MQQSE and Stitch's Shack + Sumbitch
Discussion in 'Canada' started by MQQSE, Aug 2, 2019.
  1. Sep 21, 2019 at 1:36 PM
    #601
    MQQSE
    MQQSE [OP] I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Hmmm...don't know? She's the one that named my first '81 pickup "Trigger." I'll have to tell her since these are meant to be long term vehicles, she needs a name for good luck. Let's see what happens. :)
    It would not surprise me if she says exactly that. :laughing:
    Thanks man! :fistbump:
  2. Sep 22, 2019 at 7:38 AM
    #602
    Martin64
    Martin64 Well-Known Member
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    Good morning.
  3. Sep 22, 2019 at 7:40 AM
    #603
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Morning everyone!
  4. Sep 22, 2019 at 7:42 AM
    #604
    MQQSE
    MooseMan
    Palmer, Alaska
    :wave: Morning Martin and Bill.
  5. Sep 22, 2019 at 7:45 AM
    #605
    MTgirl
    Weesa
    Bob's secret mod lair
    :pccoffee: slept like poop last night...out cold for 2 hours then toss and turn for 3. back out for another couple of hours and back up for good
    MQQSE[OP] and Martin64 like this.
  6. Sep 22, 2019 at 7:51 AM
    #606
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    I did that too.
    MQQSE[OP] likes this.
  7. Sep 22, 2019 at 7:52 AM
    #607
    MTgirl
    Weesa
    here. i made extra...
  8. Sep 22, 2019 at 7:53 AM
    #608
    MTgirl
    Weesa
    crap....i thought i was in the 50's thread. how'd i end up in MQQSE's garage?
    MQQSE[OP], Taco-Grinder and TomTwo like this.
  9. Sep 22, 2019 at 7:54 AM
    #609
    T4RFTMFW
    T4RFTMFW Well-Known Member
  10. Sep 22, 2019 at 7:55 AM
    #610
    TomTwo
    Bill
    I-85 Southbound
    :rofl::rofl::rofl: Sleep Deprivation
  11. Sep 22, 2019 at 8:07 AM
    #611
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    Thanks. Going to need it.
  12. Sep 22, 2019 at 9:08 AM
    #612
    MQQSE
    MooseMan
    Palmer, Alaska
    That's how it starts. :anonymous:
    You're the Mod, figure it out.
    Hiya kid, how's tricks?:)
    And Good Morning...I just got home... morning nap time. :yawn:
    T4RFTMFW[QUOTED] likes this.
  13. Sep 23, 2019 at 5:34 AM
    #613
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    Good morning.
    Bigdaddy4760 and MQQSE[OP] like this.
  14. Sep 23, 2019 at 5:43 AM
    #614
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Mornin
  15. Sep 23, 2019 at 6:40 AM
    #615
    TomTwo
    Bill
    I-85 Southbound
    Mornin to my Northern Folks
    Bigdaddy4760, MQQSE[OP] and VE7OSR like this.
  16. Sep 23, 2019 at 10:22 AM
    #616
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Salutations from the great white north; well not quite white yet, leaves have just barely started to change color.
  17. Sep 23, 2019 at 10:42 AM
    #617
    TomTwo
    Bill
    I-85 Southbound
    2B3F9615-6F24-44A2-9358-9867267E481B.jpg DD334AEA-6DEF-44D6-92FF-A03F39EA50C6.jpg @MQQSE Brothers tree and stump removal in progress
    Bigdaddy4760, Martin64 and MQQSE[OP] like this.
  18. Sep 23, 2019 at 11:27 AM
    #618
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    ^taking advantage of the circumstances to clear some land, or removing danger trees? looks like many of those trees should green up again.
    Bigdaddy4760 likes this.
  19. Sep 23, 2019 at 11:33 AM
    #619
    TomTwo
    Bill
    I-85 Southbound
    @VE7OSR They are Clearing fire damaged trees, Some of the trees look healthy but the fact is the roots grow on the surface under the vegetation and the fire burned away the vegetation and damaged the roots beyond the point of making a comeback. Some trees that look healthy are just falling from the wind making for a dangerous situation for everyone. @MQQSE can elaborate
  20. Sep 23, 2019 at 11:40 AM
    #620
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    yup, familiar with the hazards forest fire damage leaves behind. I see what you mean about the shallow roots. Hopefully the fire didn't go underground anywhere near you, correction your brother's place.Those root networks can keep burning right through winter. What I found interesting after one of our major fires, is the deer will still use the same trails they did before, even though they could wander wherever they wanted to. Breaking through into root holes not so much fun. Where there are shallow wet pockets, we get morel mushrooms growing like crazy the next spring.
    Bigdaddy4760 and Martin64 like this.
