MPG question... is this normal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tidrow, Jun 15, 2010.
  1. Jun 15, 2010 at 7:03 AM
    Tidrow
    Tidrow [OP] Well-Known Member
    Austin
    PreRunnin' 08
    BHLM, All Black grill, Fog light Mod, AFE pro dry, 20% tint, Weathertechs, Kenwood deck, Bridgestone AT Revo 2
    :confused:
    I have a 2008 Automatic V6 Access cab w/ 25k for about 1 month. I put an afe dry flow filter on and added new tires. The tire size changed from the factory 245 dunlops to 265 75 16 goodyear tires.
    My mpg's are averaging 16-17 at this point. I had it on the highway this weekend and got about 17.5mpg. Just doesn't seem right for a 4x2...
    Does anyone think I am having issues or is it just the slightly bigger tires?
    I put my fuelly sig on if you want to check it...
    Thanks,
    PS. don't get me wrong, I'm not dissapointed or bitchin or anything, just concerned if there might be something wrong with the pickup I just bought.
  2. Jun 15, 2010 at 7:13 AM
    Brunes
    Brunes abides.
    Rotorhead
    Do you know the mileage from before the tires??
    And have you used the tire calculator on the site to figure out the mileage correction??
  3. Jun 15, 2010 at 7:15 AM
    Tidrow
    Austin
    PreRunnin' 08
    I only had the stock tires for one or two fuel ups, I didn't have my fuelly account then, but I'm pretty sure I calculated getting 21 on a road trip to corpus.
  4. Jun 15, 2010 at 7:18 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Yea, no way did those tires drop your MPG that much... something has got to be off.
  5. Jun 15, 2010 at 7:24 AM
    Brunes
    Brunes abides.
    Rotorhead
    Specially if you went 245 to 265- that's like a .4% adjustment- which is nothing. I'm kind of interested to see what the result is.
  6. Jun 15, 2010 at 7:26 AM
    Tidrow
    Austin
    PreRunnin' 08
    Thanks guys, but what would be the plan of attack? Dealership? It is under warrenty another 10k or so
  7. Jun 15, 2010 at 7:37 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How exactly are you calculating your MPG?
    What tire pressure are you running?
    What type of driving are you doing?
  8. Jun 15, 2010 at 7:45 AM
    Tidrow
    Austin
    PreRunnin' 08
    Tire pressure is at 35psi
    When I fill up I stop on the first click of the gas pump. I drive in heavy traffic most of the time. On a full tank of Austin traffic on highway 35, I got 14mpg!?! The thing with that is I did some highway driving this weekend and I still only got 17.5. running 70-85mph
    I just made a fuelly account and that is how I have been tracking it. Before that I would divide the miles drivin by the number of gallons it takes to fill up.
  9. Jun 15, 2010 at 8:03 AM
    Janster
    Jandy
    Lancaster, PA
    Are you taking into consideration the difference of distance with the larger tires? When you put larger tires on, the actual distance you travel DOES NOT match the distance your speedometer is showing you.
    With larger tires, your TRIP distance information is going to be LESS than the actual mileage you are traveling.
    Do you have a GPS?? You can compare actual trip information (on your truck) with the GPS.
  10. Jun 15, 2010 at 8:21 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    well there you go. for maximum MPG the ideal speed is 55mph. take it down a notch and dont go over 70...ever. try your best to keep your RPM's under or at 2k, drive like you have an egg under your foot. Im running 33" tires and my last tank averaged 18.2 mpg and I did account for my bigger tires, I think its like a 5% increase. so instead of what my ODO showed, 308 miles, I actually got 323 miles.
  11. Jun 15, 2010 at 9:25 AM
    Tidrow
    Austin
    PreRunnin' 08
    You may be right, I will check my tire % increase, thx bud
    don't you have a 4x4? I can't believe I'm getting worse mpg than a 4x4s
  12. Jun 15, 2010 at 9:41 AM
    Tidrow
    Austin
    PreRunnin' 08
  13. Jun 15, 2010 at 9:45 AM
    Brunes
    Brunes abides.
    Rotorhead
    You take the % difference in the Circumference add 1 and then multiply your odo distance. Soo...300*1.039=311.7 iirc.
  14. Jun 15, 2010 at 9:54 AM
    Tidrow
    Austin
    PreRunnin' 08
    Brunes, thanks for the help.
    went into my fuelly account and updated the miles drivin.... raised the mpg's on my profile almost 1 pt.
  15. Jun 15, 2010 at 10:25 AM
    OCTaco
    OCTaco Well-Known Member
    OC
    '16 TRD Sport DCSB
    Im running goodyear 285/75/16 and average about 19 mpg. It's all in you driving dude.
  16. Jun 15, 2010 at 11:32 AM
    Rbohno
    Rbohno Well-Known Member
    Richard
    Charlotte,NC
    2010 DC TRD OffRoad
    Viper remote start alarm 2.5" Spacer in front, 1.5" spacer in rear, rear TSB performed N-Fab Nerf bars 16" x 8" Vision Warrior wheels 265/75/16 Dura Trac tires
    I have a stock dc trd 4x4 with the 6 cylinder and just got back from a road trip to Texas. I used cruise control 90% of the time and after 2600 miles I got 23.4 mpg. I am very pleased, around town here in NC I was only getting 19.2 -19.4 but around town for me doesn't mean much traffic. Five o-clock traffic in Boger City is 3 cars in line at one of the 4 or 5 stoplights in town.
  17. Jun 15, 2010 at 4:24 PM
    Tidrow
    Austin
    PreRunnin' 08
    thx all, i'll back off the gas
  18. Jun 15, 2010 at 4:26 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Also what gas are you using? Use quality fuel like cheveron/quik trip/shell/ect
    Cheap costco type gas can kill your millage a few points too. I did the math once, I saved more running chevron 91 than I did costco 87 on millage bonus (let alone the car ran like ass).
    Also as a side note, my prerunner was pretty consistent with 18.7 no matter what I did (excluding towing).
  19. Jun 15, 2010 at 4:48 PM
    Tidrow
    Austin
    PreRunnin' 08
    18.7 is more like it. I'll try a better brand and see if that helps also.
  20. Jun 22, 2010 at 1:15 AM
    corman6892
    corman6892 Active Member
    Corey
    Portland, Or
    07 prerunner w/ fiberglass fenders
    cold air intake, 16" black steel wheels, 33" super swampers, 8000k HID's, blacked out headlights, flowmaster, 3" procomp lift kit, procomp light bar, 2 KC off-road lights, 12" sub, 1.5" wheel spacers, Fiberglass fenders, remote start, 6 disc touch screen stereo, and train horn!
    I don't know how you guys do it, I drive slower than a grandma and hardly touch the gas and get 14 mpg in the city and if I'm really good on the highway then ill get a little over 16. I have a 3 inch lift and 33's. And I have made all the proper adjustments to the speedometer and everything, somethings up with my truck :confused:
