MPG went up?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spankomatik, May 20, 2022.
  1. May 20, 2022 at 3:02 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Until the actual math is done when you fill-up, you won't know if this is so. I haven't seen much better than 23 mpg, and change yet with my stock sr5 v6 at those speeds.
    As far as the weather, you'll always do better in the summer. I get my best mileage when its 70 degrees plus.
  2. May 20, 2022 at 3:07 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    You should move to Texas, it's always hotter than 70 degrees plus. That must be why my truck can easily average 20+ MPG for the entire tank!
    Oh, a strong head wind will KILL the MPG's. While driving home today there was one (We have heavy storms and a cold front coming in), and I got 15.9 MPG during my commute home. I have NEVER had it dip that low.
  3. May 20, 2022 at 4:24 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Mobbin
  4. May 21, 2022 at 8:36 PM
    Muddy Duck
    Muddy Duck Well-Known Member
    I have the same phenomenon. My SR 4 banger used to give me 21 to 21.5 mpg in the winter time. It improved to 23 to 24 in the last couple of fills. I thought for a while the digital was lying, but when I filled it up and worked on the math, it was darn close to what the digital was saying. It must be the hot weather that gives me a better mileage. I drive in the city only with lights and road turns. I don’t rush to the light, but I usually rev it up after the light to make it shift to a smoother gear. That may help to improve fuel efficiency. Other than that, I am happy what the SR is giving me for mileage.
  5. May 22, 2022 at 5:53 AM
    zoo truck
    None
    It can be -10 in the winter to nearly 100 degrees by mid july here. We can get some crazy high winds, and storms to. Biggest issue is protecting the truck from a sudden hail storm.
  6. May 22, 2022 at 5:57 AM
    Clearwater Bill
    Billy
    Largo Florida
    Do actual math over several full tanks.
    Report back how close the dash display was.
    davidstacoma likes this.
  7. May 22, 2022 at 6:15 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Summer gas has higher btus so more energy. Warmer air less dense. Tire pressure doesn't drop as much in warm weather.
  8. May 22, 2022 at 6:21 AM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    There was no winter-summer gas switch this year so that couldn't be contributing
  9. May 22, 2022 at 6:22 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    +1 on summer gas.
  10. May 22, 2022 at 6:40 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I run a scan gauge and it's pretty damn accurate and yeah fantastic instant mileage but at the end of day the scan gauge and the fill up math are all most a perfectly match and it a hell of a lot closer 20 MPG!
  11. May 22, 2022 at 7:44 AM
    MississippiPI
    MississippiPI Well-Known Member
    Jimmy
    All over the Great State of Mississippi
    2018 SR5
    My mpg will increase if I use non ethanol gas and drive about 60
    321cya likes this.
  12. May 22, 2022 at 8:06 AM
    Barcelona21Taco
    Barcelona21Taco Well-Known Member
    21 OR
    I gain 2+/- mpg by driving 69-72 mph instead of 77-78 mph. The V6 seems to have a sweet spot it likes at the lower speed.
    AZYotes likes this.
  13. May 22, 2022 at 9:26 AM
    GBR
    GBR Well-Known Member
    19 TRD OR
    It's pretty much all wind resistance causing that. I think in a vehicle wind resistance closely follows the cube law in relation to speed. So a 5 mph increase from 75 to 80 is going to cost you more than a 5 mph increase from 70 to 75.
  14. May 22, 2022 at 9:44 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    How much? Is it worth it in the long run with the price difference?
  15. May 22, 2022 at 9:59 AM
    #35
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    This and less.time warming up. I've noticed how much a load affects mileage by mid winter I'm driving.around with a pretty dense block.of snow in back.
    V6 2019 sr, don't understand people, in past threads, who say its a dog. Pulling.out into traffic I have to be careful to not spin the tires.
    VT has a unique law that allows passing on a double line if certain criteria are met. 40-80mph no time flat.
    I've clearly taught my Tacoma.well. Don't get the whining.
  16. May 22, 2022 at 10:16 AM
    #36
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    you didn’t get 33 mpg. As some have said check it over a full tank of gas recording your mileage at each fill.
    Have no idea of what caused your indicate mileage anomaly. Expect low 20s with your truck in good conditions.
    zoo truck likes this.
  17. May 22, 2022 at 10:45 AM
    #37
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Here you go I think we have a winner. page.giftsfinder.co/fuel-saver/?gclid=Cj0KCQjwvqeUBhCBARIsAOdt45YlBpJv_PB9K5mMycjgCJlNQ9nJDpkzU4mJemTnYB5il2DMOwXbezoaAgLjEALw_wcB
  18. May 22, 2022 at 11:01 AM
    #38
    AZYotes
    AZYotes Well-Known Member
    Glendale, AZ
    '20 TRD Sport Previous - '14 Prerunner Access Cab
    I don't think I could get that kind of mileage if I coasted down hill all the time.
  19. May 22, 2022 at 11:05 AM
    #39
    AZYotes
    Glendale, AZ
    When Covid first hit and the cops were staying home too I was getting 12 when I'm normally in the 15.5 range. Trip to work was a little more fun though.
  20. May 22, 2022 at 1:13 PM
    #40
    mrengineerical
    mrengineerical Well-Known Member
    Baltimore, MD
    2019 Tacoma TRD Sport DCSB
    Oddly enough, my TRD sport with the V6 gets better mileage with the AC on when on the highway. It drives much nicer with more lower end power on the highway which allows it to not shift gears is my guess as why. Must be something in the Toyota engine computer that allows more power when under more accessory load or something.
