MPG Mods
Discussion in '4 Cylinder' started by kylefrdavis, Apr 20, 2009.
  1. Nov 21, 2022 at 4:33 PM
    #1401
    Rocky Mtn Hilux
    Rocky Mtn Hilux Diesel Aficionado
    The Rockies
    1992 Toyota LN107 JDM Double Cab 4x4 5 Speed Diesel
    2" Lift running on 31.5 x 10.5 Michelins x 15" JDM 2-piece aluminum bead locks Monroe Gas Shocks ARB Front Bumper & Winch
    I always use a diesel fuel additive every time I fill up my tank...... :bananadance:
    Rocky Mtn Hilux
    :canada:
  2. Nov 22, 2022 at 7:49 AM
    #1402
    MoneyB86
    MoneyB86 Well-Known Member
    Reagan Country, CA
    2019 MGM Tacoma Double Cab
    Started to drive in the right lane at the speed limit. Cruise gives me worse mileage than controlling the speed with my foot. This was the commute to Disney Land this past weekend.
  3. Nov 22, 2022 at 9:00 AM
    #1403
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Cruise doesn’t adjust for changes in grade where your foot can allow the truck to slow a bit knowing you can regain it on the downslope. It does constant speed where you can do constant energy.
  4. Nov 22, 2022 at 5:30 PM
    #1404
    Metal Toy
    Metal Toy Well-Known Member
    2021 2.7L AC 4x4
    For the 2.7 keep the trans in S4 or S5. You can do cruise with it locked in to S5 and it helps with some of the constant shifting. However, if you are dealing with inclines, I recommend keeping cruise off and control the transmission yourself. It will also help keep the temps down on your transmission if you keep it in S4 or S5 with the torque converter locked up. I recommend using some type of scangauge to watch your torque converter state. I use the scangauge 3. I regularly get 22-23 mpg in town and 25-27 mpg on the highway.
    vanhap and cryptolime like this.
  5. Nov 30, 2022 at 7:54 PM
    #1405
    bagleboy
    Scott
    Norcal, Santa Rosa
    525 miles on 21 gallons. I threw 2 gallons from a can in before work today and included that so I wasn’t running on empty. Normal commute with 20% city, freeway speed ~ 70.
  6. Feb 13, 2023 at 7:52 AM
    #1406
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    the 2.7 runs better with more octane i've found. better MPGs too.
    Scotfree and Dan71 like this.
  7. May 17, 2023 at 10:48 AM
    #1407
    HGPineapple
    HGPineapple Active Member
    Hawaii
    2013 Superwhite RC
    New personal high score
    DGXR and bagleboy like this.
  8. May 19, 2023 at 2:19 PM
    #1408
    Dan71
    Dan71 Well-Known Member
    Dan
    1996 Tacoma
    Bone Stock
    I have noticed the same with my older '96.
    cryptolime[QUOTED] likes this.
  9. May 24, 2023 at 6:09 AM
    #1409
    spicy_fish_taco
    spicy_fish_taco Well-Known Member
    '18 2.7L Taco 4x4 Access Cab
    not sure if it was mentioned in this thread but using a shorter serpentine belt to bypass the AC pulley gave me better MPG's and a tiny bit more power. I know im not kidding myself because aside from the MPG meter the transmission stop kicking down a gear on a couple inclines on my commute that I have taken almost every single day. this mod isnt for everyone but it works for my situation.
    pastoreater likes this.
  10. Jun 18, 2023 at 6:45 AM
    #1410
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    There are a few places around where you can get the Blue or E-0 gas. No ethanol. It's only available in the lower octanes, no 91/94, but it's usually been good for about a 5 to 7 MPG lift for me (in other vehicles). I'll be near one of those stations today and hope to see what it does in the Taco. The trick is timing it so that I can get as much of that in the tank as possible. Might be 3/4 of a tank full today. Would be better if I could get more in.
    https://www.pure-gas.org/
    vanhap likes this.
  11. Jun 18, 2023 at 8:58 AM
    #1411
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    just moved to a place where they have a bunch of ethanol-free stations. there's a place callled GOGAS that only sells 87 E10 and 93E0. Great gas and my truck loves it.
    https://qualityoilnc.com/gogas/
    GTGallop[QUOTED] and JGO like this.
  12. Jun 18, 2023 at 3:07 PM
    #1412
    GTGallop
    Greg
    Anthem, Arizona
    Dash Cams and Hams!
  13. Jun 22, 2023 at 9:59 PM
    #1413
    oldtoyman
    oldtoyman Small bore freak
    Kevin
    North of Seattle
    2019 Honda Monkey,2023 klx300 , 2013 prerunner TRD off-road
    Anybody here use the Kdmax or OTT tune on their 2.7 with fuel mileage gains??
  14. Jul 12, 2023 at 9:11 PM
    #1414
    GTGallop
    Greg
    Anthem, Arizona
    Dash Cams and Hams!
    I ended up getting nearly a full tank in. Was pricey but the fill up was worth it. No real improvement for me. I'm driving like a grandpa and getting around 15 to 16 MPG.
  15. Oct 20, 2023 at 5:01 PM
    #1415
    Lillyroseires
    Lillyroseires New Member
    Lisa
    ‘21 tacoma 6’ bed
    None ( yet)
  16. Dec 22, 2023 at 11:08 AM
    #1416
    APaulcolyps68
    APaulcolyps68 Active Member
    Paul
    2014 Tacoma TRD Off Road 2WD
    Fox Coilovers & Levers 285/75/R16
  17. Feb 2, 2024 at 11:58 AM
    #1417
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Just a thought for those of you who drive til MT - The fuel pump is in the gas tank and is cooled by the gas so you are probably shorting the life of the fuel pump by running it practically dry - also there's no longer a fuel filter, it's just a sock on the pump in the tank so if there is any debris in the tank the sock is more vulnerable when the tank is near MT.
  18. Feb 2, 2024 at 12:36 PM
    #1418
    bagleboy
    Scott
    Norcal, Santa Rosa
    There’s 3 gallons when the light comes on and a well around the pump. Trucks 10 years old on the original pump no issues. I never run out of gas but “low” is subjective since many fill up at 1/4 and some even 1/2 tank. People have their reasons but the pump won’t burn out or clog with 2-3 gallons still in there. Infrequent fill ups is an even better reason to turn it over more completely.
  19. Apr 15, 2024 at 10:16 AM
    #1419
    bagleboy
    Scott
    Norcal, Santa Rosa
    Last 7 tanks have all been 24 or better with 3 above 25. Total miles/total gallons at fill up. All we’re with loads of concrete, debris, or stuffed to the shell roof with blackberry brambles. The one I’m on now I’ve had the rack bars on for 1st a squeeze plank and now an extension ladder so I expect the run to end but mileage and reliability were the two main reasons I chose this model over others. Over 100k since I got it used almost 7 years ago and 1 battery, 1 set of pads & 1 set of tires beyond fluids & filters so check both boxes.
  20. Jun 12, 2024 at 5:29 PM
    #1420
    NTaco23
    NTaco23 Well-Known Member
    Millington, TN 38053
    2023 TRD Off-Road DCSB Ice-Cap
    WeatherGuard window visor, AlienGear holster, bug deflector, roll-up tonneau cover, direct mount wireless charging phone mount, Pedal Commander, Chrome Delete with Black Badging Covers, Glove Box Lights, Black Exhaust Tip, Black-out Bumper covers, bed mat, bed step, bed rail mounted rod and reel holders, rear diff breather relocate
    If I keep mine under 2000RPM I can get 21HWY and 24 city, my city driving does not consist of a lot of stop-and-go.
