www.youtube.com/watch?v=Y-UIg5djOmU
  10. May 6, 2015 at 7:27 AM
    #1070
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    No ill effects on O2 sensors or cat? I am getting 18 to 19.5 mpg on my stock 2010 i4 prerunner, switched to all synthetic gear and engine oils with little change in mpg. I keep shift points at just above 2000 rpm. My best tank was after stomping on the peddle for a tank, 16.5 mpg. The next tank was my best at 19.5 mpg, why I'm interested in carbon blow out. Truck bought used in 2014 with 32,000 miles on it, 45,000 miles on it now.
  11. May 6, 2015 at 11:21 AM
    #1071
    Nor7
    Eric
    Texas
    No concerns here. My brother uses it all the time in an assortment of various vehicles and equipment and has never had a problem. I'm sure if you used it every day you'd get some sort of build up since you'd be blowing smoke all the time.
  12. May 6, 2015 at 1:00 PM
    #1072
    23Skidoo
    Paul
    meme
    I'll give it a go this weekend.
    Thanks
  13. Oct 25, 2015 at 12:54 PM
    #1073
    jasontojo
    jasontojo Well-Known Member
    jason
    west virginia
    SR tacoma 4x4 2.7L
    5100 Bilsteins, Toytec Fr coil lift springs, Deaver AAL packs, Mobtown tailgate reinforcement, Intermittent wiper switch, ECGS Fr Diff bushing
    installed the AFE pro dry filter. I would recommend this upgrade for sure thanks fellas for the write ups. I did not see much of a MPG gain however I have noticed a power increase and having the 2.7l I will take all that I can get. I have noticed that I get better mileage if I get pure gasoline, around 23 MPG where as I only get 20 with ethanol cut crap. thanks again for the write up.
  14. Nov 14, 2015 at 1:56 PM
    #1074
    tacostache
    tacostache Active Member
    2013 Base Model
    intake and headers
    i just installed an afe pro dry s filter and removed the charcoal filter. i definitely notice a bit of power gains but i'll have to give it another week or so to see if mpg has improved. i was averaging 23-25 mpg before. if mpg stays the same i'll still be satisfied. cheap and easy mod i can't complain.
  15. Nov 14, 2015 at 2:07 PM
    #1075
    jasontojo
    jason
    west virginia
    SR tacoma 4x4 2.7L
    do you have a 4x2 or a 4x4, because I have not seen any significant MPG gains, only power. I also removed my charcoal filter and now notice pedal drop where I didn't before. I had it on my old chevy 4x4, must be because that it breaths easier.
  16. Nov 14, 2015 at 3:04 PM
    #1076
    tacostache
    2013 Base Model
    intake and headers
    i have a 4x2. i'm not sure what pedal drop is but i definitely feel it breathing much easier. i spend most of my weeks stuck in traffic so i don't know how much mpg gains i could see :p
  17. Nov 15, 2015 at 3:09 AM
    #1077
    jasontojo
    jason
    west virginia
    SR tacoma 4x4 2.7L
    pedal drop- you feel the gas pedal slap your foot due to engine pressure pulling on the throttle
    tacostache likes this.
  18. Nov 15, 2015 at 8:25 AM
    #1078
    worthywads
    Is that a joke?
  19. Nov 15, 2015 at 11:02 AM
    #1079
    jasontojo
    jason
    west virginia
    SR tacoma 4x4 2.7L
    No this is not a joke. You've never experienced this? I've had several older Chevy 4x4's that where standards "like my Yota" and when I would downshift or lay off of the pedal the gas pedal would slap my foot. Pedal Drop, just as it implies. I noticed that my truck now does this since I have installed a High flow filter and removed the charcoal filter installed in the air box from the factory. I may not be a tech but I have worked on and built trucks for 20 yrs. I am pretty sure that my 2.7 is fuel injected and not a throttle body that's why I am scratching my head on this one. The only time I have experienced this was with carbureted models. The butterfly would get sucked open causing the accelerator pedal to tap your foot. Maybe you might have an explanation as to why my pedal drops like that.
  20. Nov 15, 2015 at 11:31 AM
    #1080
    worthywads
    You have drive-by-wire.
    rodehard likes this.
