mrbeggins 04 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by mrbeggins, Mar 24, 2013.
  1. Dec 2, 2013 at 12:22 PM
    #361
    mrbeggins
    mrbeggins [OP] LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    What page is it on? I wouldn't mind taking a look
  2. Dec 2, 2013 at 5:12 PM
    #362
    98THOR
    98THOR Well-Known Member
    Hawaii
    98 ex. tacoma 4x4
    33x12.50 nitto mud grapplers, Pro Comp eXtreme alloy wheels 17x9, Fabtech/fox adjustable coilovers in the front, Fabtech rear shocks, 3" body lift, Tint, K&N air filter
    do you know what company makes it? thanks
  3. Dec 2, 2013 at 5:22 PM
    #363
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
  4. Dec 2, 2013 at 5:50 PM
    #364
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
  5. Dec 2, 2013 at 5:56 PM
    #365
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Thanks!! Kind of a nifty setup, but around here with all the shitty roads conditions I'd be filling that sucker every 50km's haha. I wonder if I can fit a bigger "tank" somewhere. Or maybe switch to 3" after the bend. Hmmm
  6. Dec 2, 2013 at 6:43 PM
    #366
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    if i had an 01-04 im pretty sure out trucks would look identical with the exceptions of front bumpers. but damn, your truck is beautiful
  7. Dec 2, 2013 at 6:50 PM
    #367
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Tanner, I got to tell you man the look of your truck is awesome. The work you did on the fenders is pretty clean. Refresh my memory. Front fenders are trimmed an 1" all the way around except for the rear of the front fender. That has to be cut back at least 4". How did you make that shit look so clean broseph!
  8. Dec 2, 2013 at 7:24 PM
    #368
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Thanks Paul! I'm going to drool over yours once your done with it. Mind you I have been already haha. My fronts are cut 1 3/4" all the way around, then like you said a lot more near the rear of the front. I can't exactly remember what the number was, but 100% sure the arch of it is cut 1 3/4". And the rears are cut 1"
    I used the thinnest cut off wheel I could find, and basically made plunge cuts below my line, then took another pass to smooth the arch out. Once that was done, I used a flap disk to clean up the burrs on the inside of the fender.
  9. Dec 2, 2013 at 8:45 PM
    #369
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    Are you by chance selling your old led bar?? :)
  10. Dec 2, 2013 at 9:28 PM
    #370
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Sorry, it's already been sold!
  11. Dec 2, 2013 at 9:37 PM
    #371
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Bleghhh alright man.. :rolleyes:
  12. Dec 3, 2013 at 8:30 AM
    #372
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Is there a reason you run the M/T-R backwards on the right side?
  13. Dec 3, 2013 at 8:56 AM
    #373
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Do you have ABS? if no..then i know i have seen a guy on TTORA? I think..been a while..but he used a GMC blazer or jimmy or s10..can't totally remember..tank. It fits right up by where the ABS usually sits or where a lot of people put thier second battery on the passenger side above the air box.
    damn..i can't remember where the hell i saw that..kinda disregarded it as i have a battery there..
    they aren't a symmetrical tire. How all MTR Ks are. sadly..
  14. Dec 3, 2013 at 9:19 AM
    #374
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    That's correct, MTR's are an asymmetrical tire.
  15. Dec 3, 2013 at 9:24 AM
    #375
    COMAtized99
    North Carolina
    99 DCLB v8
    Huh??? :Confused: You mean directional, not symmetrical??I did a little good searching and looks like they are not directional
  16. Dec 3, 2013 at 9:26 AM
    #376
    Blackdawg
    Monte
    Wyoming/St. Louis
    same thing really..
    yes they aren't directional..because they aren't symmetrical.
    the tread is different on each half of the tire. thus..not symmetrical. As pointed out above..asymmetrical.
    due to that..they aren't a direction tire. they only mount up one way and thats why the passenger sides always look backwards.
    Not for the OCD owners..haha
  17. Dec 3, 2013 at 9:33 AM
    #377
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    What did you use for fillers in the fender flare holes?
  18. Dec 3, 2013 at 9:38 AM
    #378
    COMAtized99
    North Carolina
    99 DCLB v8
    my brain hurts... go it though...
  19. Dec 3, 2013 at 9:39 AM
    #379
    Blackdawg
    Monte
    Wyoming/St. Louis
    :laugh:
    :thumbsup:
  20. Dec 3, 2013 at 11:36 AM
    #380
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    See above :thumbsup:
