MPG on auto vs manual
Discussion in '3rd Gen. Tacomas (2016-2023)' started by linkfeeney, Jan 7, 2020.
  1. Jan 7, 2020 at 5:48 PM
    linkfeeney
    linkfeeney [OP] Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    hi, what are you guys getting in MPG on the new tacomas?
    I have done a lot searching, it seems like the the mileage hasn't improved at all and I have a 09! is the manual getting better gas mileage compare to the automatic?
    thx
  2. Jan 7, 2020 at 5:51 PM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    Manual will be worse. The new 6AT is completely tuned for mpg even if it's still not great but the 6MT still has both a shorter 6th and a shorter rear end.
  3. Jan 7, 2020 at 5:54 PM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    Depends on how you drive. The manual is geared way lower, so ar higher speeds it drinks gas. I commute on a 75mph interstate. Winter driving is 17 to 19 mpg, summer is 21 or less. These are tank averages. I've seen as high as 23 on individual trips, but this is empty, wind to my back, Jesus pushing me along.
  4. Jan 7, 2020 at 5:59 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    The AUTO is pretty good IF you keep the RPM's low. Just hate the way it shifts. Getting anywhere between 30 mpg (flat ground, no wind and ~ 70 MPH & 1800 RPM) to 18 MPG (headwind, hills, lower gears and higher RPM).
    mgmdclb likes this.
  5. Jan 7, 2020 at 6:00 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    On paper the AT is better. I get crap gas mileage on my AT, but that's because I don't drive slow. I'm sure some MT drivers are doing better than my AT.
    SJM95 and Junkhead like this.
  6. Jan 7, 2020 at 6:02 PM
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    AT for just driving around and not worrying about it will get better. If you are cognizant and try to drive to maximise mileage you can beat an AT with a MT, but you'd have to work at it.
    Junkhead likes this.
  7. Jan 7, 2020 at 6:04 PM
    Sparky.
    Sparky. Bought, built, totaled
    Dawson
    Enumclaw Washington
    ‘14 AC 6MT -R.I.P, ‘08 cummins
    By work at it you mean stay under 50mph :rofl:
    Taco4Jaco, XUT, GoBig and 3 others like this.
  8. Jan 7, 2020 at 6:04 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I had Manual 2nd Gen's prior to my 3rd Gen Manual, this one does better.
    6MTPro, WoodsGhost, 02Duck and 3 others like this.
  9. Jan 7, 2020 at 6:12 PM
    Dubiousveracity
    2018 TRDOR DCSB MT
    none
    60 or so, neutral coast down to yonder stop light, shift well before the 3.5 will make any power. ;)
    MOC221_ likes this.
  10. Jan 7, 2020 at 6:17 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    They’re the same if you drive the same.
    If you’re into hypermiling techniques and driving specifically for mpgs for fun (not many people are haha) then you can get better with the manual.
    Most wont.
    Junkhead and Chew like this.
  11. Jan 7, 2020 at 6:38 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Auto, 18.8 mpg combined over 18k miles. FWIW
  12. Jan 7, 2020 at 6:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    www.fuelecomomy.gov
    Since their formula revision their numbers are surprisingly accurate for a stock vehicle, reasonably driven in reasonable weather.
    You'll actually learn more there than by listening to 'but my truck' numbers from internet strangers. Where you are clueless of conditions or their arithmetic skills. :D
    BTW, if you want MPG, don't buy a truck. Any truck.
    If you have to have a truck, keep in mind MPG is only a factor in TCO. A truck that gets better MPG and costs less out the door may wind up costing more over the life of ownership if it's not reliable.
    cosmicfires, DarkSkyGuy and Junkhead like this.
  13. Jan 7, 2020 at 7:06 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Physics say they will get similar mileage. Tough to beat those laws.
    Boghog1 likes this.
  14. Jan 7, 2020 at 7:10 PM
    Sparky.
    Dawson
    Enumclaw Washington
    No experience 3rd gen, but 2nd gen 60mph is 2k rpm. Takes hills and tows better, but you can kiss mpg goodbye
  15. Jan 7, 2020 at 7:15 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    This!
    What are you expecting- it's the same truck (weight, aerodynamics, nearly same ratios, etc)
  16. Jan 7, 2020 at 7:18 PM
    PhenixFord
    Randy
    Arkansas
    Well - except for the difference in transmission. :)
    Gen3TacomaOBX, auskip07 and Junkhead like this.
  17. Jan 7, 2020 at 7:27 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Efficiency changed a bit is all.
  18. Jan 7, 2020 at 7:28 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Correct, I was attempting to answers OP's question, referring to difference in MPG
    "what are you guys getting in MPG on the new tacomas?"
    PhenixFord[QUOTED] likes this.
  19. Jan 7, 2020 at 7:30 PM
    PhenixFord
    Randy
    Arkansas
    Agree that it is basically the same truck. But hard to find someone that owns a stick but drives it like an auto.
    dnlskier and Chew like this.
  20. Jan 7, 2020 at 7:37 PM
    Shellshock
    Iowa
    My Fuelly data disagrees
    I averaged 18.4 in my AT over 50,000 miles
    19.4 in my MT over 97,000(which also has over 10,000 towing miles). Highway is usually 20+ during the summer.
