MPG Mods
Discussion in '4 Cylinder' started by kylefrdavis, Apr 20, 2009.
  1. Sep 19, 2016 at 3:53 PM
    #1101
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Yeah some narrower so less surface on the road and lighter i would assume so again it should help a lil
    Br3w_ski[QUOTED] likes this.
  2. Sep 19, 2016 at 6:45 PM
    #1102
    Br3w_ski
    Br3w_ski Well-Known Member
    Bruce
    San Jose, CA
    2007 Black Tacoma DCLB
    Definitely worth a shot! Thanks dude!
  3. Sep 19, 2016 at 6:53 PM
    #1103
    yota243
    E.J.
    north Alabama
    I wouldnt get ur hopes way up. 10% would be the most extreme increase i would think to be reasonable. But every little off it helps. Now if u didnt mind "pizza cutters" u could do 255/80 17(even narrower and lighter but the same height); i run 255/85 16s and can manage a touch over 21, but im only lifted about 2" and i coast alot and drive very conservatively.
    Are u adding any mileage for taller tires? I add 7.5% btw by the tire calc on here
  4. Sep 20, 2016 at 2:46 PM
    #1104
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    2025 SR5 4x4
    I got a 2004 prerunner. Anything I can do to help out my MPG? I plan to throw on a flowmaster muffler later this month.
    I have a 2" lift and I'm running stock wheels with a little bigger tire. Brigestone Dueler H/T's.
    I've read through the thread and have some better ideas but it seems a lot of them are going to extreme lengths just to add a few mpg's.
  5. Sep 20, 2016 at 5:46 PM
    #1105
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Muffler will not help mpg.
  6. Sep 20, 2016 at 6:10 PM
    #1106
    Tacotruck7
    SoCal
    2025 SR5 4x4
    Understood. I've heardconflicting things on it. Same with air filters and such.
  7. Sep 20, 2016 at 7:04 PM
    #1107
    yota243
    E.J.
    north Alabama
    In a pefect world 14.7 grams of air requires 1 gram of gas (about 14.0 of e10 which is what most gas is around here) the only way to burn less gas with engine adjustments is to put less air in. The only way other than that is to put less load on the motor, which may be slightly noticeable with a smoother intake and smoother exhaust i.e. headers and straight thru muffler. Im in the process of turboing my truck and right now im just running some 2.5" intercooler piping with a filter and i have a 2.5-3" reducer to my maf flange adapter then into my throttle body. I have noticed a slight decrease in the load and at idle about 20% less gph due to smaller intake piping.
    A scan gauge or the torque app will help u see where u are wasting fuel
  8. Oct 26, 2016 at 5:44 PM
    #1108
    Guitoma
    Guitoma New Member
    Gary
    2017 Sport Tacoma 4x4
    I installed a K&N cold air intake on my 2005 Tacoma and was pleased with this increased performance. Can't really tell if there was improved gas mileage but just looking at the difference between the very restricted factory air flow compared to the clear, unobstructed air flow of the new K&N 4" tube it was an improvement in performance (for about $170). It is a bit louder when accelerating hard but some may even like that :)
  9. Nov 5, 2016 at 8:59 AM
    #1109
    racecarbob
    racecarbob Member
    Bob
    2016 tacoma trd odd-road
    none
    For the first 10,000 miles my 2016 tacoma trd off road got 18.7 combined mpg. This was checked closely for the entire 10,000 miles.
    After my factory oil change and vehicle inspection the dealer seems to have done something to my truck. It seems to have more power and gets over 22 mpg combined for two tanks of gas.
    It may have just got broke in, I do not know but I like it much better. Will keep posting milage as it gets more miles on the truck.
    Hang in there.
    Race Car Bob
    every day above ground is a good day
    Mush Mouse and Governor like this.
  10. Nov 29, 2016 at 2:16 PM
    #1110
    pdxyota
    pdxyota Well-Known Member
    Greg
    Newberg, OR
    2005 4x4 5M 2TR-FE SR5 Access Cab Indigo Ink Pearl
    TSB x 2 because first TSB leaf springs broke
    I bought an aluminum shell, that is very, very light and sturdy enough to keep people out of it. Mine is 2.7L 4x4 access cab manual (2005). I'm running 265/70/16 BFGs at 32PSI and getting 22MPG average, probably 24 in the summer on trips.
    Mush Mouse likes this.
  11. Dec 5, 2016 at 11:42 AM
    #1111
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    23.51 mpg today, stock Doneflops at 34psi,just changed out the power steering fluid to synthetic Valvoline hope it boosts my mpgs up a few notches;)
  12. Dec 5, 2016 at 6:54 PM
    #1112
    Miami Chillin
    Miami Chillin Well-Known Member
    DCLB TRD Sport 4x4
    Man I just bought a 09 DCLB with 265/70/17s, roof rack, and a side mount tool box and I got only 14mpg driving all freeway for multiple tanks. Tire PSI was good. Filters were clean. I gotta check the spark plugs and change all the fluids. I didn't buy this truck for the MPGs, but seeing other peoples numbers makes me scratch my head. X-Runner got up to 22 on the highway. I know the rack, tool box, and tires make a difference but shit I wouldn't think by that much. Steady between 65-75 (depending on speed limit) on cruise control.
  13. Dec 6, 2016 at 3:58 AM
    #1113
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    V6?
  14. Dec 6, 2016 at 8:47 AM
    #1114
    Miami Chillin
    DCLB TRD Sport 4x4
    Yeup.
  15. Jan 23, 2017 at 6:58 AM
    #1115
    ChiliTaco
    ChiliTaco Member
    2017 Inferno Tacoma
    None at this time
    what about K&N?
  16. Jan 25, 2017 at 4:02 AM
    #1116
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Placebo effect. Cold aor intakes do nothing but empty your wallet.
    spacetiger likes this.
  17. Jan 25, 2017 at 6:32 AM
    #1117
    ChiliTaco
    ChiliTaco Member
    2017 Inferno Tacoma
    None at this time
    Well there has been dyno proof that you get 3 to 10 more HP with proper CAI install
  18. Jan 25, 2017 at 8:21 AM
    #1118
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    I call bull shit.
  19. Jan 25, 2017 at 11:20 AM
    #1119
    0311K1LL
    0311K1LL The Old Breed
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    OME 887 w/Bilstein 5100's, 1.5 AAL, SPC LR UCAs 285/75/r16 Toyo AT2s!
    on the top end there is, but you won't notice anything. 5-10hp does nothing, won't move the truck.
  20. Jan 25, 2017 at 11:54 AM
    #1120
    worthywads
    This thread is about mpg, why does it have to be repeated, it called MPG Mods.
