mrbeggins 04 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by mrbeggins, Mar 24, 2013.
  1. Feb 9, 2014 at 1:40 PM
    #701
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    Are you running your stock coils with the 5100 s up front
  2. Feb 9, 2014 at 1:53 PM
    #702
    mrbeggins
    mrbeggins [OP] LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    That's correct. At top notch. 2.5"
  3. Feb 9, 2014 at 2:01 PM
    #703
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
  4. Feb 9, 2014 at 2:08 PM
    #704
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Yes sir. I ordered mine from bilstein canada though. Same kit
  5. Feb 9, 2014 at 2:44 PM
    #705
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    How tough was it to install do u know what tools u needed I' want to Install mine but have never done anything like it and would like to learn
  6. Feb 9, 2014 at 2:48 PM
    #706
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    I would say the most difficult part is compressing the spring to switch over your front shocks. I just took my entire shock assembly off, with the new front billies and took them to a shop in town. Had them compress the spring and switch the shocks over. It's pretty simple though. Remove and replace.
  7. Feb 9, 2014 at 3:13 PM
    #707
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Safest and easiest way to do it. Of course I didn't do it that way though haha
  8. Feb 9, 2014 at 3:36 PM
    #708
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    How much did that run you? Did u have to undo the lca?
  9. Feb 9, 2014 at 3:38 PM
    #709
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    I have done it before and it ran me $20 per side. Don't have to do anything with the lca but if you still have a sway bar take that loose and it will be 100x easier to put back together
  10. Feb 9, 2014 at 3:40 PM
    #710
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Hmm.. So when u say assemble the shocks what do they do to them? Sorry I'm kinda new :D
  11. Feb 9, 2014 at 3:53 PM
    #711
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Gotta start somewhere! Basically the shop will have a wall mounted spring compressor that will compress the spring and taking the tension off so that you can remove the isolator pad, top nut, washers, and rubber bushing from the strut. You can then pull the strut out of the spring and insert the new one and simply put the pad, washers, bushings, and top nut back on. Then you let the pressure off the spring so that the components on the shaft are retaining the spring. The wall mount spring compressor is a much much safer way to do it. I used these
    but these are scary to use. They bend and have a tendancy to break and/or go flying.
  12. Feb 9, 2014 at 4:05 PM
    #712
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    I hate them things. If I have to use that, I wear a football helmet lol. A buddy of mine had one snap on him. It was a rented one from a local shop. Never again haha
  13. Feb 9, 2014 at 4:18 PM
    #713
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Ha yeah scary as hell. I wrapped my struts in blankets and a comforter while I was on them with an impact gun
  14. Feb 9, 2014 at 5:39 PM
    #714
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    So if I have a shop do all that then it just a direct switch to put the other ones back in? Or do I need a compresser to put the springs back on the truck
  15. Feb 9, 2014 at 5:48 PM
    #715
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Nope. Here's what you do haha. Jack truck up...remove front shock assembly. Coil and all. 3 nuts on the top and the 19mm (I think) bolt on the bottom. Take Both assemblies to a shop and tell them you want your springs switched over to your new billies. (You decide what notch to put them at obviously...) once they are switched over, throw your old front shocks in the dumpster, instal the new setup in reverse order from disassembly, take your truck down for an alignment. Go wheeling :)
  16. Feb 9, 2014 at 5:52 PM
    #716
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Haha thanks man, r you happy with the stock coils? Is it a nicer ride compared to my stock setup with a spacer? I'm considering getting the ebicach but if I don't have to I'd rather. Not
  17. Feb 9, 2014 at 6:10 PM
    #717
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Well...to be honest I love the ride. People flack me for keeping the stock coils and running billies, but I'm happy with it. I don't jump the truck, I'm not hard on equipment, and it performs how it should on the trail. The "right" way to do it would be eibach coils as well, but until my billies start pissing oil everywhere, I'm not going to switch. Once I do, I'll be going to a coilover. Most likely King or Fox.
  18. Feb 9, 2014 at 6:12 PM
    #718
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Ya that's what I'm thinking by the time these billies are shot I might be in a position to afford a mid travel system
  19. Feb 9, 2014 at 7:31 PM
    #719
    02 TRD Tacoma
    02 TRD Tacoma Well-Known Member
    Nathan
    Lenoir NC
    02 Tacoma DC TRD
    Bilstein 5100 front and rear, dakar leaf pack, fuel hostage wheels, 285/70/17 Trail Grapplers M/T, color match shell, rola rack, hi -lift, dual cb antenna's with 520 XL cb, sandblasted bumpers an brush guard to paint black, color match grill, blacked out badges, and much more.
    Tanner saweeeet man hell I didn't know u put 35's on it looks sick dude I can't imagine what it looks like now it is one of the nicest trucks I've seen. What size is ur light bar?
  20. Feb 9, 2014 at 7:39 PM
    #720
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Thanks man!!! The light bar is a 22" single row 10w Cree chips
