mrbeggins 04 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by mrbeggins, Mar 24, 2013.
  1. Sep 9, 2015 at 8:05 AM
    #1481
    cynicalrider
    cynicalrider #NFG
    Jersey
    Is that photoshopped? lol The rear shackle looks weird.
  2. Sep 9, 2015 at 9:48 AM
    #1482
    mrbeggins
    mrbeggins [OP] LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    It is yup. Same wheels 6 lug though, I wanted to see what it was going to look like bobbed another 4"
  3. Sep 9, 2015 at 9:56 AM
    #1483
    cynicalrider
    cynicalrider #NFG
    Jersey
    Would you gain much clearance by bobbing it that much? I mean you would still hit your shackles, right?
  4. Sep 9, 2015 at 10:01 AM
    #1484
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    I would gain another 4" on the bedsides. That's it
  5. Sep 10, 2015 at 6:42 PM
    #1485
    Frolanda
    Frolanda Well-Known Member
    Fort Walton Beach, FL
    2000 Tacoma TRD
    what's your instagram? can't find stumpyy04?
    sick truck, jealous of all the adventure pics!
  6. Sep 10, 2015 at 8:19 PM
    #1486
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    It's tucker_tanner now
  7. Sep 22, 2015 at 9:03 AM
    #1487
    N_bannerman
    N_bannerman New Member
    Nathan
    2001 ext cab trd tacoma
    Curious if you are running the factory overloads on your leaf packs and if not how bad it squats with the back loaded down?
  8. Sep 22, 2015 at 9:05 AM
    #1488
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Still has the factory overload yes. No more AAL though. The truck doesn't squat much because 10.5" is missing of the box, so a lot of the weight is over the axle. I just had 600lbs on concrete bags back there about an hr ago and it doesn't squat that much
  9. Sep 23, 2015 at 1:03 PM
    #1489
    crumf20
    crumf20 Well-Known Member Vendor
    Wesley
    Tempe, AZ
    2000 Tacoma 3.4L 4x4
    33 x 12.5 x 15 Cooper Discover STT Pro's, All new UCA's LCA's including all balljoints, Bilstein 5100's all around with Dakar leafs w/ AAL in rear with 1inch extension Shackles, Eibach coils up front with 5100's set at 1.75 and 1/2inch spacer as well. Kenwood Double din deck with JBL 12in Sub: 300rms. Rockford Fosgate speakers front and back. New OEM black grill, Black Anzo Headlights with ddm tuning 6000k HID's. Seat Covers Unlimited black and grey 2 tone seat covers. Cobra CB Radio and PA system.
    Sir, I am thinking about bed lining my rockers as well. Yours look amazing and I just recently did my fenders and they turned out great but I am curious how you got the line to be so straight and perfect? Did you just spend a lot of time taping it off?
  10. Sep 23, 2015 at 7:00 PM
    #1490
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    I honestly just eye balled it and followed the body lines. The body lines themselves start to dip near the rear of the box, so I eye balled the painters tape to be straight. I thought it would look goofy if I followed the direct body lines with the box liner.
    I used ordinary green painters tape, but make sure you press it on there good. Especially the edge that's meeting the box liner. If you don't the box liner will "run" underneith the tape and it's a bugger to wipe it up and make it look good.
  11. Oct 7, 2015 at 11:08 AM
    #1491
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I didn't read through the whole thread but are you still on stock springs and the AAL??
  12. Oct 7, 2015 at 8:15 PM
    #1492
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    I have removed the AAL. So just stock springs right now
  13. Oct 8, 2015 at 8:58 AM
    #1493
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Stock springs and 35s!! Damn! :)
    Adventurer_Alex likes this.
  14. Nov 16, 2015 at 11:14 AM
    #1494
    motoman255
    motoman255 Well-Known Member
    Cameron
    SF Bay Area
    04 SR5 V6 and 2021 TRD-OR
    2nd Gen TRD Supercharger, 7th injector, Solo Motorsports LT,
    Hows it going,
    I cut my front fenders a couple days ago and can't fit the stock plastic back into the fender well now. I was wondering what you did to prevent water from entering the air box. I don't really want to put a snorkel on it just because i don't like how they look and i see you didn't do that. @mrbeggins
  15. Nov 16, 2015 at 11:26 AM
    #1495
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    it looks like he is running a cold air intake of some sort. so it wouldn't be sucking air from the stock location.
  16. Nov 16, 2015 at 11:37 AM
    #1496
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    This is correct! I don't use the factory air box
  17. Nov 16, 2015 at 11:40 AM
    #1497
    motoman255
    Cameron
    SF Bay Area
    Well i guess my snow wheeling trip is going to be put off until i can locate a new intake thanks @Cohbsteq and @mrbeggins
  18. Nov 16, 2015 at 4:39 PM
    #1498
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    I know this is a somewhat old post, but I know a guy running 37, with a 4cyl 5 speed... His SN is "GotCope?" on ttora. I am also running 35s on my Tacoma, but I have a bit more torque than stock. :)
  19. Nov 16, 2015 at 6:35 PM
    #1499
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    What filter is that??
  20. Nov 16, 2015 at 7:41 PM
    #1500
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    It's actually an amber sheet of Laminex. I measured it out and cut it myself.
