MPGs & Ride - 265/70/16 vs. 265/75/16
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mceagle555, Dec 21, 2008.
  1. Dec 21, 2008 at 10:10 PM
    mceagle555
    mceagle555 [OP] Tacoma Shrek
    VA
    '05 Impulse Red PreRunner DC TRD OR
    Metra iPod/aux; Rugged Cover Tri-fold Tonneau; Center Console Divider; AFE Pro-Dry S AF; 4-leaf TSB; Fumoto Oil Valve;
    I know everyone hates tire questions, but I have searched the threads for days and don't have a specific answer to my question. Because of having $500 in gift cards to Sears, I am buying my tires there. I have it narrowed down to the Firestone Destination A/T's (Unless someone convinces me i should go for the General Grabber AT2's). I'd prefer to go with the 265/75/16's because of the look & supposedly correcting the speedo being off (2-3 mph slow now).
    Truck: 2005 DoubleCab Prerunner OR TRD
    Current Tires: Stock 265/70/16 Rugged Trails
    My questions are:
    1. I do 95% pavement driving...is it a mistake to get the AT's? Will I see a drop in MPG from the stock Rugged Trails?
    2. I know the 265/75/16 will fit without rubbing, but do I need to re-gear at all, or will the tranny be unaffected?
    3. Am i going to see a drop in MPG with the 265/75 versus the 265/70?
    Anything else I should be thinking of?
  2. Dec 21, 2008 at 10:26 PM
    josh3972000
    josh3972000 Well-Known Member
    kentucky
    02 dbl cab TRD
    265 75 is the perfect size for our trucks, I noticed no drop in power or mpg, no need to regear, and this size also looks great with a mild lift.
    Hell, I ran 33's on a 98 4cyl and I didnt regear, 5th gear was useless.
    You will be fine on pavement with at's just check air pressure and rotate on a regular basis.
  3. Dec 21, 2008 at 10:30 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Do you drive your truck slow & careful or fast & like a sports car?
    I drive mine like a sports car & run performance tires. My truck came with BFGoodrich Gforce tires. I ran a 2nd set of the same. But when it came time for my 3rd set I switched to the Nitto NT420's. The tire was rated to last longer than the BFG's & half the price. The ride comfort is much better. I do run a big tire 265/50/20. When I pass the speed sensors the police put up on the side of the road. My speedo is set to what the sign says.
    If you are doing mostly road driving & not 4x4 driving, I would go with a performance tire.
  4. Dec 21, 2008 at 10:33 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    1. Not a mistake with the Destinations. I have them and I rarely go offroad. They're quiet, good handling, good traction in the rain, and are decent offroad.
    2. No need to regear, trans unaffected.
    3. I saw no drop in mpg going from 245/75/16 to that size.
  5. Dec 22, 2008 at 4:15 PM
    mceagle555
    VA
    Thanks for all the advice guys...I will probably end up with the 265/75/16 Destination A/T's. I think is seems like the smart choice.
  6. Dec 22, 2008 at 6:48 PM
    genxer36
    Sean
    Bethlehem,GA
    The Grapplers are awesome looking!
  7. Dec 22, 2008 at 8:54 PM
    TacoNH
    TacoNH tat daddy
    Nü Hampshire
    07 Blue Tacoma 4.0/6speed
    887s, 5100s, Light Racing UCAs, Nitto 285s, Leer Cap.
    Is there a noticeable size difference between the 70 and the 75?
  8. Dec 22, 2008 at 9:22 PM
    HighPlains
    HighPlains Well-Known Member
    I went with Michelin LTX AT2 in a 265/75/16 Load Range E over the factory tires. I did not experience really any difference in MPG. The speedometer is now reading correctly. It was about 4-5 MPH off @ 65-70. I do think that I lost just a little power going to the larger tire, but not enough to discourage me from reaffirming the decision. This may be due to the heavier weight of the 10 ply tire over the factory OEM tires. I mainly went to the larger size due to the fact that Michelin does not offer the 10 ply AT2 in the OEM factory size.
  9. Dec 23, 2008 at 1:34 PM
    mceagle555
    VA
    Thanks for everyone's input!
  10. Dec 23, 2008 at 4:11 PM
    mceagle555
    VA
    Here's another question...this time regarding the spare tire.
    Those of you that upgraded from the 265/70/16 to the 265/75/16 tire, did you change out your spare as well? (The 265/75/16 is a taller tire.)
    Here is my concern. If i get a flat in the future and have to use a spare temporarily, is it going to be dangerous using the 265/70/16 (spare) with the 3 other 265/75/16's?
  11. Dec 23, 2008 at 4:18 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Not dangerous. Those donuts many cars have aren't the correct diameter either. You just want to make sure you get your tire fixed/replaced ASAP because obviously your alignment will be off.
  12. Dec 23, 2008 at 8:01 PM
    HighPlains
    Agreed....not necessarily dangerous, but at the same time not a good idea. The two tires will not be turning the same rpm on the same axle. Probably not that big of deal if you use it just to get out of a jam, but you definitely do not want to go on about your business as if you never changed the flat one out. Most tire shops I've dealt with in the past typically have a huge stack of tires that have been removed when someone gets a new set. If you are buying a new set of tires from them, I would think they would let you just have one in the correct size. All it has to do for you is hold air and be safe for a spare until you get the normal one fixed.
