MPG Mods
Discussion in '4 Cylinder' started by kylefrdavis, Apr 20, 2009.
  1. May 23, 2017 at 12:22 PM
    #1161
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Try 65 MPH and see what happens.
    MadDaddy likes this.
  2. May 23, 2017 at 12:35 PM
    #1162
    SilverJack
    SilverJack no one
    I get run over by semis and Prikuses (I think that's the plural of Prius). Honestly, at 70 MPH people pass me like I'm stopped. Florida got some crazy drivers.
  3. May 23, 2017 at 1:49 PM
    #1163
    Sheepshead45
    Sheepshead45 Well-Known Member
    NC
    PreRunner SR5
    Keeping it under 65 and inflating the tires to 38psi are the 2 most significant ways to improve your MPG from stock. Everything else has an insignificant result, at least in my experience.
  4. May 24, 2017 at 10:54 AM
    #1164
    uwu
    uwu Well-Known Member
    It's like that everywhere... sucks! I avoid the interstates when I tow anything, unfortunately.
  5. May 24, 2017 at 7:41 PM
    #1165
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    Where I live it's Ford Super Duties that run you over and that's if you're doing 75 or 80 mph. There are the semi's to add to that, of course. I was driving home one night and I was doing 95mph and a semi was still gaining on me so I just pulled over and followed him. I clocked him at a steady 90 mph for a while.
  6. May 24, 2017 at 9:29 PM
    #1166
    Bmello
    Bmello Member
    Bill
    2016 Quicksand 4 x 4 off-road Toyota Tacoma
    I was told to put the ETC button on to improve mpg on the freeway, it did not make sense to me so I tried it out for A 40 mile round-trip on the I 20 and found with it on I got 16.5 MPG and with it off I got 19.5, So I'm not believing in the dealer on that one
  7. May 25, 2017 at 10:13 AM
    #1167
    DGXR
    Friend
    Sacramento, CA
    That is nuts! My normal commute I keep it at/below 65 most of the time and nearly everyone is passing me but not like I am stopped. Longer drives (road trips etc) I can actually make some time cruising 75. Not sure what to say of your situation but for safety's sake it sounds like you don't have a choice but to cruise at 70 minimum.
    My tire pressure monitor will light up if I go that high. Not at cold pressure of course, but if I start with 38, at road temperature the pressure will go to nearly 44 psi and the system on my truck does not like that. I learned that one the hard way. Now I run 34 front and 32 rear, stock 5 lug size (215/70R15). No problems, good balance between grip and economy.
    BillsSR5 and TRDSport10 like this.
  8. May 31, 2017 at 7:42 AM
    #1168
    Indy
    Indy Master of all I survey.
    Reset your monitors when the pressure is up. They don't monitor actual pressure, just a change in pressure. If you reset when you have low pressure, they won't trip in a flat. If you reset when you're high, they won't trip because you're high.
  9. May 31, 2017 at 7:52 AM
    #1169
    Indy
    Speed is the biggest factor in a vehicles mpg. An engine will reach peak efficiency at a certain speed (rpm not mph). A vehicles shape will reach peak efficiency at a certain speed (mph). At a certain point the 2 put together will be as efficient a combination as possible even if 1 or the other isn't at peak.
    When you're under that combination, your mpg drops. When you're over it drops again. The faster you move the greater the drag created. And drag increases at a square to velocity.
    The downside there is peak mpg is rarely (at least around here) a speed that keeps others from parking their car in your trunk.
  10. May 31, 2017 at 9:10 AM
    #1170
    SilverJack
    SilverJack no one
    It also doesn't help that I live in a state that encourages stupid driving: http://www.fox13news.com/news/local-news/114281038-story
    If I keep to the left or middle lanes I risk getting a ticket from the local cops; and driving in the right means I'm going too fast for the people trying to merge. The middle sucks cause I get passed on both sides and feel trapped. I have to remind myself I'm driving 2 tons of pickup truck with an elevated steel rear bumper. People might get upset but they really don't want to hit me intentionally. I'm going to stay at 70, since 75 kills my mileage and I get passed by the crazys anyway.
  11. May 31, 2017 at 3:19 PM
    #1171
    DGXR
    Friend
    Sacramento, CA
    And this is exactly what lies at the heart of our MPG dilemma. I'd be happy driving 62mph most of the time if it did not pose a safety risk to everyone.
  12. May 31, 2017 at 9:18 PM
    #1172
    Indy
    I moved to fl about a year ago, drivers definitely suck.
  13. Jun 2, 2017 at 7:14 AM
    #1173
    SilverJack
    SilverJack no one
    I've been in FL since the early 70's and it's getting worse. The state always had bad drivers, but now there are more people and the same amount of roads. I can't move due to family obligations, so my alternative is to drive the biggest vehicle I can afford (mpg-wise).
  14. Aug 3, 2017 at 7:41 PM
    #1174
    Timothy Abbott
    Timothy Abbott New Member
    Timothy
    2017 Silver TRD Sport
    I just came back from Pismo Beach with a truck bed full of camping gear covered with a hard bed cover and got 24.9 MPG/V-6. I'm not sure how much a bed cover helps but I had it on CC between 65-70 MPH most of the way home.
  15. Oct 24, 2017 at 9:04 AM
    #1175
    jvandivere
    jvandivere Active Member
    Jon
    2014 Tacoma TRD Sport
    So, not sure if this will be the right thread or not, but here it goes. I bought a 2014 Tacoma double cab (TRD Sport). I drive every other week or so from Ohio to Missouri (about 375 miles or so one way). I think I drive pretty consistently, but this last trip sucked on fuel (I'm guessing also in part to strong headwind and weather). I was looking into the fuel economy gauges, but wondered if there is a way to program the current LCD display the radio to show that information? I'd rather not have an additional mod box other than a tow break once I get set up for that. Just curious if there is any programs I could load and buy a sensor for fuel economy.
    Before the Taco, I had a Nissan Juke which has pretty good diagnostics, but it was a year later (2015). I should also add, I work for a major japanese OEM and I see that stuff as pretty standard now and days. Trying to find a solution to analyze my crappy driving.
    BluefinTaco likes this.
  16. Oct 24, 2017 at 10:22 AM
    #1176
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I haven't heard of any mods to the LCD, but short of a Scangauge or a Ultragauge there is at least one app for your phone that I have seen. There is no sensor required just access to the OBDII data.
  17. Oct 27, 2017 at 12:25 AM
    #1177
    Schrauffy
    Schrauffy Member
    Scott
    North Branch, Minnesota
    2020 TRD Off Road DCSB Premium Package
    That was very informative and eloquently stated with an optimal degree of humor! Great stuff!
    I married my tacoma likes this.
  18. Oct 27, 2017 at 12:40 AM
    #1178
    Schrauffy
    Schrauffy Member
    Scott
    Woah, that's very impressive! Maybe you have a Tacoma Hybrid?!? Do you tailgate semis? I'm fortunate to get 21 and I drive sensibly. I'm going to try airing up to 38 psi.
  19. Oct 27, 2017 at 12:45 AM
    #1179
    Schrauffy
    Schrauffy Member
    Scott
    Will airing up to 38 psi exaserbate tire wear? If not, I'll give it a try. Thanks!
  20. Dec 15, 2017 at 7:09 AM
    #1180
    LoveMyTruck09
    LoveMyTruck09 Member
    Rob
    Chester County, Pennsylvania
    2009 Toyota Tacoma 4x4
    added hitch, added cruise control, added fog lights
    Are there any videos here on how to install the Scangauge on to a 09 tacoma
