MPG w/ Stock Supercharger - PLEASE READ BEFORE VOTING
Discussion in '1st Gen. Tacomas (1995-2004)' started by zacharypaul89, May 26, 2016.
What is your gas mileage (1st gen supercharged only)?
This poll will close on May 26, 2026 at 8:02 AM.
  1. less that 15 MPG
    18.2%
  2. 16-18 MPG
    45.5%
  3. 19-20 MPG
    27.3%
  4. 21-22 MPG
    9.1%
  5. 23+ MPG
    0 vote(s)
    0.0%
  1. May 26, 2016 at 2:07 PM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    I guess it depends on what happened to it but I don't see why not. In all the years, I personally have never heard of someone being left stuck in the middle of nowhere because the S/C
    failed, it could happen I guess but I've not heard of it.
    zacharypaul89[OP] and eon_blue like this.
  2. Jun 18, 2016 at 2:19 PM
    1997tacomav6
    Denver
    I have 500,000 miles on my supercharger, has been rebuild 3 times, yes my belt has broken 3 times
    in those 500,000 miles along with regular belt changes and yes you can still drive the truck, but the alternator will not be working, so
    the truck will run only until the battery goes dead. The belt lasts about 25,000 miles or so
    zacharypaul89[OP] likes this.
  3. Jun 20, 2016 at 9:48 AM
    elnip
    LC,NM
    You, sir, take the cake! lol
    Question, where have you had it rebuilt?
  4. Jun 20, 2016 at 4:53 PM
    1997tacomav6
    Denver
    The first 2 rebuilds were done by Magnuim in California, but they stop doing rebuild I think 4 years ago.
    The 3rd rebuild I used www.thehighspeedlab.com.
    They did a complete job, all new seals, gaskets, bearings,
    Including the bypass gaskets and bypass bearings plus rotors recoated for 950.00.
    Plan on having the rotors recoated as they will be coated with carbon after 150,000 miles
    and will have to be stripped anyway.
    If you need any mill work or metal repairs they can handle all this type work,
    they know the Trd chargers very well.
    From my experience the supercharger will last about 150,000 miles give or take before bearing start to go out.
    The front bearing will last about 100,000 miles maybe 150,000.
    The rotor pack bearings start to make noise around 150,000.
    So its best to just do a complete rebuild at 150,000 and not have
    the Super Chargers body get messed up inside with bearings that fail and the housing getting hurt inside.
  5. Jun 21, 2016 at 9:30 AM
    elnip
    LC,NM
    Excellent feedback, I appreciate it! :thumbsup:
