MPG Tire Size Comparison
Discussion in '1st Gen. Tacomas (1995-2004)' started by ForestRunnerFrank99, Jul 22, 2019.
  1. Jul 22, 2019 at 11:42 PM
    ForestRunnerFrank99
    ForestRunnerFrank99 [OP] Well-Known Member
    Josh
    Rancho Cucamonga, CA
    '99 TRD 4x4 Manual 3.4l v6
    Fox Coil-overs, Dakar Leafs, Intake, Tires, Rims
    That is awesome. I figured someone somewhere made a speed sensor calibrated for bigger tires. I'll definitely purchase one when I get my tires.
    DJB1[QUOTED] likes this.
  2. Jul 23, 2019 at 11:27 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Yes, stock Pro 16" rims.
  3. Jul 23, 2019 at 1:09 PM
    ForestRunnerFrank99
    Josh
    I wonder how much of a difference there is between yours and mine regarding gearing and power.
  4. Jul 23, 2019 at 2:01 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Hmm, that would be some interesting math. First I would compare power and weight, though. 3rd gen is 278 HP and 265 lb-ft torque (compared to 190/220 for a '99 V6). But the 3rd gen is significantly heavier, '18 is 4480 curb weight, compared to 3280 for a '99. So HP and torque to weight ratios are actually pretty close -- slightly better HP to weight for the 3rd gen (7% better), slightly better torque to weight on the '99 (12% better) which is usually better for a truck, especially for larger tires.
    Rear end on the '18 AT is 3.909. Gear ratios are:
    1st 3.6
    2nd 2.09
    3rd 1.49
    4th 1
    5th 0.69
    6th 0.58
    Just not sure this makes any difference -- I think there's a point where regearing just becomes a better option when going with bigger tires, not just for MPG but driveability.
  5. Jul 23, 2019 at 2:49 PM
    ForestRunnerFrank99
    Josh
    Interesting that the 1st gen has a higher torque to weight ration.
    Rear end in the (my) '99 MT is 4.10. Gear ratios are:
    1st 3.83
    2nd 2.062
    3rd 1.436
    4th 1.00
    5th 0.838
    So re-gearing is probably only worth the cost with 35"+ tires.
  6. Jul 23, 2019 at 4:52 PM
    azadv
    azadv New Member
    Jerry
    2004 Tacoma 4x4 Extra cab
    All-Pro skids and bumpers, rear lockright, front ARB locker, 4.88 gears, 255/85R16 BFG KM2s, All-Pro rear leafs, Sway-A-Way front coilovers, Bilstein rears, Camburg upper control arms, onboard ARB compressor, ARB snorkel
    I'm getting about 18mpg with 255/85R16 BFG KM2's and 4.88 gears (2.7l w/5spd)
    DJB1 likes this.
  7. Jul 23, 2019 at 4:55 PM
    ForestRunnerFrank99
    Josh
    That's not bad at all.
  8. Jul 23, 2019 at 4:56 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I hate you guys :luvya:
  9. Jul 23, 2019 at 5:00 PM
    ForestRunnerFrank99
    Josh
    If you are looking for better gas mileage I know someone who would take that pesky Supercharger off your hands. I'm close by too :D
    eon_blue[QUOTED] likes this.
  10. Jul 23, 2019 at 5:25 PM
    larryj467
    larryj467 Member
    Lawrence
    Tucson
    '99 Taco Xcab TRD
    Eibach w/881s 1.5" spacer/5100s SCS SR8s
    I am running 33s. Recently started tracking my MPGs and am getting around 17mpg. I rarely go over 60mph since I just go to and from work. That being said, the truck is also empty...nothing in the bed or cab other than myself.
    '99 Ex. Cab, 4x4, 3.4, Manual Trans
    33x12.5x15 General Grabber ATs / 15x10 Procomp 252s
    I also just got a set of SCS SR8s that I am going to wrap in 255/75 BFG muds, so I will keep you posted on what that does to my mileage.
  11. Jul 23, 2019 at 9:02 PM
    ForestRunnerFrank99
    Josh
    Cool! So only a few less MPG's. I can live with that.
  12. Jul 23, 2019 at 9:23 PM
    NuubTaco
    NuubTaco Member
    Lyons, CO
    2004 Tacoma X-tracab 4x4 n'stuff
    Billie 5100s w/ OME 883s and OME DAkars w/ XLs, ARB Roo Bar, Warn M8000 winchy, Bud Built full slider kit, Toyo
    Holy poop! I went to 31.9's after my wee lift and have been calculating my mpg the same way I did b4, with the odomenter difference between fillups divided by the amount filled at the time.. How the heck do I correct for the new tire size. Uuuugh Math!?!
  13. Jul 23, 2019 at 9:56 PM
    ForestRunnerFrank99
    Josh
    I did the math up there somewhere
