Mr. Marv speaker adapter bolts
Discussion in 'Audio & Video' started by WTtoolman, Nov 1, 2010.
  1. Nov 1, 2010 at 7:44 PM
    WTtoolman
    WTtoolman [OP] Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    I just received my speaker adapters from Marv and am curious if anybody knows what size, pitch and length of bolts I'll need to install them. Or if you know what size and pitch the stock bolts are that would help, too. I won't have time to take the door apart and look so if anybody knows, I'd really apreciate it. Thanks!
  2. Nov 2, 2010 at 5:32 PM
    WTtoolman
    William
    Omaha, NE
    Come on guys!!?? A crap-ton of people have speaker adapters that require longer bolts! Somebody has to know!! What if I say please?
  3. Nov 2, 2010 at 5:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I would take one bolt down to a local hardware store, and have them measure the stock one. You should be able to tell what size you will need from there.
  4. Nov 2, 2010 at 5:53 PM
    WTtoolman
    William
    Omaha, NE
    Yeah, I just don't have time to take the door apart. I have limited few hours to do the install on thursday afternoon and wanted to have everything on hand. I was hoping someone would know
  5. Nov 2, 2010 at 6:56 PM
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | DiamondBack SE Tonneau Cover, Havoc HS2 Hoop Steps, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat | INTERIOR | Flyzeye V2W (Amber/White/Amber), RAM Mt A-Pillar Mod, Audio: Pioneer AVH-X5700, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    Well I'll offer this up. I made my own my adapters out of 3/4" mdf, counter sunk the screw heads 1/4"... maybe 3/8" (can't remember for certain), and used no. 12 x 1-1/4" Pan head phillips screws. They threaded into the stock holes nice and snug.
    Based on Marv's adapter stock thickness and whether they have countersunk screw holes you should be able to figure out what you need. Hope this helps... Good luck!
    *Note: The screws I used have a much more coarse thread than the stock screws... I don't want anyone thinking they're longer replacements.
  6. Nov 3, 2010 at 6:57 AM
    rscecil007
    rscecil007 Well-Known Member
    Seattle
    06 4x4 TRD Sport Access Cab
    Goodyear Duratracs 265/70R17's, Bed mat & extra d-rings, Weathertech floor liners, Husky Liner for rear seat area, Biceman Illuminated 4x4 Switch, Pioneer 800 PRS, Hybrid Audio L6 and L1V2, JL 13TW5 in a Mr. Marv box, JL HD900/5
    Go read his how to thread here on the board. I'm 99% sure he mentions what bolt to get in there.
    I know he at least gave enough info for me to run to Lowe's and get bolts, nuts, and washers to work for my adapters he made me. Sorry I can't tell you what size, but it's been almost a year since I installed mine.
  7. Nov 3, 2010 at 8:23 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    From Mr Marv's how-to thread, if you're using the stock plastic mounts, you'll need 30mm M6 bolts for a 3/4" thick baffle, and longer for a 1" baffle (probably around 35mm). If you're not using the stock plastic mounts, then it doesn't matter as long as the screw is long enough, but that's what she said :D
