MPG?
Discussion in '1st Gen. Tacomas (1995-2004)' started by GLIDE50, Sep 27, 2015.
  1. Sep 30, 2015 at 2:51 PM
    doyouevenprerun
    doyouevenprerun Well-Known Member
    Jake from state farm
    Gilbert, AZ
    02 TuRD
    just got a simple lift on her
    Dude, half tank on the dash is not really half tank....
    if you have a 18.5 gallon tank, and your at a half tank, you probably only have 7 gallons left......
  2. Sep 30, 2015 at 2:53 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    :bananadead:Ok I lose guys. I'm wrong. My bad. Don't listen to me. I'm insane. I guess my brain thought it was cooler than it actually was.
  3. Sep 30, 2015 at 3:46 PM
    doyouevenprerun
    Gilbert, AZ
    02 TuRD
    Not ragging on you, just saying that you should really try it the other way..... you get an exact measurement every time....
    The Fluffer likes this.
  4. Sep 30, 2015 at 3:56 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    I'm just under a half a tank. When I get on empty, I'll be sure to try it your way.
  5. Sep 30, 2015 at 4:10 PM
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    ive gotten a smidge over 26 mpg on a tank of all highway 60-65 and driveing hills (i.e. easy up, steady down)...01 3.4 DC 4wd. so i think 25 is certainly within bounds.
  6. Sep 30, 2015 at 5:38 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    dont forget to account for your larger tires if you have them..
    for me.. when I calculate MPG's:
    take miles shown on Trip and add 1.064% (the increase over stock tire size for me)
    divide by gallons shown at pump when pump shuts off when full
    reset trip and repeat next time
    for instance..
    278 miles shown on trip..
    278 x 1.064 (yours may vary depending on new tire vs stock tire size)= 296 miles
    296 / 18 gallons (18 is just an example. I try to fill up as soon as the light comes on, so it may be more or less than 18 gallons when I fill up)
    = 16MPG (about my average.. usually between 16-18)
  7. Sep 30, 2015 at 6:03 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    just did some figures, and wanna brag that I only spend about 50 bucks a month in gas with my truck
    :bananadance::broccoli::dancingbacon::locked::jellydance::kona::taco:
    but the again, I live 2.5 miles away from work and take taxis/shuttle when going out.
    and tell me what you guy think about this. I can take this route, and make it back home all on 1 topped off tank. it's a mountainous off road route that can have some pretty hefty boulders to crawl over if you take the harder paths.
  8. Sep 30, 2015 at 6:30 PM
    58jake
    58jake Active Member
    Jake
    Three Forks, Valley Center, Kea'au
    I always love hearing this. Where do you think the pump pickup pulls from? Just a little of my past experience, I own a 1996 crewcab longbed F350 with factory dual tanks. Not long after I bought it one of my pumps failed, I dropped the tank and replaced it. I didn't find a spec of dirt in that tank. I've also owned a '93 Lightning and a '95 shortbed F150, both with dual tanks. With all three of these trucks it's my common practice to run the rear tank bone dry before switching. You can run them dry, just don't let it struggle too long, you may shorten the life of your pump.
    Oh and to the OP, I'd love to get 25 out of my '96 3.4, I'm stoked when I see 20.
  9. Sep 30, 2015 at 8:24 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    no method is 100% accurate for measuring mpg, save one: a controlled environment with an exact measured amount of fuel, running a consistent speed, no deltas.
    Every slow-down and take-off throw the numbers off. when you start up after it's been off and sit at long lights/in traffic.
    you can get a good "idea" as to what you are getting by using the trip and fill-up amount. the avg works out close the more you keep track.
    this does kind of sound like a rant but you get my point: no one is right, but no one is wrong :D
    p.s. I wouldn't run it dry but I've been know to fill up 16.5+ gallons...
  10. Oct 1, 2015 at 8:34 AM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    I agree that with most modern vehicles debris on the bottom of the tank isn't really an issue. But the gas surrounding the pump is also used as a heat sink for the pump, so why would you run the risk of putting extra strain on the pump just to go a few more miles before filling up?
  11. Oct 1, 2015 at 9:48 AM
    doyouevenprerun
    Gilbert, AZ
    02 TuRD
    This exactly.... the pump uses gas to stay cool, running dry all the time could put extra un-needed stress on the pump.
    P.s. i do run close to dry sometimes, everyone does it ;)
  12. Oct 1, 2015 at 7:15 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    I average 23-25 mpgs daily driving in my '97 ext. Cab 2.7l 5spd 4x4 with 31" mudders and 300k on the clock. Up hunting last weekend bouncing around in the hills for 170 miles I got about 23.5mpg. Plenty happy with the economy of this little rig
