mrbeggins 04 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by mrbeggins, Mar 24, 2013.
  1. Jun 7, 2013 at 4:25 PM
    mrbeggins
    mrbeggins [OP] LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
  2. Jun 7, 2013 at 4:34 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Las Vegas, Nevada
    2003 Tacoma TRD 4X4
    :thumbsup:
  3. Jun 7, 2013 at 5:13 PM
    CBR1000RR
    CBR1000RR Well-Known Member
    Maryland
    03 TRD DoubleCab
    Toytec ultimate lift kit
    I have the same front bumper with a WARN M8000 winch. I didn't realize that the all pro bumper was designed for a winch with synthetic line. What did you do to make that roller style fair lead work with that bumper?
  4. Jun 7, 2013 at 9:40 PM
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    The roller style or the hawse fair lead? The roller style bolted right up to the stock mounting holes in the all pro bumper. As did the TJM aluminium fair lead.
    Did you have to drill the roller fair lead for yours to fit?
  5. Jun 7, 2013 at 10:00 PM
    CBR1000RR
    Maryland
    03 TRD DoubleCab
    I am talking about the roller style fair lead. The holes that come on the fair lead are in the middle and I had to shim the fair lead out with washers just to bolt it on. I haven't used it because it will just bend the brackets but I just did it to bolt the fair lead on so at least I had one. Will it work well even with all the pressure on it when winching if I drill holes lower for it to fit?
  6. Jun 8, 2013 at 7:02 AM
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Ooh...I'm pickin up what your puttin down. The fair lead that I used had 2 different mounting locations drilled in it when I bought it. The 2 holes that I used were in fact lower than centre of the fair lead, so yes... The fair lead sat higher allowing it to clear the bottom tube of the bumper. Believe it or not I actually found the fair lead at princess auto here in Canada. Do you guys have something similar in the states?
    Hope that helps. Could you red rill holes lower on the fair lead? Or just switch to synthetic line and a hawse style lead all together haha?
  7. Jun 8, 2013 at 8:43 AM
    CBR1000RR
    Maryland
    03 TRD DoubleCab
    Well I want to switch to a synthetic line and hawse fair lead but funds are kind of tight right now as I just dropped 5k on the truck this past month. I will be taking the fair lead off and drilling holes lower on the fair lead to make it fit.
  8. Jun 9, 2013 at 4:27 PM
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Took the mountain bike out today and met up with the CT4WD group that were out for their monthly run. Got to ride it down the mountain then got a pinch flat in 2 different spots. I then proceeded to ride shotgun for the rest of the day:)
    image by Tanner Tucker, on Flickr
  9. Jun 9, 2013 at 9:30 PM
    RJ MacReady
    RJ MacReady professional trousersnake charmer
    RJ/Mike Hauncho/HeavyHands
    US OUTPOST North 31-Mayday Mayday! We've found som
    00 4Runner 4WD LTD - Cheatin' Bitch Build 2
    Cheatin' bitch build 2: All stock for now... 99' Tacoma 4wd TRD Cheatin' bitch build 1: BG44K additive, motul 5w40(always), deckplate mod, K&N washable air filter, 2.5" flow master(cut thanks to Airdog), king fronts 2.5", all pro standard leaf pk, stainless steel rear ext brakeline, 5125's 10" travel rears, 4-jasper offroad 6" pod LED spot lights, secret compartment for small bottle of wild turkey, cobra CB, Hi-lift jack w/locking bed mount, hi lift curved bumper lift & road base plate, smittybuilt X20 winch, wab fab F&R bumpers w/ hitch receivers, smittybuilt 4in1 recov tool, 10gal mini flamethrower, 11 lbs dynamite sticks, 13 4-hr snowflares, .50Cal full auto mounted machine gun w/ RPG unit & a shitoad of death metal to fuckstart your brain...everything you need for first contact with a shape-shifting alien entity frozen for over 100,000 years reanimated & immitating all life it engulfs.
    thats some heavy duty shit...plenty of room for mini bottles of whiskey
  10. Jun 9, 2013 at 9:38 PM
    IDtrucks
    IDtrucks My screen name is now slightly incorrect...
    Mark "Buck"
    Jackson Wyoming
    looks very clean! nice work!
  11. Jul 13, 2013 at 5:27 PM
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    I've been busy with work and helping out with the flood situation we had up here in southern Alberta, but still managed to get out and have some fun. These ledges are much larger in person and a lot more challenging than they look in the picture. It was a blast!
  12. Jul 13, 2013 at 5:33 PM
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
  13. Jul 13, 2013 at 6:15 PM
    TotesMagotes
    TotesMagotes Too Drunk To Taste This Chicken
    British Columbia
    '01 Double Cab 4x4 V6
    OME Lift, 285's
    I just love the colour combo of red n black on your truck it looks wicked.
    Nice seat covers too, i'm looking for some covers for mine...are those pretty comfortable?
  14. Jul 13, 2013 at 6:24 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Great looking truck man!
  15. Jul 13, 2013 at 7:23 PM
    #35
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Well considering they are for a JK they actually aren't that bad. They fit a little loose, but with being loose they sit deeper into the boulsters of the seats. And their heavy duty to haha. No tearing these puppeies
  16. Jul 13, 2013 at 7:33 PM
    #36
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Thanks a lot!!!
  17. Jul 13, 2013 at 8:17 PM
    #37
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    I want those so bad but i didn't buy them because i heard they are made poorly and fall apart
  18. Jul 13, 2013 at 8:22 PM
    #38
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    looks way better painted around the headlights and rear bumper. that part around your headlights always bugged me.
    we'll dominate those ledges some time this year.
  19. Jul 13, 2013 at 8:48 PM
    #39
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    The old smittybilt ones were made bad yes. They had strings holding the sides together. It's what I had before these. But I can assure you, if you can rip these I'm sure smittybilt will give you your money haha. The buckles are tough and big
  20. Jul 13, 2013 at 8:59 PM
    #40
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Haha ya I've been putting that off for quiet some time now. It drove me nuts to.
    And yes...those ledges will be slayed in the next few months to come
