mpg with the temp of the air cond
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bra, Oct 24, 2008.
  1. Oct 24, 2008 at 12:01 AM
    bra
    bra [OP] Well-Known Member
    2008 AC 4X4 TRD sport
    Badges off
    Hello, just a question about the airconditionner, does anybody know when and why the A/C suck fuel? I don't know if it more we cold the temperature or when we put the fan on the hi or low position.
    Do you think it will increase the mileage if we don't set the temperature too cold?
  2. Oct 24, 2008 at 12:53 AM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    When you turn on your A/C, it engages the clutch on the A/C compressor. It causes more drag on your engine, in turn making the engine work harder. If you just turn the temp knob to cool, it won't be as cold as your A/C, but it also won't affect your gas mileage.
  3. Oct 24, 2008 at 6:14 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    A/C on = lower mpg in city driving.
    the temperature or the fan speen will not make a dif.
    Mythbusters did a test between two identical trucks. one using a/c and one with the windows down while driving on the highway. the one with a/c drove farther than with windows down. Im not sure how far it was, I think he drove for about 40 more mins.
  4. Oct 24, 2008 at 6:34 AM
    Brunes
    Brunes abides.
    Rotorhead
    The over under speed is usually about 40 mph (rough estimate).
    If you are going BELOW 40-keep the windows open because the drag from the open windows is less then the drag on the engine of the AC compressor.
    ABOVE 40-Roll up the windows and turn on the AC.
    And +1 about the temp not mattering.
  5. Oct 24, 2008 at 6:57 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Back in the older cars (say Buick and Olds etc) the A/C could draw up to 20 HP off the engine to run the compressor. Now, ours are much more efficient and only draw 5-10HP when the compressor kicks on. You can feel it mostly on a slight incline where HP becomes challenged by the hill itself as well as windage, then you add the third variable of the A/C engaging, there's that instantaneous slight drop in power for like 10 seconds then it comes back and so on. This is not that noticeable on our trucks with the V6s, but the I-4s will feel it a little more...but still not as badly as the small cars with say 130HP or less. That A/C still requires the same draw of power and the less overall power your engine has the more you'll feel it.
  6. Oct 24, 2008 at 7:35 AM
    camsbored
    camsbored Well-Known Member
    Raleigh, NC
    08 PreRunner DC/Sport/LB
    Kenwood DNX8120, Homelink mirror, Valentine One hardwire
    Also, turning the temp knob warmer does not help mpg if the AC is on... it's just a way for the girlfriend to annoy me by inefficiently warming previously air conditioned air.
  7. Oct 24, 2008 at 7:58 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I sweat it out with the windows up and the AC off. Occasionally, I'll roll the windows down and swap out the air for a minute, but then the windows go back up.
    As for the mythbusters, there are far too many variables for me to believe what they say when it comes to this.
  8. Oct 24, 2008 at 8:34 AM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    why would u leave the windows up and sweat it out? just does'nt make sence u have ac use it. :confused: how much money do u think u are saving getting all gross and sweaty in a closed up truck when its hot out. :rolleyes: i just dont get people like u. but hey maybe u like sweating? :D
  9. Oct 24, 2008 at 8:49 AM
    lsocoee
    Hotdog
    Wet Okole Underwear
    I don't sweat that much, and it isn't really that unpleasant. Assuming $3.6 for gas, I spend $10.26/day to commute without AC. With AC, I'll be spending $11.34/day. So to answer your question, I don't know I bother, I waste way more than $1/day.
  10. Oct 24, 2008 at 6:30 PM
    bra
    Badges off
    Oh really? Are you sure?So I can turn the temp in the maxcold position and the fan on the hi position and it will not affect the mpg? I will maximise next time my a/c if there are'nt difference with fuel comsuption :D
  11. Oct 24, 2008 at 6:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The temp is controled by mixing the cool air with air heated by the coolant. With the fan running on "High" there might be a mpg penalty as its useing more electricity, thus putting more of a load on the alternator.
    All things considered, running AC isnt going to hurt your mpg THAT much. If you need the extra .5 mpg, you should have considered a different vehicle. :rolleyes:
  12. Oct 25, 2008 at 8:55 AM
    allrsdup
    Sahuarita AZ.
    i agree this is a retarted conversation in the first place.
  13. Oct 25, 2008 at 10:14 AM
    TSUNAMI*22
    TSUNAMI*22 Obama can suck-it
    Stockton, CA
    '07 Standard Cab / White / 2.7 I4
    ScanGuage 2 equipped. Toyota DIY aftermarket Cruise Control mod
    *retarted? :laugh: Don't you mean retarded?
    It's not a stupid thread. It's a valid question that deserves a valid answer.
    In simplest terms: A/C on = worse gas mileage than if it's off, due to reasons stated in the above posts.
    In addition, your mileage will suffer much more greatly from every 5 mph increase in speed after 55 than A/C will ever hurt it at any speed. I've seen big drops in gas mileage with my scanguage tool when reading between speed increases. It's amazing what wind drag will do to performance.
  14. Oct 25, 2008 at 10:35 AM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    To only add more technical information to this thread, the environmental selector may make a difference in the mid 50/50 position as the AC compressor will engage when the Freon needs to be pumped into the condenser for cooling to take affect. It will cycle on and off as needed. So if the incoming air is already cool, the compressor may run for 10 mins, off for 5, on for 10 and so forth. If the incoming air is warm, it will run continuously. So in recirculation mode with full heat, the air will effectively be warm, fed through the condenser (cooled) and heated again to the environmental setting.
    But now were talking technical, not rational; as it would account for only hundredths of a penny in fuel difference (even at $3.6/gal).
  15. Oct 25, 2008 at 5:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The AC compressor cycles more or less due to the pressure its building in the system. It has nothing to do with the temperature.
  16. Oct 25, 2008 at 10:08 PM
    Rich Swanner
    Rich Swanner Well-Known Member
    N.California
    2007 Black PreRunner DC V6 SR5 LB
    Leer 100R Shell NXT Tech Wax
    Recycle gives you more cold air, but run regular vent to dry out the coils before you shut off , turn off the AC a little bit from home and leave on the fan..Rich ....City MPG does suffer, but you bought the truck to be Cool....LOL
