MPG Mods
Discussion in '4 Cylinder' started by kylefrdavis, Apr 20, 2009.
  1. Aug 29, 2010 at 9:06 PM
    #141
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    well no matter what you do if you do only highway miles you will get better gas mileage.
    So technically we can make a new MPG increase mod: Drive only freeway!
    Welcome to the forum Karl!
  2. Sep 1, 2010 at 3:54 PM
    #142
    juan
    juan New Member
    juan
    florida
    07 prerunner
    hi ,I'd like to know where the low pressure sensor is located,I have a tacoma 07,the light never go off
    thanks
  3. Sep 3, 2010 at 10:17 PM
    #143
    93Yoter
    93Yoter Member
    Karl
    Four inches of lift, 32 BF Goodrich's, K&N intake, Coldwire plugs, Powdercoated Black Rims....More to come
    Thanks bro!
  4. Sep 3, 2010 at 10:21 PM
    #144
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    the TPMS??? in your wheels dude. monitor your tire pressures and the light comes on with a change of 25% of whatever the psi was set to and programmed to the sensors.
  5. Sep 4, 2010 at 5:40 PM
    #145
    sschiltz
    sschiltz New Member
    Tomahawk, WI
    10 Tacoma
    Has anyone tried the VoloPerformance MPG chip thing yet?
    Claims 15% increase in mileage!
  6. Sep 12, 2010 at 8:17 PM
    #146
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    I have the deck plate mod, K&N drop in filter and run synthetic blend, I also have an ultragauge. Recently i got 25 miles per gallon on high ways doing 55 to 60 the whole way from Charlotte, nc to Raleigh, nc. Then on the way back I took the inter state on the way back doing 65-70 and averaged with the 25 I got 23 altogether the whole trip. That's the best mileage I have ever gotten
  7. Sep 12, 2010 at 9:45 PM
    #147
    JKD
    JKD Well-Known Member
    Scam.
  8. Sep 13, 2010 at 7:02 AM
    #148
    jham1956
    jham1956 Member
    Kentucky
    01 prerunner
    I just joined and I realize the post about AFE is 2 years old but I was wondering how much improvement in gas milage I could expect by getting an AFE filter? I have a 2001 prerunner with a v6 automatic and get about 18 now.
  9. Sep 13, 2010 at 2:27 PM
    #149
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    In my case no increase, maybe a slight .5 MPG decrease. All I got was the fact it is a long life filter, and it makes more noise when you are cruising at 70 MPH, It moans so much that I put the stock Toyota filter back in. A roar I could live with, but the moaning sounds like a cat in heat.
  10. Sep 14, 2010 at 8:56 AM
    #150
    tacomaster09
    tacomaster09 New Member
    Garett
    Orange City, FL
    2009 PreRunner TRD Sport Douple Cab
    K&N Filter
    I've already installed a drop in K&N air filter in my 09 Tacoma TRD V6. I'm now looking at installing a flowmaster exhaust. My main goal is to bump up the MPG a little. Will this mod help or hurt?
  11. Sep 20, 2010 at 11:41 PM
    #151
    alextdunn
    alextdunn Active Member
    alex
    san Diego
    05, 4cly, base, Xtra cab, 5 lug lift
    ready lift 5 Lug lift, bed lights, 400 watt inverter, scan gauge II, AFE pro Dry s, second air filter removed
    Im glad to see im not the only "crazy one" that runs a spread sheet for their gas.
    before i put in my ready lift 5 lug kit i got about 24.41mpg all stock
    after the lift and new bigger wheels 235/75/15 AFE Dry s filter and removal of secondary with the help of scan gauge II now i get 20.78mpg.
    I have bin logging where i get gas and if i see the sticker that says "may contain up to 15% ethanol"
    I have bin driving for California to Az a lot recently and some gas stations in Az have the sticker but not all.
    I do notice a big MPG loss when in california using the "BETTER" ethanol gas. food for thought if you have a choice in Ca i dont think we have one all the gas stations have the better gas.
    Also just a thought people that do more stop and go with notice lower MPG's if they have 4WD all that extra weight that has to be started and stopped will make more of a difference.
  12. Sep 26, 2010 at 10:59 AM
    #152
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I'm not calling you a liar, but I really just don't see how the hell those figures can be in any way true. 31 mpg????? Unless you're driving down hill the entire time, coasting, with a tail wind, while being pulled by a tractor trailer. Especially hauling around a camper shell, that's adding about 200 lbs to your standard load. Are you sure somebody's not adding gas to your tank when you arent' looking?
    kelvingaz and belrose like this.
  13. Sep 26, 2010 at 11:32 AM
    #153
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I didn't go thru all 8 pages but I can get 28 to 29 mph sometimes if I'm very, very careful. That's with a 2.7 and stick. 18 - 22 if I'm not trying.
  14. Sep 27, 2010 at 4:13 PM
    #154
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    the new 2.7s seem to be able to get good mileage if your on the highway coasting. on rare occasions ive been able to hit 29 MPG.
    x2
  15. Sep 27, 2010 at 5:00 PM
    #155
    george3
    New Jersey
    Well, if you got 29 at least ya all know I'm not full of sh-t at least on this one.
  16. Sep 27, 2010 at 8:43 PM
    #156
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    My sticker says 27... best I've ever seen is 23 though. I didn't realize it until late in the trip, but the cruise had the throttle damn near wide open almost the whole time. MY truck doesn't go on many road trips, so I'll try the next one without cruise and I could see getting close to the 27.
  17. Sep 28, 2010 at 10:01 AM
    #157
    ctxtaco
    ctxtaco Well-Known Member
    Austin, Texas
    2010 PreRunner SR5 Double Cab
    Black tube steps
    I do all hwy driving in a 2010 DC Prerunner, 4.0 with stock wheels/tires. I keep the RPMs at 1900 which is 68MPH displayed, but actually 65 MPH according to the GPS. The average since new has been 21.5 MPG. I recently added a drop in K&N air filter, (left the secondary filter in), switched to Valvoline SynPower 5W30, and keep the tires at 34 psi. My MPG suddenly went up to 24.8 MPG over the last 3 tanks. Life is GOOD!
  18. Sep 28, 2010 at 11:44 AM
    #158
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I've gotten 30.9 MPG's on 2 separate FULL tanks. 60% highway/ 40% suburban.
    I routinely get 27.8-27.9 with nearly zero highway miles. And I'm not driving like a grandpa either. I love this truck.
  19. Sep 28, 2010 at 12:05 PM
    #159
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    Are you sure they had the right sticker on there? Toyota's site only claims a max of 25mpg, and that's for the base 2wd 2.7L
    Stewzz likes this.
  20. Sep 28, 2010 at 7:27 PM
    #160
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    The sticker on my '09 2wd 2.7L said 26 MPG Hwy. That's what I get in "normal" driving, but if I'm careful (short-shift and keep the speed down) I can get as high as 28. I've gotten that many times. Lately I've been taking the interstate route (70 MPH speed limit - I'm driving 70-80) to work rather than the 2-lane country highway (55 MPH speed limit - I drive 60) and my average for the last several fill-ups has been down around 25-26 MPG.
    Keep in mind that the EPA changed their testing methods for the 2008 model year so that their results would be closer to what you could expect in real-world driving. MPG estimates for pretty much ALL vehicles went down. With the old rating system, it was difficult to achieve what they said you should be able to get, but now the estimates are pretty accurate.
