Mr. Toyota
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mr. Toyota, Jun 11, 2016.
  1. Jun 11, 2016 at 10:09 AM
    Mr. Toyota
    Mr. Toyota [OP] New Member
    2015 Tacoma sport TRD
    6" Zone suspension lift with Fuel 18x9 wheels and -12 offset wrap with 35x12.50 18 Toyo A/T2 tires.
    I recently installed a Zone 6" suspension lift on my 2015 4x4 Tacoma with 35"12.50 x18" Toyo A/T2 tires on 18x9 Fuel -12 offset wheels and now my speedometer is 6.8 mph off.
    I've been on the internet and called some of the big name aftermarket programmer and found only Hyper Tech to offer for a 2015 Tacoma an In-line connect behind the instrument cluster speedometer calibrator.
    I know they sell calibrators for older models that plug to your OBD connection. OBD stands for On board Diagnostic plug that is under the dash they use to read the trucks computer.
    I also looked at performance programmers and no one sells for 2015 yet.
    Has anyone used the Hyper tech calibrator for a 2015 or does anyone know of something else that would correct my issue.
    Thanks :oldglory:
  2. Jun 11, 2016 at 2:53 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
  3. Jun 11, 2016 at 7:26 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    You are correct! I have one in my 08. Works great! Been installed just over six years. Here is a post I made on another forum when I first installed it.
    http://www.toyotanation.com/forum/showthread.php?p=3148476
    In case you can't view the post on TN...the only thing I would do differently is I would leave the USB cable plugged in and stash it under the dash where it would be accessible to change the settings on the calibrator via laptop without having to pull the dash apart.
    Simple Man likes this.
