MPG shift with slightly bigger tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Snakedoctor, Oct 16, 2017.
  1. Oct 16, 2017 at 5:48 PM
    Snakedoctor
    Snakedoctor [OP] Well-Known Member
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    Mandatory tint, in-channel visors, and 265/75R16 MT Toyos.
    I'm not the most experienced in the realm of getting good MPG with tires. My last truck was a 97 Cummins and it got 17MPG with 35s so I couldn't complain.
    How big of a difference should I notice on the 3rd Gen Tacoma with 265/75/R16 MT tires? So far my average has dropped from a healthy 18 to a 15.9, been babying it trying for that .1, but also I've read somewhere these truck can actually adapt to a change to help it get the best MPG? Is this true?
    Also what do you guys run on your tacomas? I'm at stock height and I know that makes a factor sometimes.
    Thanks for anyput I'm new to the forum and I've heard good/scary things from Reddit.
  2. Oct 16, 2017 at 7:13 PM
    camyz125
    camyz125 Well-Known Member
    Charlotte NC
    2016 TRD OR DCSB 4x4
    Bigger tires = worse MPG. You'll probably lose 1-2 MPG. I went from 19-21 avg to a 18-20 going to the 265/75r16.
    hiPSI likes this.
  3. Oct 16, 2017 at 7:18 PM
    Snakedoctor
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    Are your steps factory? I've found it random that some come with them and some don't.
  4. Oct 16, 2017 at 9:00 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Little bigger equals a little less mpg. A lot bigger equals a lot less mpg. Easy peasy.
  5. Oct 16, 2017 at 9:26 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    I have no idea what my initial MPG was when I got my truck. I drove it two miles from the dealership to my work and installed the 265/75/16's.
    I averaged about 15.5-16 mpg for the first two tanks of gas and it has slowly improved,this last tank full I averaged about 17.5 in town with a manual trans.
    ETA I just passed the 1K mark on my last fill up,getting right at 300 miles per tank
  6. Oct 16, 2017 at 10:10 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The bigger difference in that size shift will be weight. Spinning heavier tires up to speed will cost you MPG. Did you go with E-rated? Also if you go to E’s you might have to inflate to a higher PSI to get reasonable mileage.
    Sociopenguin and inwood customs like this.
  7. Oct 17, 2017 at 12:39 AM
    Snakedoctor
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    Yes I do believe they are E-rated tires they are pretty heavy tires. Really makes you think about how a few pounds in the wrong spot can make a difference.
    I'm still getting used to having a truck, coming from a Honda Civic that got 30mpg really spoils you to gas mileage.
    What's this about higher PSI? How can I tell what is proper
  8. Oct 17, 2017 at 3:16 AM
    Stocklocker
    17TRDORDCSBAT
    Rolling mass has a much bigger effect than static mass. I can’t advise you on E-rated pressures, but I know other members here have discussed running e-rated Ko2s etc at higher pressures than the stock Toyota 30 PSI after doing a chalk test. Maybe someone who has experience can chime in? I’m still running the factory Wranglers.
  9. Oct 17, 2017 at 5:11 AM
    camyz125
    Charlotte NC
    No, they're Nfab steps.
  10. Oct 17, 2017 at 5:16 AM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    For example, if the stock is calibrated to 265/75/16 and you upsize your wheels and tires to 285/70/17, your speedometer will be off 2.1 MPH at 60 MPH
  11. Oct 17, 2017 at 6:02 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Running BFG KO2's (265/70/17's) and have always gotten 18-20+ with my 16 SR5 DC V6 4X4. Live in the hills of Western NC. Unless I'm on the highway going better than 60, I use ECT.
    G.
  12. Oct 17, 2017 at 6:35 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    37 PSI for LT265/75/16.
    Stocklocker[QUOTED] likes this.
  13. Oct 17, 2017 at 6:57 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I lost around 2mpg going from the stock wranglers to heavy ass st maxx's in 285/75/16
    If you haven't re-calibrated your speedo, then you need to take into account the difference in not only speed but your ODO and MPG as well.
  14. Oct 17, 2017 at 7:58 AM
    pocketsmcaaron
    pocketsmcaaron Well-Known Member
    Oregon
    '16 OR MT DCSB WHT Prior:'15 MT ,'94 MT
    Snugtop Rebel,TRD Pro Bilsteins,2" Block rear,SR Grill,TRD Beadlocks,Toyo AT 2s,Focal Experts,Kicker AmP & 10" Sub
    Just curious, are you running C or E rated? Thanks
  15. Oct 17, 2017 at 8:25 AM
    Garyji
    Gary
    Running the C’s.
    G.
    pocketsmcaaron likes this.
  16. Aug 30, 2018 at 6:49 AM
    Woodzyzewski
    Woodzyzewski Well-Known Member
    Woodrow
    West Virginia
    2018 Inferno TRD Off Road DCSB
    I have a 2018 TRD Off Road that has the factory 265/70/16s on it. If I go to 285s, how can i recalibrate my Speedometer, ODO, MPG tracker, etc...? Is that something I can do on my own or Toyota will do it for me or what?
  17. Aug 30, 2018 at 8:11 AM
    Mikeybuck
    Mikeybuck Well-Known Member
    SW WA
    2018, 2010, Tacoma
    I run C rated 255/75/17 duratracs. 60 miles a day, this summer I'm averaging 19.5-20MPG. My truck is a 6MT, slimline steel bumper, winch, sliders, tool box full of tools.
    Go buy yourself a fat tire bike and see how much fun it is to peddle a 4.5 inch wide tire around vs your skinny bike. Wide, heavy tires kills your mpg/power.
    hiPSI and pocketsmcaaron like this.
  18. Aug 30, 2018 at 8:20 AM
    pocketsmcaaron
    Oregon
    Do you have any pics? I was interested in the same size. Also, was the 60 a day both highway & city? If so, that’s excelkent, you’re getting better than stock size.
  19. Aug 30, 2018 at 8:49 AM
    ICU1
    ICU1 Well-Known Member
    I’ve been averaging 19.9 around town
  20. Aug 30, 2018 at 9:05 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Reddit is great for a lot of things but their car and truck subreddits are terrible.
