MPG Mods
Discussion in '4 Cylinder' started by kylefrdavis, Apr 20, 2009.
  1. Jan 17, 2019 at 8:58 AM
    #1281
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    I completely removed my air filter, fuel filter, oil filter, cabin filter and every other filter I could find and my mpg increased big time and so did my HP. It's amazing how restrictive filters can be. I don't plan on keeping my truck past 5k miles so its all good in the hood bro.
    torreyb, worthywads and JNG like this.
  2. Jan 20, 2019 at 3:01 PM
    #1282
    slow TURD I4
    slow TURD I4 Well-Known Member
    SD
    2018 DCSB 2.7
    try driving 65...does wonders
    Ozarktaco and AxisCab like this.
  3. Jan 20, 2019 at 3:01 PM
    #1283
    slow TURD I4
    SD
    2018 DCSB 2.7
    averaged 27mpg on my 50 mi commute
  4. Jan 20, 2019 at 4:34 PM
    #1284
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Even 70 is good.
    FirstTimeTaco2020 and Tullie D like this.
  5. Jan 20, 2019 at 4:41 PM
    #1285
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
  6. Mar 20, 2019 at 10:37 PM
    #1286
    TacomaRebar
    TacomaRebar Well-Known Member
    Blake
    2014 Tacoma TRD Off Road
    I've run a couple bottles of Lucas Oil injector cleaner and fuel system cleaner through my truck since buying it about a month ago. My first 3-4 tanks I was getting 15ish mpg and crappy throttle response. My last two fill ups have been 17ish and 18ish mpg. Calculated based on odometer and gallons put in. I've maintained the same driving habits. No cruise control. Easy on the acceleration. Air filter is brand new. Fresh oil. Tire pressure is good. I'm curious to see if it goes up anymore. I'm 1/4 into the current tank. Looking like it's going to be about the same as the last tank's mpg. I'm not saying I'm proving anything scientific or did any fancy research. I've just tracked mpg and payed attention to throttle response. The fuel system and injector cleaner seems to be doing it's job. After I finish the last two bottles I'll drop it down to 1 bottle every few fill ups.
    DGXR likes this.
  7. Mar 25, 2019 at 7:23 PM
    #1287
    Ddmarte
    Ddmarte New Member
    Dennis
    2nd gen long arm
    All pro off-road long arm king coilovers 8000 warn all pro off road front bumper nerf bars rentless fab high clearance rear bumper ARB front Detroit soft locker rear 529 gears twin ARB air compressor 3 gallon air tank under bed ARB twin air compressor under hood mickneal fiberglass front fenders 35 inch wrangler calivlers on fuel wheels body chop mount to fit 35 s on front so no rubbing 2 inch all pro off road rear wheel spacers to track front long arm
    What about the 2 nd gen tacoma
  8. May 21, 2019 at 2:06 PM
    #1288
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    As an experiment, I drove 55 MPH on the same route that I normally drive 70 MPH. Mileage went up to 28.6 MPG vs 24.5. This was a one time only test. I'm OK being passed by idiots going 80 MPH when I'm going 70. It seems a lot different when going 55.
  9. May 21, 2019 at 6:42 PM
    #1289
    Roadspoke
    Roadspoke Well-Known Member
    2nd Gen Taco 4X4 AT 4.0 SBDC
    Shocks 5100, 2016 trdpro struts, K&N airfilters and removed factory maxipad in airbox, 2in. catback 50 series Flowmaster, BFG AT tires, tint, Leer shell.
    Oh good to know. I experimented trying too run at rpm's lower than 2000 at any situation freeway and city in Las Vegas Nv. I got 21.2 mpg. On a regular drive I would get 17 to 18 mpg.
  10. May 21, 2019 at 11:20 PM
    #1290
    bagleboy
    Scott
    Norcal, Santa Rosa
    There are definitely roads and times when you can and can't take it easier. 70-75 is better than 80-85 and 60-65 is better than 70-75. I enjoy driving more when it's less hectic. I know I'll get there a few minutes later but those extra minutes are in my taco rather than a body bag. I'll go with the flow and not slow others down but I'm glad I don't always have to lean on it.
  11. May 22, 2019 at 12:03 PM
    #1291
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Many people have had similar experience with the Lucas fuel treatment. If you plan to use it long-term, even just occasionally, you can get a gallon jug for about $30 from Amazon which is WAY cheaper than any price on the 5.25oz bottles. (Hint: keep the bottles and refill them with the gallon jug.
    bagleboy likes this.
  12. Jun 21, 2019 at 10:53 AM
    #1292
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    I found that a hard bed cover increased MPG by about 10% but not many miles on it yet.
  13. Jun 21, 2019 at 4:24 PM
    #1293
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    I think Mythbusters did a test to prove that no tailgate vs net vs rear cover vs stock empty bed came out to the same mpg. I think the thought was that a large air pocket formed in the bed and acted the same as a cover or cap so there was no drag from the tailgate like you think there would be.
    dborrer and Winch[QUOTED] like this.
  14. Jun 22, 2019 at 9:15 PM
    #1294
    bagleboy
    Scott
    Norcal, Santa Rosa
    Mythbusters did a lot of tests, many of which proved nothing because they were prop/special effects guys and knew more about breaking stuff than good methodology. Entertaining as fuck though. I wouldn't take any of their results as definite except on a case by case basis. They did quite a bit of guessing after the fact to explain unexpected results and it seemed to me they would rig the outcome if they didn't like the myth.
    Tullie D likes this.
  15. Jun 23, 2019 at 7:33 AM
    #1295
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    They actually measured the amount of fuel that was run through the engine (not the amount to fill up the tank) and compared it to the distance driven. Obviously warmer or cooler temps could affect it and possible wind differences but overall there was basically no difference. It did seem to be one of the more meaningful episodes.
  16. Jun 23, 2019 at 7:56 AM
    #1296
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    My cap made zero difference, or canceled out, it weighs about 200 lbs.
  17. Jun 23, 2019 at 7:58 AM
    #1297
    23Skidoo
    Paul
    meme
    I average 20 mpg, 2nd gen PreRunner, 2.7 access cab.
  18. Jun 24, 2019 at 8:43 AM
    #1298
    bagleboy
    Scott
    Norcal, Santa Rosa
    They usually did something right and other things wrong then made their declaration. Two dudes driving two trucks two times isn't a sample size, it's a joke. Here on the forum mileages vary all over the map with many variables left unmentioned or unaccounted for. Some people can't hold a constant speed and are continually reaccelerating, the cruise control does a poor job adjusting to terrain, traffic, altitude, blah ,blah. I'm not saying they were always wrong, only that they often missed crucial details that rendered their results inconclusive. To be considered a reliable source for results they would have to have been much more rigorous. It was entertainment, nothing more. Play acting at science with a budget to make noise.
    ancient11, JGO, DGXR and 1 other person like this.
  19. Jun 27, 2019 at 2:56 PM
    #1299
    Tullie D
    Tullie
    Wilson, NC
    Welcome to the forum.
    Luke-Maine likes this.
  20. Jun 28, 2019 at 7:22 AM
    #1300
    Sarhog
    Sarhog Well-Known Member
    Greer, SC
    2017 Tacoma Sport Rally
    What country are you referring to? Would you be so kind as to post a reference to your claim?
